Can you run 110v from a 115v geni*tools)
Power tools 110v from a 115v out let from geni
  • 242 Answers
I'm a little confused about what 'geni' is.
The outlets in your home are rated at 120v AC and any equipment that you plug into them that state 110v or 115v will work fine.
If you are referring to some type of adapter that you plug into a wall and then into some electronic unit, be careful. It isn't just the voltage that you should be concerned with but the amperage!
Adapters generally take the AC current from a wall outlet and then convert it into DC voltage. This voltage is more or less specific to each device that requires DC input. As a basic rule, you must match the exact VDC and mA from your device with the same values on an adapter.
Posted on Jan 15, 2013
  • Thomas Henfrey
    Thomas Henfrey Jan 16, 2013
    geni is short for genarator? was can you run a 110v from a 115v genarator
  • Chuck Ricks
    Chuck Ricks Jan 16, 2013
    Yes, you can run tools rated at 110v off of a 115v generator.
Old Honda eb1500x is putting out low voltage but engine seems to run fine. Ideas for testing and fix?
Couldn't find anything on that model number other a control box.
Assuming your in the USA output frequency would 60 hertz under load so 65 hertz would be find; although, engine is running close to 3900 rpm when it should be around 3750 rpm unloaded which would be 62.5 hertz. As the output voltage being low it is probably the AVR (automatic voltage regulator) that is the problem.
May 28, 2015 | Honda Electrical Supplies
Burcam 300521 Instant Hot Water Genie 115v
Check: http://www.h2oplus.us/id97.html
Wal-Mart, Sears and others have the pump and can get the by-pass valve. As far as your problem You forgot to tell us!
Nov 07, 2013 | Bur-Cam Burcam 300521 instant hot water...
What is the voltage required to run rival hand mixer?
This plugs into a standard 120v household outlet, it's only 150 watts, running 10 of these is like one hair dryer. Most products say 110v, 115v in the USA.
The actual voltage is around 120v at the breaker panel and around 118v at the outlet.
But all products marked 110v, 115, 117, all work on a standard outlet.
Apr 14, 2013 | Rival 150 Watts MX555-W Hand Mixer
My dewalt drill is 3pin 110v I need to step up to 240v
You cant convert to 240 the plug you have is a 30 amp 115 volt
Nov 07, 2012 | Drills
Power Plug Adapter - Converter - 110V - max. 1550W US/Japanese to Australia
You need a stepdown transformer from 240 volts to 110 volts AC.
Make sure you get one that has the required wattage you require.
Jaycar has a 1000W 240 - 115V Cat. No. MF-1086 for $360.00
**** Smith has a 1000W 240 - 115V Cat. No M1154 for $246.00
If you require a higher wattage, try an electrical wholesaler.
Jan 14, 2012 | Video Game Consoles & Games
I have a 240v drill and need it converted to 110v as I can't use it at work. It is the Hitachi DC 30PC2.
Unfortunately thi sis not really possible internally, you need to purchase step up transformer 110V/115v 220V230V/240V with at least 2A rating, 50Hz/60Hz frequency and at least Watts as are on your drill, that is, I am afraid only solution to your problem. Check prices of the transformers as maybe purchse of new drill will be less expencive.
As you did not stated where you are, I cannot advice more closely where you can find these, for beginning I would suggest chasing one (step-up!) on auction sites and electrical wholesalers, tool dealers.
Aug 18, 2010 | Drills
I HAVE A 115V USA HAIR CLIPPER.LIVE IN UK, SO
Look on the side of the clipper handle. You ahould see what appears to be a screw. With your clipper plugged in and turned on, turn that screw with a screw driver in either direction, the noise you are talking about should quiet down quite a bit,
Aug 21, 2009 | Oster Health & Beauty
RPM/voltage fluctuation on Guardian Primepact 50G
go to www.zabatt.com - look in their Service manuals section - good luck!!
May 28, 2009 | Guardian Rv Generator 4800 Watt, Gasoline,...
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
