Kenwood T-7i tuner no power
Power drop
How do I turn the volume up and down on a Kenwood tuner KT-56
Hello, according to the information I have, the Kenwood KT-56 tuner is just that. This means in order to have volume control you will need an amplifier. The KT-56 only allows changing of the stations, pre setting stations and may be a couple of more options. But it is only a tuner or simply put a display, now you need to put power behind it to make it put out sound.
Jun 17, 2016 | Kenwood Audio Players & Recorders
Where can I find a manual for Kenwood Tuner kt-57?
Is it a tuner only? If so you will need a power and or just a receiver with speakers. A tuner only has no power output for things like tvs.
Mar 25, 2016 | Kenwood KT-57 Stereo Synthesizer AM/FM...
I can't operate my kenwood KR-A4070 receiver manually anymore, it only operates with factory remote. When it was new, I could manually press the various function button's..such as power-tuner-etc., an
Only a service person can help now. Likely you have a connection loose, a buldged cap or maybe just a transistor with a cold solder joint. Not being able to see it makes it hard to tell.
Jan 21, 2015 | Kenwood Audio Players & Recorders
Kenwood KT56 need a code that will work
Of course it has no volume the KT56 is a radio tuner! It needs to be connected to a power amplifier to hear anything. The audio out sockets need to be plugged into a stereo amp that has speakers. The KT56 is not a stand alone device!
Jul 29, 2013 | Kenwood Audio Players & Recorders
Don't know how to hook up kenwood ka-994
Check the bellow link for the user manual of kenwood KA-994. In page number 4 of the user manual You can see how to make the connections to the receiver
Manual
Ajin
Mar 09, 2012 | Audio Players & Recorders
Why won't my amps work for the cd player but will work for the radio
You have used the wrong remote wire to signal your amplifier.
swap the blue's around.
You are using the Power Antenna remote - which drops out if another source besides TUNER is selected - so the power antenna goes down.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 01, 2010 | Kenwood KDC-MP528 CD Player
I HAVE A OLDER KENWOOD STACK HOME STEREO SYSTEM WITH OUT MANUALS OR REMOTES AND NEED TO KNOW HOW TO HOOK ALL THE COMPONENTS TOGETHER. KC-206 STEREO CONTROL AMP KT-76 TUNER KX-96W CASSETTE DECK KM-106...
start with the tuner, hook up the equalizer to the tuner, then on the rear of the equilizer hook up all the peripherals except the amps which will go to the tuner outputs and all will feed thru the tuner to the amps and out to the speakers
Oct 23, 2009 | Audio Players & Recorders
Kenwood Tuner Works Through amp, CD & Ipod dont turn on amp
You have the amplifier remote and power antenna remote installed backward. Switch them. The radio drops power to the power antenna when you choose a source other than TUNER... thereby shutting the signal down to the amplifier's remote turn on lead.
See the bottom comment of the tip AT THIS LINK. under NOTES:
Mar 15, 2009 | Kenwood KDC-MP238 CD Player
Kenwood stereo synthesizer tuner t-85l
T-85L is a component of a hifi system not suposed to work alone. You have to connect it to another Kenwood component (an amplifier like the A85 ) through a special cable to power it on/off. The special cable can be used point to point or as daisy-chained.
Nov 05, 2008 | Yamaha HTR-5830 Receiver
Kenwood KDC-2011S display blinks
Download the MANUAL here.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=037b5697f7192f25431654464fa26ba6&q=Kenwood+KDC-2011S
Enjoy!
;) Mak
Aug 22, 2007 | Kenwood KDC-2011S CD Player
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
