Question about Maytag MZD2766GES Side by Side Refrigerator
Maytag fridge wont get cold kicks on and off
Wont get cold compressor kicks on and off, relay switch?
  • Maytag Master
  • 4,655 Answers
If your model is the MZD2766GES it would be a good idea to examine the=> 12002794 Relay and Overload Kit
replacing the=> 65889-4 Run Capacitor
will also be recommended. Can yu feel the top of the compressor? Is it hot? I am here if you have questions, Sea Breeze
Posted on Jan 15, 2013
dididsaythat
  • 291 Answers
SOURCE: maytag model RTC17A
how is freeezer side doing? Do u have any frost build up in freezer back wall and is you fan in freezer blowing?
Posted on Sep 02, 2007
  • 90 Answers
SOURCE: (Overload and relay switch)
hey Louie -- I had the same problem -- maytag is a waste of help unless it still is in warrant
you need to replace the overload relay --- the kit cost $26.00
go to appliancezone.com
part # 4387835
email me with any more questions
Posted on Dec 30, 2008
  • 1250 Answers
SOURCE: compressor runs constantly, fridge cools, but not as cold as new
If unit is running constantly, and not nearly as cold as it used to be, most likely a freon leak. Possibly a partially frozen over evap too. If evap is mostly clear except for about 5% of it, most probably a freon leak. Changing controls will probably not fix anything. Need to look into this a little deeper.
Good Luck and hope this gets it done for you.
Posted on May 10, 2009
heatman101
  • 43501 Answers
SOURCE: maytag MSD2758DR side by side, not cooling at all
You can start with replacing the start capacitor and relay to see if the compressor will run again, but you have about a 50 -50 chance that the compressor has gone bad and will need to be replaced....
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Apr 12, 2010
heatman101
  • 43501 Answers
SOURCE: fridge not cooling,compressor wont kick in
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fsdgj
Posted on Sep 29, 2010
Maytag mod#MSD2550VEW00 compressor not kicking on
Could be the thermostat or defrost thermostat.
Oct 03, 2016 | Maytag Refrigerators
Maytag GS2121PADW, fridge running continually, does not switch itself on & off. Could it be the condensor fan motor, as I notic it does not go at all.
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 24, 2011 | Maytag MSD2756G Side by Side Refrigerator
Moved my mds2434ge maytag side by side from one house to another. it was unplugged for maybe a day and half. plugged it back in everything worked fine for about 30 minutes then the compressor stopped and...
NOTE: This
Leo Ponder
Aug 17, 2011 | Maytag MSD2434GE Side by Side Refrigerator
Kelvinator 401 Impression series. Oldie but a goodie until I switched it off for 6 weeks while on holidays. Switched it back on and now fridge area freezing. Tried switching up overnight (8-10) hrs and...
If it runs then that cold control is the problem.
If this doesn't work Do this
That is probably the compressor relay or cold control (Thermostat
The relay is on the compressor and needs replaced
Leo Ponder
Aug 16, 2011 | Kelvinator Refrigerators
Maytag PTB1753GRW Both top and bottom not cold. Compessor starts for a few seconds. Then kicks off. Just lost power a few days ago. Power went on and off several times before power went off for hours. Any...
Hi Nick,
I would plug in a new start relay. The start relay is on the side of the compressor.
If the new relay still will not start the compressor then the compressor has been damage from the power outage.
Aug 03, 2011 | Maytag PTB1753G Top Freezer Refrigerator
Hi, freezer took a dump two days ago, fridge was still fine. Then 12 hours later the fridge dumped out too. The compressor is hot and the relay looking thing with part number nsk 85851 clicks on for 20 sec...
most likely the start device is bad,look at the left wall inside the fridge near the cieling,you should see a model number,call your parts store,give them the model number on the machine,there is other letters after the g and tell them you need a start device.unplug the machine,until you get the part so you don't damage the compressor,it's not cooling anyway and thhe freezer feeds cold air to the fridge side,a fan blows cold air from freezer to fridge so next time if the freezer has a problem the fridge side is gonna have a problem too,unclip the metal clip and slide the start device off,read the instructions and it will tell you how to install the new device
Feb 06, 2011 | Maytag PTB2153G Top Freezer Refrigerator
Fridge not cooling,compressor wont kick in
heatman101
fsdgj
Jun 02, 2009 | Maytag MZD2665HE Stainless Steel Side by...
Maytag has a recall for compressor relay update possible fire hazard stated on notice,tech comes out and does update,now fridge wont cool. tech states that adaptive defrost timer is bad,he jumped wires...
Check the cold control thermostat for continuity.(off/on switch)
When he bypasses the wires at the board ,he also bypasses the thermostat control.
Apr 08, 2009 | Refrigerators
My fridge freezer defrosted n now wont wrk
what you are hearing is the overload kicking in and out. which means bad start relay /bad capacitor/low voltage/bad overload/bad compressor.you can buy a 3in1 to eliminate all but the compressor. and the voltage check them first.
Dec 14, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
After defrosting the freezer the whole fridge doesn't work (is warm!)
sounds like the compressor is locked up or the relay on the compressor is bad. whats happening is its drawing too much current and cutting out from the overlaod relay. that may be a bad compressor or the start relay. both the overload and the relay are under the black box on the front of the compressor. you will need to check the relay to make sure its good, and also the compressor. there should be a wiring diagram on the back that will tell you how many ohms from terminal to terminal on the compressor. hope it helped if its a newer unit the relays are electronic and if you shake it and hear like little sand pebbles in it most likley its bad and thats why it wont run.
Aug 10, 2007 | Danby DCR34 Compact Refrigerator
Maytag MZD2766GES Side by Side Refrigerator Logo
59 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
