We are receving calls from an overseas number constantly, there is nobody on the other end and if we try and call back still getting silence on the other end. Its driving us mad and also blocking out line and could cause us to miss important calls. Does anybody know if there is a way I can block this number calling in? Thanks
SOURCE: how to do check my missed call log
A Panasonic TDx system has 2 types of call logs, one personal for the set, and one for the ICD group.
Pick a spare button, press PROG, the button, and dial 54 STORE.
If you had incoming: 00x on your display, that button will light and you can now press it to see who called. Your Navigator UP/DONW key will step you forward or backward through the log. The LEFT/RIGHT key will display the 4 lines of the display if you're not using a 7636 phone.
If you want to see incoming calls to a particular ICD group, pick another button, and dial 54 plus the ICD group number. For example, I used 100 as my ICD group (now 600 by default). I have 2 buttons, one logs my extension calls, one displays the system calls.
Carl
SOURCE: Clear missed calls message
You can try this, it worked for us.
Press the key that says CID (Caller ID) to view every missed called telephone number. They disappeared, but we had to do each handset. Hope that works for you.
SOURCE: kx-TGA641T how does one unblock blocked number
http://ww2.justanswer.com/uploads/MCVGreg/2009-09-21_023145_KXTG9331-Remove-Blocked.pdf
Viewing/editing/erasing block call
numbers
1 {MENU} -> {#}{2}{1}{7}
2 {V}/{^}: Select the desired item.
~To exit, press {OFF}.
3 Proceed with the desired operation.
■ Erasing a number from blocked list:
{Erase} -> {Yes} -> {OFF}
you can also edit:
■ Editing a number:
{Edit} -> Edit the phone
number. -> {Save} ->{OFF}
SOURCE: I have a Panasonic PNLC 1012 phone system - i want
Thanks for visiting FixYa!
I believe the number you've provided may be the part number to the charging base which the phone sits in. Check to make sure. Panasonic phones that use this base (usually) begin with the letters KX-TG
You may have a KX-TG8521 or a KX-TG8523. Again, please verify the exact phone model you have then re-post a NEW question with the correct phone model. Thanks!
Testimonial: "Yes - will do - thanks for that - when it comes to technology - i really should be in remedial class"
