Question about Dishwashers
I keep getting an F2 error message on my Sandstrom dishwasher control panel why?
  • 1314 Answers
SOURCE: Display F2 E6 error, then dead. Keypad realted? How do I remove control panel?
fiest press the on key see if the display comes if not the turn the power off for 5-8 seconds if that doesnt do it turn power off then pull the oven out from the wall and remove the top to acess eoc pull the mylar ribbion out of the eoc by releasing the latch which is a tiny pullout bar at the base of the connector at the eoc then you cam clean the ribbon gently with a clean pencial eraser also under the top panel will be a tech sheet with more info pay atten to resseting the oven cavity size on start up
Posted on May 16, 2008
  • 297 Answers
SOURCE: my fuse in the controll panel of my dishwasher dies out.
Something shortening to ground.............
Posted on Apr 16, 2009
MNfisherman
  • 11896 Answers
SOURCE: F2 error code
F2 E6 says this:
1. Check keypad connector for firm connection.
2. Press CANCEL. If error code returns after 60 sec., replace keypad.
3. Replace control
Posted on Nov 10, 2009
  • 351 Answers
SOURCE: Asko 3350 F2 fault meassage keeps flashing
you have a blockage try the drain spigot under the sink or the pump may be blocked.
Posted on Jun 17, 2010
blueextc3221
  • 15935 Answers
SOURCE: Replacing touchpad or control panel in our RBD305PDQ8 oven
F2-E1 - Touch Pad (Keypad) Cable Unplugged -
Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
It appears your timer/clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&&&&&&&&&&&&&&
Posted on Oct 01, 2010
Sandstrom dishwasher showing f9
please i have a dishwasher SDW60B12 , i live in spain and no body knows this brand here. So the error code is F9, please anybody knows what does it mean.?.. please i called an engineer buy he does`t know about it. Pleaseee.
Nov 06, 2013 | Dishwashers
I keep getting the following error message: E6 F2 - what does this mean?
If you have a Whirlpool oven, the F2 E6 error means that the Cancel key line is open. You will need to replace the keypad or the keypad and controller board (if a single assembly) if the keypad doesn't respond to a press of the Cancel Key.
I hope this helps.
Dec 12, 2011 | Whirlpool Ovens
What does the F2 Error mean? I got that error thsi morning. The engine was buzzing so I turned the power off. I have cleared what appears to be calcium and/or soap build-up in the 3 filters and in the...
The F2 error means the tray underneath the unit has filled with water. You will need to pull out the dishwasher (remove 2 screws at top left/right when door open that prevent tilting). Unplug and pull out dishwasher. Remove 4 screws on bottom rear panel and you will see tray underneath. Sponge out water and F2 error will reset.
However, you should not get water in this tray. There may be a faulty valve, pump or leaking pipe. Run diagnostic mode (described in user manual) to see if leak occurs during filling, draining or circulating.
Sep 19, 2010 | Asko D1876 Dishwasher
Apr 23, 2010 | Asko 24 in. D3350 Dishwasher
My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
Jan 19, 2010 | Asko D1976 Built-in Dishwasher
ASKO dishwasher
F2 fault water in the base remove dishwasher from under the bench and tip back water will run out,then it will restart.remove rear lower panel and run the dishwasher you may find a leak,also check that the inlet valve is shutting off and not filling the dishwasher up overnight.hope this helps.
Mar 27, 2008 | Asko D1776 Stainless Steel Built-in...
Asko Dishwasher F2 Error Flashing
F2 flashes, and wll not stop runing. No water in pan. help
Sep 29, 2007 | Asko D1776 Built-in Dishwasher
F2 Error Message on my Asko D1776
F2 error message means that you have a high water level problem that could be caused: - A plugged or bed water pump - A defective water inlet valve (stay open) Good luck !
May 21, 2007 | Asko D1776 Stainless Steel Built-in...
F2 error message
Hvace, F2 is a shorted temperature sensor. Probably took it out with the self clean...Catriver..post back.
Aug 31, 2006 | Whirlpool GBS307PD Electric Single Oven
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
