My neon lcd with built in dvd player will not come on power light is on but cant get any tv channels
Watching a dvd on my neon lcd tv changed back to tv tv froze turned power off then back on power light stays on but no channels
SOURCE: Unable to locat and select the AV channel on new LCD HD TV
Hi, try switching your tv to channel 3 or 4 and see if that works- there should be a switch on the back of your DVD player beside the Coaxial Cable outputs-it will allow you to use Channel 3 or 4 as the default to play dvd's. I hope that helps-if more detail or wiring diagram is needed-please leave make and model numbers and i'll try to help.
Cheers and have a Happy Holiday Season!
Posted on Dec 23, 2007
SOURCE: digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Posted on Apr 01, 2009
SOURCE: dvd wont read discs dvd or cd
is the drive still recognised by the system of the tv? If so it may simply be a dist situation (that's what happened tro me recently) unless it was jolted heavilly just before it froze. I asume other disks won't read either. You could try a dvd cleaning disk but I found them to be pretty **** and an aerosol cleaner works a lot better. Get one from an electrical component supplier or even some department stores stock them. Be sure to use the right product, i.e. for blowing dust out of electrical systems, as you don't want to go spraying just anything in there. A friend of mine once used a car 'easy start' to try and do a similar job and he ended up buying a new cd player (it was an in car player). Like I said it worked for me.... I was ignoring my intuition for ages looking to get components replaced etc. Finally I gave in and ended up kicking myself for not having listened earlier!!!
Posted on Jul 06, 2009
  • 458 Answers
SOURCE: 3 year old 42in LG LCD TV scrren went blank
You will either have a fault with the inverter board which drives the backlights or a faulty backlight in the screen. If the problem is a backlight then a replacement screen is the only cure. One or the other is breaking down after it has been opn for a certain period of time, have an engineer call out & check with a tester if it is a screen problem.
Posted on Dec 19, 2009
  • 139 Answers
SOURCE: How do I change the power supply for my Viewsonic N3760W TV?
YOU HAVE A VOLTAGE/CURRENT LIMITER PROBLEM THAT IS PROBABLY CAUSED BY A LEAKY CAPACITOR IN THE FEEDBACK CIRCUIT IN THE POWER SUPPLY. THIS CAN BE FIXED. I CAN GUIDE YOU IF YOU CAN SOLDER AND FIND THE PARTS- RADIO SHACK OR MABYE AN OLD TV AROUND?
Posted on Dec 27, 2009
Testimonial: "Awesome help."
I bought a sony led tv, but i don't have any english instruction so that i can play DVD on my sony TV.Can u help me?
Here is a manual for your unit http://www.docs.sony.com/release/KDL40HX800_qs.pdf
As far as watching a DVD, I wasn't sure if your TV has a built in player or not. If you have a built in player simply insert the DVD and change the input channel to DVD. If you do not have a built in player, check to see how your DVD player is attached to the TV. Insert a DVD, then cycle through your inputs with your Input or Video Source button until you see the DVD playing.
Hope that helps!
Jul 18, 2011 | Sony KDL55HX800 55 in. TV
VENTURER PLV91217S52 22" LCD TV Hi does
Good day!
Unfortunately that TV Doesn't play media from U.S.B device.
This is the great features of that TV.
  • Free view built-in-- This TV includes a digital tuner which allows you to watch u p to 40 digital Free view TV channels with no monthly subscription or contract required.
  • Built-in DVD player--Your TV have a DVD player.
  • 720p H.D ready-----H.D Ready TV sets have a minimum horizontal resolution of 720 lines which means that they are capable of displaying high definition TV signals like play-station3
  • 1 High Bandwidth Digital Multimedia Interface - highest quality digital connection.
Thank you very much.
Apr 21, 2011 | Venturer PLV36220S1 22 in. LCD TV
Can't get the tv back on the channels properly after watching a m
Change the input, look for the button on the remote or on the TV itself. Just changing the channel on the TV after powering down the VCR should also work.
Sep 08, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Apr 13, 2009 | RCA DRC8320 DVD Recorder/VCR
Input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
Jan 05, 2008 | Sanyo DS24205 24" TV
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
