Question about Hitachi 53FDX01B 53" Rear Projection Television
Hitachi, model 57UWX20B ghosting?
My mother in law has an Hitachi, model 57UWX20B, ISSUE: blue , red, & white (ghosting) visable below main picture. Looks almost like the ray gun is being deflected below the actual picture somehow.
In researching this a common theme with the 53inch Hitachi are circuit board problems (loose connections, blown resistors/capitors) is most likely cause. This would make sense since issue started after someone ran into TV.
Questions:
Has any one else experienced same issues with this model/what troubleshooting methods can I use to verify issue?
If issue is board related how difficult is installation of new board? Is this something you can do or does a technician need to be called? Any idea on price of parts (boards) to fix issue?
Thanks in advance
  • Hitachi Master
  • 3,459 Answers
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,PioneerHitachi, model 57UWX20B ghosting? - 2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 18, 2010
My picture is now always a pink to red shade on my
unplug your TV look on the back for a three controls marked red / blue / green "screen" turn / tap on them; watch the screen when you find the "dirty" control clean it with "TV tuner cleaner spray"
Mar 20, 2010 | Hitachi 57UWX20B 57" Rear Projection...
Green bulb-or lamp on ultravision hitachi 57uwx20b does not work how much to replace?
On a projection television you will have to replace all three(red,blue,green) projection guns in a matched set, the reason is if you replace just the green gun, your picture will be over saturated with green light making your picture look green,because the new gun will be alot brighter than the red and blue guns.
With that said, repair will cost approx.$400+, I've heard up to$600. Good luck !
Jan 09, 2010 | Hitachi 53UDX10B 53" Rear Projection...
HITACHI 57UWX20B has blue ghost shadows how do I
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jan 05, 2010 | Hitachi 57UWX20B 57" Rear Projection...
I have a hitachi 57uwx20b that had distorted
If the problem "distorted picture" was red and blue lines everywhere you may have a shorted convergence IC and the set may be in shutdown; someone needs to determine by unsoldering the two convergence IC chips and then trying to turn the set on; if they are unsoldered and the set comes on---one of them is the trouble----also you can look around them at a number of small resistors to see if any are discolored or look burnt--If you need more direct assistance my email address is:
etower.766@netzero.net
The convergence ic chips are usually located on the right side of the set as you look at it from the back on a large finned piece of metal(it is a heat sink to keep them cool).
Aug 11, 2009 | Hitachi Televison & Video
Red and blue ghosting,
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Problem #2
Jul 12, 2009 | LG RU-52SZ51D 52" Rear Projection...
Blue ghosting all over the screen blue ghost all over screen
*Screen Looks 3-D
*Colors wont align
Problem #2
Feb 18, 2009 | Hitachi 57F500 57" Rear Projection...
Hitachi 50" Ultravision too much yellow, not much blue
First of all sorry for delay.
can you provide a image of yello shadow.I believe it seems to be technically say "ghost image"
If it is ghost image we can try by entering SERVICE Menu and adjust RGB level of the light engine.
Good luck
Dals123
Oct 04, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 57UWX20B 57 in.
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 08, 2008 | Hitachi 57UWX20B 57" Rear Projection...
Hitachi 57uwx20b
First of all there is no light engine inside your set. Your model is CRT based. Can you better describe what you mean by the green only working occasionally? What exactly is the picture doing? Also, please confirm that your model is: 57UWX20B.
Thanks,
Dan
Sep 05, 2008 | Hitachi 57UWX20B 57" Rear Projection...
Magnavox model 6P5440
You can turn up the Screen controls in back of set. Look for the focus block that has 6 controls on it. 3 are for the screen and 3 for the focus, in each color Red, Blue, Green. need to turn evenly to keep color balanced. On set turn color all the way down and then get a good black and white picture.
Sep 14, 2007 | Hitachi 57UWX20B 57" Rear Projection...
Hitachi 53FDX01B 53" Rear Projection Television Logo
154 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
