Does not show any networks detected
Hello phineas mbabvu,
In order to better diagnose the problem, I would need the model number of the HP laptop......
SOURCE: Wireless card will not connect to internet
Hey Chet, What is the model number for the device? I'll see if I have one for you.
SOURCE: Cannot connect my wireless adapter to Belkin wireless router
Check and see if this setup guide matches your device?
Setup Guide
If it does we can probably search for more information.
Did you configure your router using WEP, WPA security (using passphrases) on your router?
Did you enable MAC address checking on your router?
SOURCE: hp laptop dv6000 series won't recognise netgear wg111v2 wireless adaptor
If you need a new battery, I suggest you could purchase one from adapter , which would shipping to you fast and the quality is satisfy satisfied.:)
SOURCE: Wireless connection to internet
I just got it all working [new notebook running Vista], connecting to the net via the telkom 5102G - with a PC running XP connecting via LAN.
The 5102G comes ready configured with a network key / code [stuck on the back] so use that to connect to the router - once you've connected it'll come up with limited connectivity.
I then ran the firmware upgrade from http://www.telkomphones.co.za/5102g.htm
To do this, download and unpack the thing. In your browser, go to 10.0.0.2 [for the router config] and click on firmware and follow the instructions.
Once this is done - disconnect and reconnect the vista laptop connection. Open your browser and simply click on tools and uncheck the tickbox alongside "work offline".
I know that sounds ridiculous but that's exactly what I did and I'm surfing fine.
Now... just need to share files and printer and we're 100%.
Hope that helps.
SOURCE: HP Laptop does not connect to internet unless directly
Hello dstoller,
You description is very confusing to sort exactly what is or isn't happening.Let me try to sort out what you have:
You have a Laptop
You have a Desktop
Desktop has a printer attached
You have a DSL modem with a wireless router
Laptop via ethernet: Good
Laptop via wireless: Not Good?
Desktop via wireless: Good
Not sure exactly what you are needing help with...
- Vincent
Still not sure what
Check the wireless router and high-speed modem.
If the two are not powered on, or if the Ethernet cable connected the two is not completely inserted into both connection ports, you are unable to access the Internet on the Acer Aspire One laptop computer.
Activate the wireless Internet connection on the laptop computer.
Right-click the wireless icon on the desktop, then choose "Enable" from the pop-up menu.
Without activating the wireless receiver on the Acer Aspire One, the laptop is unable to detect any wireless network.
Select the appropriate network you wish to connect to.
Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire. Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
Restart the computer.
The system may have booted and failed to detect the wireless receiver. Restarting the computer corrects this issue.
hope this helps
