Sony KDL40X3100 is not getting digital signals but can get analogue
Analogue TV getting full Signal Strength but no Digital Signals are coming through the same Digital Aerial, was working fine then stopped suddenly. Still connects to Bluray player and plays DVD and Blurays with no problems. Just no Digital TV.
SOURCE: digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Posted on Apr 01, 2009
tvtek
  • 1284 Answers
SOURCE: How can I get an analogue signal on my LG3000 32in
According to the manual I looked at, this TV has only one antenna input. This means that analog is available if you let the TV do a full autoprogram of memory. It might take it several minutes to complete, but once its done you should have analog and digital if available. If you were looking for analog channel 5 then you would just enter 5-0 but digital channel 5 would be 5-1.
Posted on Nov 12, 2009
  • 458 Answers
SOURCE: I have just moved house to Reading and previously
You will need to have an outdoor aerial installed, the signal area you're now living in will not be a strong enough reception for an indoor aerial no matter how good or expensive. You could try the indoor aerial in different positions around the room especially by a window to try & pick up some other channels but the long term this will cause some of the programmes to break up or freeze. An aerial on the roof or in the attic will be your best solution to pick up all the digital channels on freeview.
Posted on Nov 15, 2009
SOURCE: LG LCD HDTV 'NO SIGNAL'
To fix the problem, try turning off the TV and unplugging it from the outlet. Once unplugged, push the power button and hold it down for 1 minute. Then turn the TV back on and rescan for channels.
If the problem persists, contact LG customer service immediately as there is a problem with the memory card. The device is unable to retain scanned channels for immediate feedback.
All LG LCD automatically comes with a 1 year manufacturing warranty. You would have to provide proof of purchase to show when it was purchased. Hope this helps. The Guru
LG customer service: http://www.lg.com/us/support/index.jsp
Posted on May 12, 2010
BElectric
  • 1140 Answers
SOURCE: My Sony Bravia television froze
Your TV has a dual tuner - one for analogue and one for digital although they are contained on the same tuner board. It's possible that the digital tuner has failed, in which case the tuner board will most likely need to be replaced, but often this problem can be resolved with a "hard" reset. Turn the TV off and unplug it. Remove all the cables from the back, leave it for at least 5 minutes and then re-connect only the cable from the tuner source. i.e aerial/antenna. Make sure you are in Digital TV mode (DTV), then run the channel scan again.
If it works turn the TV off, re-connect all of your other devices and you should be able to resume using the TV as normal.
If this doesn't work, you may need to have the digital tuner replaced. The analogue and digital channel feeds are from the same source. As the analogue channels are working there is no obvious fault with the feed or cables.
Please try this first and then post back for further assistance if needed.
Regards,
BElectric
Posted on Dec 23, 2010
Want to convert analogue tv to digital
You need a digital converter to receive digital signals on an analogue TV (old type). If you are using an outside antenna you can purchase the box from places like Walmart, Kmart, Radio Shack for around $40. If you have cable TV or Sat (Dish or Direct TV) you need one of their boxes to convert the signal back to analogue. The Walmart type boxes WILL NOT WORK for cable or Sat TV.
Mar 30, 2015 | Refrigerators
Can anyone tell me why all of my BBC digital channels have no signal at night or the early morning, but work again during the day!? thanks
Check the signal strength. If the signal strength is weak, this can happen to digital channels. For analogue channels, the fault due to weak signal will be a grainy picture.
Jul 26, 2014 | Goodmans GTVL32W27HDF 32 in. LCD TV
Have had digital installed and cannot get tv to work through digital. Any advice?
Hello
Thei Orion model Tv is not equipped with a digital tuner inside. There is only an analogue tuner fitted and only analogue channels can be received by this set. To get digital channels, you have to buy one settop box, which can convert digital signals to analogue signals. In short, a Digital to Analogue Converter should be bought, if you want to get digital channels. OK.
Dec 23, 2011 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
The screen says that the signal is weak and shows snow.
Is this a replacement set? Plugged in the same antenna?
Is this the analogue tuner you're using or it's DTV (Digital TV tuner)?
If you're in the USA and Canada there are no analogue transmissions.
You'll find the tuner selection in Menu and a sub menu headed Inputs.
If in the UK some regions have closed down analogue signals already and some are coming up to doing so, concluding with my region, London in June, 2012.
If you're not in these countries you'll get your area's info. by entering 'Digital TV changeover' into Search on your web browser.
Sep 26, 2011 | Televison & Video
How can I get an analogue signal on my LG3000 32in LCD tv? Digital input is fantastic, but no idea how to obtain analogue. Input is connected to a community arial and other residents get analogue with no...
Nov 12, 2009 | LG 32LG30 32 in. LCD HDTV
Loss of Digital Shows??
U have cable's or dish's boxs?unplug,replug the box for the software to down load to upgrade.Unplug,replug the tv.Go to the menu set for Air or Cable then rescan all channels
Oct 26, 2009 | iLO V27DMBX Television
Cannot get good tv signal since ITV and other channels have gone digital in the last 3 weeks. The picture keeps breaking up and the sound goes intermittently.
The transition from analogue TV broadcasting has been painfull in some areas. the only way to get out of this frustration is to buy yourself a digital set top box . This will convert the digital TV signals to analogue form so that your TV can pick them clearly. In any case ,the trend is to have all analogue transmissions phased out altogether
Oct 23, 2009 | Televison & Video
No digital picture on digital TV
Are you getting a snowy picture, If so, you`re still on analogue. If you are on a digital channel with say no signal, you should get a blank screen with either a message saying no signal or a dot on the screen. Ian
Jul 24, 2009 | Sony Televison & Video
TV reception band no longer works
all analogue signals going out means EVERY analogue signal is gone in the TV band. these are now apparently assigned to emergency services in some states.
Jun 14, 2009 | Audio Players & Recorders
Digital Television sound synchronisation
The pixel problem your having is signal strength related, the sound is always affected first. If your on cable, have them come out and check the signal strength first.
May 17, 2009 | Hisense LHD3206US Television
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Electro Med Services...
