Question about Toshiba e-Studio65 Copier
Sharp sf 2540 code F1
Code F1 please help me!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
The F1 error code -- lost communication with the sorter. Are there secondary numbers after the F1?
Check connector cables on sorter and machine, check power to sorter. If those are fine then you are looking at a board problem. Also make sure that all covers are close properly. *** check cover between the sorter and machine*** ( you may have to pull sorter away from machine).
Posted on Jan 24, 2009
My sharp SF-2540 it has a code H5-02
its an error code for the fusing unit
Sep 06, 2016 | Sharp SF 2540 Copier
Sharp 2540 code f2
F2 mean toner not supply .Change toner chip
Jul 12, 2014 | Sharp SF 2540 Copier
After powering on, it will show F2 on the Sharp SF 2540 Copier, So please, I need a programme code to clear it or any other solutions to solve it problem
You need to take it to a Sharp technician to check machine , usually a toner issue that toner is unable to replenish in developer unit and so blows the chip on toner cartridge ,
replacing toner cartridge rarely helps
seeing as it is a deeper issue
Sep 12, 2013 | Sharp SF 2540 Copier
How can I reset the password/ Copying code on SF 2540 copier
codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Aug 08, 2012 | Sharp SF 2540 Copier
I have sharp AR-163 it indicate f5 error. And Sf 2030 error code f2
Ar163 F5 = Copy lamp problem.
Possible causes are:
Blown Copy Lamp
Inverter trouble (copy lamp driver module)
MCU Board failure
This is most likely to be a blown copy lamp.
Ar2030 F2 is a process control error - depending on the sub-code it could be a number of different things. Please repost with the full code.
Hope this helps.
Feb 09, 2011 | Sharp SF 2540 Copier
Error f1
How do you do. You should check join from the main of the charge to device сортера.If connections is checked and where are no mistakes in join no pay attention to mechanical possible damages, findings scrap papers and stranger subject in sorter device. Recall, pr what circumstance appeared the fault.Error code F1 for sharp copiers sf 2020.2030 Sub code 00: Communication error between main board and sorter. Sub code 02: Sorter transport motor drive.
Sep 23, 2009 | Sharp SF 2020 Copier
Sharp sf 2530 hang
I would suggest to throw that old thing in to a pond see if it will float..
Oct 24, 2008 | Sharp SF 2540 Copier
Sharp sf.2540
Press C - interrupt - 0 - interrupt - flash
and then
14 and press start
Feb 26, 2008 | Toshiba e-Studio65 Copier
Sharp sf-2540 copier f1-00 code.
If your machine has a sorter it may be caused by the wiring harness that goes to the sorter from the machine being pinched. Try powering down the machine and unplugging the sorter and powering the machine on. If your problem goes away it is a sorter issue if not it may be a problem in the fuser.
Jan 16, 2008 | Toshiba e-Studio65 Copier
Toshiba e-Studio65 Copier Logo
288 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
