Question about Canon NP 6650II Copier
Layar lcd tidak nampak pada canon np 6650 II - Canon NP 6650II Copier
SOURCE: Canon NP 6650 photocopier. Begins to pick up
1)jammed issue.
2)can u try to make copies by using stack bypass or other paper deck see whether u hav the same fault.
3)or flip over your paper and put it in the paper deck again .Fan the paper ,it could be high moisture and static on the paper.
4)clean the paper dust from the pick up unit with damm cloth.
Posted on Sep 06, 2009
goodgold
  • 389 Answers
SOURCE: how to fix eror 000 on canon np 6650 II
This problem take a part? then the fusers lamp is wrong or disconnect. Please, be shore, that the connections of fuser lamp, it's on fusers part of the copiers, is on work?, The second, tes please the thermistor section, if the thermistor dous notwork, the eror 000 will be the same. And then, u mast test the thermo fuze, this own, and all about I told u is situated in fusers part and remooved very easy. Weel, then u test will be finished your copier dous not started, u must push the buttom wich is on ander the back cover in to the right and down place near the controller of DC. Than u push it, u can starting the copier. My email goodgold@inbox.ru Good lark
Posted on Sep 12, 2009
  • 170 Answers
SOURCE: CANON NP 6650 GIVING ERROR CODE E002. ANY IDEAS
check the thermistor or replace that parts
Posted on Jan 14, 2010
SOURCE: mesin menyala tapi tidak kuat bekerja,kemudian
saya pernah mengalami hal seperti itu, biasanya masalah pada voltase listrik yang kurang dari 220Volt. Jadi mesin tidak bisa bekerja secara normal. Apabila voltase listrik normal berarti ada masalah pada power supply mesin sehingga tidak dapat mencukupi daya yang dibutuhkan seluruh komponen.
Posted on Feb 19, 2010
  • 17 Answers
SOURCE: i have canon np 6650
if error E010 occure, it means your Main motor not running,
motor or motor drive board or mother board problem,
if show E010 after running the main motor, check motor driver board or mother board,
but 99.9% case of E010, cause of main motor problem so check the main motor first,
Posted on Aug 11, 2011
Tanda replace cleaning web artinya apa ??
artinya anda harus mengganti cleaning web,
bentuk sparepartnya seperti kain canvas warna putih di gulung,
fungsinya membersihkan pres rool dan hot roll.
tapi biasanya kalau cleaning web habis atau tidak jalan muncul tulisan di layar E0005.
Feb 24, 2013 | Canon NP 6035 Copier
Mesin saya canon np 6650 II, mesin tidak jalan, pada layar monitor tertulis E210 remettre copieur sous tension, bagaimana ?
Mesin saya canon np 6650 II, mesin tidak jalan, pada layar monitor tertulis E000 remettre copieur sous tension, bagaimana ?
Feb 07, 2013 | Canon NP 6650II Copier
Bagaimana mengatasi masalah tampilan Texas Holdem Poker yang sudah terbuka tapi tidak ada yang bisa di klik pada layar tampilan di lobi..
BANTING LAPTOPNYA ATAU PC YG BUAT MAIN POKER..... DIJAMIN SECURITY ALERT SUDAH TIDAK AKAN MUNCUL LAGI PADA LAYAR LAPTOP ATAU PC ANDA..
Apr 24, 2012 | Zynga Texas HoldEm Poker
E020 pada mesin foto copy NP6550
Mesin foto copi canon np 6551 scan atas waktu ngopi berhenti di tengah tidak ada intruksi lain, sudah di cek motor scaner bagus, sensor bagus ?????????
Mar 13, 2012 | Canon NP 6551 Black and White Copier
Gambar tiba-tiba hilang saat tv on?
hallo bagus,
Gambar hilang seperti apa ya?
1. kalau hilang suara ada, coba cek backlight nya dengan cara mengetuk panel .
jika di panel keluar cahaya (ditempat diketuk), itu tandanya backlight masih bagus, masalah berasal dari T-con atau pcb main.
jika diketuk tdk terlihat apapun, backlight rusak. Bisa rusak neon atau pcb inverter nya. klo neon rusak harus ganti 1 panel, tapi klo inverter rusak, bisa beli di service center.
2. kalau gelap dan tidak ada suara ; kemungkinan kerusakan dari power supply.
jika punya pengalaman di elektronika, coba ukur fuse dan kabel ac cord nya.
Semoga berhasil bro.
Mar 23, 2011 | Samsung LN32A330 32 in. LCD TV
Saya mempunyai Sony DCR SR100, problemnya adalah pada layar Lcd hanya keluar warna putih saja tidak ada gambar, padahal LCD flexyble cable sudah diganti tapi masalahnya masih, apakah rusak Lcd Block nya ?
sumber dari permasalahan diatas a.l:
-kabel fleksibelnya tidak menempel dengan baik
-IC power supply LCD sudah bermasalah sehingga tidak mampu menghasilkan gambar pada LCD
kalau masih ada garansi, sebaiknya segera diklaim saja, karena kerusakan pada LCD termasuk jarang
trims
Jan 02, 2011 | Cameras
Mesin saya canon np 6650 II, nesin tidak jalan, pada layar monitor tertulis E001 ! turn the power on again, bagaimana solusinya?
PAGI gan saya mau tanya foto copy saya NP6650 II di monitor ada tulisan nya 002 ! TURN THE POWER ON AGAIN BAGAIMANA SOLUSINYA TRIMA KASIH
Nov 11, 2010 | Canon NP 6650II Copier
Tidak bisa mengirim sms.selalu gagal pengiriman.
masalah anda mgkin disebabkan pembekal rangkaian. Jika anda dapati bar network pada cellphone berada tahap penuh tetapi gagal membuat penghataran sms. ini bermakna pembekal talian yg bermasaalah. cuba hubungi pembekal talian untuk kartu sim anda. tetapi jika bar network yg terdapat pada sebelah kiri pmuka layar, tidak stabil, turun naik..ini mgkin disebabkan cellphone anda bermasalah pada antena pad. klau anda boleh buka cellphone/posel anda, bersihkan permukaan pad berwarna emas bertentangan dengan pin antena, pastikan jugak pin2 tersebut tidak rosak atau patah..klau pin2 tersebut ada kesan tertekan kedalam, tarik keluar pin tersebut supaya ianya bisa menyentuh permukaan pcb. sekiranya ini berlaku, kesan penerimaan siaran pemancar network tidak berfungsi dengan baik. semasa memasang semula ponsel itu, pastikan ianya diketatkan betul2..
Jul 04, 2010 | Nokia 6680 Cellular Phone
Mesin menyala tapi tidak kuat bekerja,kemudian layar touch screen mati
Dec 18, 2009 | Canon NP 6035 Copier
Canon NP 6650II Copier Logo
155 people viewed this question
old marine
old marine
