Question about Kitchen Ranges
Loss of power to oven clock
I have a problem with a Belling countrychef oven. There is no power to the digital clock. I have traced the circuit to what looks like a thermal cut-out/relay in line with the clock power supply.
Belling can't give me a schematic diagram as it's against ''health and safety''.
    President:
  • 1,214 Answers
Chances are it's the thermal fuse, the the health and safety issue is because the fuse link will only melt if excessive heat was in the area of the fuse. They don't want the user to just replace the fuse as there is a risk of fire if the fuse melted and is just replaced. The cause of the excessive heat needs to be determined.
I had the same problem with a KitchenAid double oven. There was a factory recall on the unit which required replacement of the fan modules, over temp sensors and rerouting of wires.
Posted on Jan 24, 2009
Totally dead no clock or power have checked supply this is ok belling countrychef 100 dat
Belling don't make laptops!
Check the PCBoard has power to the display. If not ask again in Cookers section.
Feb 29, 2016 | Computers & Internet
Hi, I have a belling electric oven and separate grill. The two hobs on the left don't work, the grill doesn't work and the front elements in the oven itself has stopped. Is it fixable? Thanks.
Go to the circuit breaker location on your house and locate the one for the oven. Try flipping it on and off a couple of times. If the breaker only supplies 120 volts the heating elements won't work but the light and clock will. If resetting the circuit breaker fixes the problem, it will happen again, so replace the breaker to do a permanent fix.
Dec 14, 2015 | Belling Ovens
Belling evolution 152 main oven stopped working and clock gone out.
Have you checked the power source to the oven? Has the cord come out of the wall plug? Has a circuit breaker tripped? Once the obvious things are checked and proven good will it be necessary to dig into the interior of the appliance.
Oct 14, 2014 | Ovens
On my countrychef 100g gas range oven lights but when control knob is released it goes out
The heat sensor that detects the flame is not working properly. Consult a qualified Gas Engineer as this is a safety critical item.
Dec 26, 2010 | Belling Microwave Ovens
There is no heat coming out of my fan oven, a Belling Countrychef 100df Range Cooker. The fan comes on and the light goes on to show it is on but there is just no heat ! It is about 7 years old. What is...
If the fan is working o/k, then it is sure to be the oven element that has failed.
This is located at the rear of the oven compartment behind a removeable cover.
Nov 17, 2010 | Ovens
My belling countrychef 100 G oven won't stay lit
There is a good possibility you have a faulty component called a thermocouple, this is heated by the pilot light of your oven and is the most common cause of flame outage.
I would recommend you get a 'Gas Safe' qualified engineer to check it. The thermocouple should be no more than £30.
I hope this helps.
Jul 08, 2009 | Kitchen Ranges
Oven wont work but clock still works
First make sure you didn't trip a breaker. You could have power for the electronics on one side of the 220V and that is why the clock still works. Turn off the breaker and then back on even if it looks on. If it does this again you have a sever problem that will require a service call. If the breaker is tripping it could be other than the oven and if so a new one will work ok unless itsin your wiring.
If this helps you please ratre me accordingly Good luck.
Mar 12, 2009 | Belling XOU252 Electric Single Oven
Kitchen Ranges Logo
273 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
