Question about GPS
Manual for Navman Tourer 614LM
Can you please let me know where I would get a manual for a sat nav Navman 614LM my email address is dpollit@howarth-timber.co.uk
SOURCE: navman F10 wont function shows sat nav connecting to computer on screen
Try holding down on/off button till screen clears,switch back on and it should be working normally,this worked on mine,it had picture of laptop ,navman usb cable and a red cross,hope this helps.Cheers.
Posted on Jun 19, 2008
  • 5 Answers
SOURCE: photos of tomtom one power on fix
Attached is a sequence of photos on how to get to and change the power control chip - the one that is probably damaged. This is for the Tom Tom I repaired and yours could be different however, there will be a power control chip of some kind (check out the part numbers to see which one it is) and it will be this that is damaged and will need replacing. The Power control chip is the hardest to replace as you cannot get to the 'legs' to solder them. To remove the old one, just apply a large soldering iron bit (with a blob of solder on it to make good thermal contact to the top of the chip) and heat up the whole chip until it is free. Lift it off straight away with tweezers. Clean up the solder pads with solder wick and then apply a SMALL amount of solder paste to each pad. It is improtant that this is a SMALL amount and is equal on all pads so the new chip sits square and true when you put it on. Make sure the chip is in the middle of the pad patern and push it into place. Now for the tricky part....either usa a large soldering iron and heat the chip until it melts the solder paste and drops into place or, use a hot air gun with a small nozzle and do the same thing. Great care needs to be taken to ensure you do not heat up the near by parts so the soldering iron is best but you have to remove it as soon as the chip falls into place. The surface tension of the solder should centre the chip up if it is slightly out but you need to get it possitioned as good as you can before you heat it up. Take care not to move the chip as you heat it. You will need a fine bit in the soldering iron for the diode and any other parts you may need.
You should start with TT1 and work through to TT7.
As well as this chip, if the power supply went high (12 volts) then the zener diode on the input to this chip will also have been destroyed - you should see signs of this just by looking at the device (see photo TT6)
The most difficult bits are: -
Opening the connector to the LCD. This can be done by gently lifting up the PCB to see the connector on the back and then pushing up the 2 ends of the connectors white locking bar. Replacement is also very tricky but with care it can be done. As an alternative, you can remove the LCD complete by gently flexing the plastic surround to it and freeing the display from the case. It is then easy to disconnect and re-connect the LCD to the PCB.
Removing the tin cover from the back of the PCB so that you can get to the power control chip. This takes time and a hot soldering iron with good solder wick to remove the solder. Having liberated a couple of lugs you can remove the others by gently lifting the cover near to a lug and heating that lug to pull it through the PCB. Don't burn your fingers though!
The parts are easy to obtain from either Farnell or RS Components - RS have trade counters you can go to and Farnell have a retail side CPC you can find them at http://cpc.farnell.com/. If you have problems let me know and I will see what I can do.
Posted on Dec 17, 2008
SOURCE: evesham 7211 sat nav
hi therei have problem with navigation car evesham 7211 when i wont use or looking for location it say no gps avilable then i have wait for couple second . please can solve my problem as soon as pooble
thank you .
Posted on May 06, 2009
SOURCE: sat nav
GO TO PREFERENCES ,LOCALIZE , LANGUAGE, UK OR US ENGLISH . EXIT BACK TO LANGUAGE , TAP VOICE , MALE / FEMALE TAP TICK . ALSO INCREASE VOLUME ON SIDE OF NAVMAN + OR -
Posted on Jul 02, 2009
autotherapis
  • 501 Answers
SOURCE: Trying to register a new Garmin sat.nav. So far
Try this link. If you can't just click on it, copy it to your browser line, not a search engine like google.
https://www8.garmin.com/registration/contact_info.jsp?regID=07381817
Posted on Aug 28, 2009
Could i get a copy of instructions for the navman n g60i sat nav
http://www.navman.com/docs/manuals/navman-n-series-manual-en_gb.pdf
Sep 23, 2010 | GPS
I am looking for a user manual/guide for a Navman iCN 320 sat nav. I have downloaded one but it's unreadable.
Look at the below link :-
http://www.retrevo.com/support/Navman-iCN320-GPS-manual/id/466bh842/t/2/
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 31, 2010 | GPS
Instructions for navman F20 sat nav
I bought the same, but managed to download the manual from navman. Try again friend.
Jun 13, 2009 | Navman F20 GPS Receiver
I need a user manual for MYGUIDE 4200
send me your e-mail address to zecemiidelei@yahoo.com and I'll send you the manual (pdf)
May 23, 2009 | MyGuide 3000 Portable Sat Nav Car GPS...
Navman F10 wont function shows sat nav connecting to computer on screen
Jun 10, 2008 | Navman F20 GPS Receiver
Sat nav
May 02, 2008 | Navman F20 GPS Receiver
GPS Logo
54 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
