Question about Stihl Garden
Will a complete engine from a stihl 017 fit into a stihl ms180 chainsaw.
    Sergeant:
  • 322 Answers
You should be able to get the engine to fit. The 017, ms170 and ms180 are all part of the same family.
Posted on Jan 15, 2013
SOURCE: STIHL CHAINSAW MIXTURE SETTINGS
one turn high and low 66 has compesator carby willrun rich up high but will lean under load
Posted on Sep 03, 2008
  • 2692 Answers
SOURCE: 0340 AV stihl chainsaw won't fire
Spray a little starter fluid down the carburator . It is starts then is is a fuel problem. Most likely a gummed up carburator. Remove and clean .
Posted on Jan 24, 2009
Dolfoff
  • 148 Answers
SOURCE: tunning specification for a stihl 028 chainsaw?
I'm not sure there are any "endorsed" tuning specs from Stihl as weather, temperature, fuel quality etc all contribute to engine performance.
Pictures of all types are all over the web.
As for the carb tuning procedure, maybe I can help?
Start with fresh fuel, all filters clean, and bar and chain installed. Also, fill the chain oil tank with bar/chain oil and VERIFY that the chain oiler works properly.
Initial fuel mixture settings (the H and L screws) should be 1.5 - 2 complete revolutions counter clockwise from lightly seated. Sight the carb's throttle plate and adjust idle screw counter clockwise until the plate stops moving.(Throttle closed completely.) Then go back clockwise 3 complete revolutions. This will produce an acceptable startup condition on a HEALTHY saw.
Clamp the bar in a STURDY bench vise and roll the chain with the shank of a screwdriver to verify it is clear. BE SAFE!
Choke the saw and pull the starter rope until the engine "burps".
NOTE: If no burp after 6 pulls, stop! Something is wrong.
After the burp, set choke to half and pull starter until it runs. The settings I gave should produce a slightly rich condition and a slightly high idle. (Chain will be in motion!)
Blip the throttle trigger and idle it down just enough to keep it running during the tune procedure.
Step 1) Using the "L" screw (closest to the engine), turn it clockwise until the engine smooths out or possibly increases RPM. Back it out slightly until the engine has a slight "LOPE" sound to it. (Like a drag car on nitro).
Step 2) Accelerate the engine to full throttle and go to the "H" screw (closest to the air filter) and slowly turn it clockwise and note the RPM increase. There will come a point when the saw will "Top-Out" and loose power. Not even enough power to turn an maintain empty chain's RPM! Go back counter clockwise to the edge of that point, and counter clockwise another fourth (1/4) revolution.
Step 3) Idle the saw back down. Again go to the "L" screw and repeat Step 1.
Step 4) Repeat Step 2.
Step 5) Idle the saw down until the chain stops moving completely. NOTE: Don't settle for a "crawling chain" condition. If the steps above are performed well and all else is healthy, you should be able to idle the engine down to a ridiculously low RPM and it will not shut off.
Hope this helps,
Dolf-
Posted on Oct 13, 2009
SOURCE: stihl 009 chainsaw
http://www.ultimatehandyman.co.uk/manuals/stihl/19.pdf
manual above it is all in there..
Posted on Mar 26, 2010
SOURCE: how to find date of manufacture for stihl chainsaw
call up Stihl USA and ask them when your saw was manufactured. Tell them you bought it used and give them the serial. They told me!
Posted on May 11, 2010
Need sparkplug wire for ms180c chainsaw
Robert, spark plug wire for Stihl MS 180C. Check the attached links, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Ignition Coil Spark Plug Wire Fits Stihl 017 018 Ms170 Ms180...
New Ignition Coil Spark plug wires for Stihl 017 018 MS170 MS180 Chainsaw...
Amazon com IGNITION COIL MODULE FITS STIHL MS170 MS180 017 018 ENGINE...
Jul 30, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
How do i find a repair manuel for stihl ms170 chainsaw
Best Advice I can give you is to contact Stihl directly on their website or 800 number.
Oct 03, 2014 | Stihl 017 018 Ms170 Ms180 Chainsaw Starter...
Model number stihl rollomatic mini user manual
855-456-4299 try this#
http://www.hlsproparts.com/stihl-replacement-parts-s/79.htm?Click=28651&gclid=CNXP0_WbmcQCFQsxaQod1XgAug
Mar 28, 2014 | Stihl 017 018 Ms170 Ms180 Chainsaw Starter...
Magneto specs stihl 170
There is only an ignition module on this saw which should be fitted at a maximum of 0.5mm from the flywheel.
Apr 15, 2013 | Stihl 017 018 Ms170 Ms180 Chainsaw Starter...
Will a stihl chainsaw engine assembly from 017 fit in a ms180
those saws are part of the same family so there should be no problem putting the two together
Jan 10, 2013 | Stihl 017 Crankshaft Assembly W/ Piston...
Starter coil on stihl 017
If you are asking for the part number, it is 1130 400 1302 if you have two ground wires and one lead wire. If you only have one ground wire and one lead wire, the part number is 1130 400 1300.
May 22, 2012 | Stihl 017 018 Ms170 Ms180 Chainsaw Starter...
Stihl brake assembly diagram
Oh man, you shouldn't be monkeying around in there. Bring it to a STIHL dealer and make him let you watch, but don't screw with that again, that's a big safety no-no and another reason why STIHL doesn't sell out to lowes or the home cheapo.
May 15, 2012 | Stihl 017 018 Ms170 Ms180 Chainsaw Starter...
Garden Logo
108 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
