Question about Refrigerators
Oven will not light at all
I held a lighter at pilot for more than 15 min
  • 32 Answers
I could be a number of things.
1. a safety feature signifying a gas leak.
2. a bad thermocoupler.
i recommend calling you gas company to light it [usually free] they will tell you what is wrong.
Posted on Jan 15, 2013
How do I lite the oven pilot
If it's an older model with a true pilot light you turn on the gas at supply line valve, open oven door, remove bottom panel to access pilot and burner. Sometimes it's easier to remove broiler drawer on these models but regardless take a lighter and light pilot. Most models are electronic ignitions which if you have it probably needs replaced if it doesn't ignite the burner in under a minute or minute and 15 secs. It could also be a bad thermostat if the burner ignites within the time period described above
Sep 10, 2014 | Magic Chef Ovens
Where is my pilot light for kenmore 317B6442P001
it shouldnt have a pilot light
there is a hot surface igniter under the pan below the racks
two screws in the back then lift from back (tabs in front)
is the oven not working or lighting?
you cant light with match or lighter
if you are having problems lighting change the igniter
simple to do 15 min get part un piug old plug in new
Nov 18, 2013 | Kenmore Ovens
Amana oven pilot light
If you have a standing pilot and it is not on, you should be smelling gas in the house.
Try lighting it with a BBq lighter directly.
On some stoves, you will have to press a button and hold that button for some time ..over a minute..while you have the light to the middle of the pilot.
Do not proceed to light the pilot until there is no more smell of gas in the oven.
Oct 24, 2013 | Ovens
How do I light a pilot in a gas oven
On a pilot type system you typical hold an ignition source (lighter) to the pilot while holding down the thermostat (push the oven temp knob in) and hold for approx 20 seconds make sure you have the lighter directly on the pilot assemble in oven while you are doing this once it's lite continue to hold for the 20 seconds if you are not sure you are doing it right or if you smell gas vent your house and seek a knowledgable tech
Dec 24, 2011 | Kitchen Ranges
How to light the pilot or the burner on a built in Tappon gas double oven?
Find the gas valve under the stove, First turn off all gas. Let air out 15 minutes, then turn valve to pilot or light, Then light with bbq lighter, Keep pressing in valve for exactly 1 minute, then turn and leave in ON position
Sep 16, 2009 | Ovens
Oven does not work.
Just a guess. There may be something called a thermo-coupler which needs to feel the heat of the pilot light before it will allow the gas to turn on. If it's not working ... no gas.
Jul 08, 2009 | Ovens
How to light the pilot in my RV?
push in on the themostat when the oven is on piolt hold a lighter under the burner and presto also light the stove to get gas flowing first this can take up to fifteen min to light if it has been awile since lit
Jul 19, 2008 | Magic Chef 9512 Electric Single Oven
Gas meter was changed upon relighting,top burners pilots are on but oven not
under each (the) oven behind a panel, is a red button it may be a different color from time. this has to be pushed and held while the pilot light under the oven floor is lit with a match. it has to be held to allow enough heat to activate the thermocouple, which will keep the pilot on. if this does not work there may be an additional problem
Apr 10, 2008 | Garland H283 Gas Kitchen Range
Burners on gas stove work but oven and broiler not working
Most ovens, unless they have an electric igniter (does it go tick tick tick when plugged in and turned on? If so, it has an electic ignition.) have a pilot light. In order to keep gas from flowing out, and to prevent a possible explosion when the pilot light has gotten put out, they have an electric thermocouple on them that shuts off the gas when it gets cold. Plug the cord back in, and relight your pilot light by holding the lighter (I recommend a fireplace match or bbq lighter, not a cigarette lighter to prevent singed knuckle hairs!) over the thermocouple for a couple of minutes.
Nov 19, 2007 | Maytag CWG3100A Gas Single Oven
Tappan Stove 5 burner with Oven
does the pilot seem low?you can remove the pilot then clean it out,let me know.
Nov 10, 2007 | Tappan TGF320 Gas Kitchen Range
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
