Question about Toshiba Satellite A105-S4004 Notebook
Laoptop batery batery of my toshiba satelite is stop geting charged i don't know how it was working fine yesterday its now working only on Ac power if i pull power cord it gives message battery low its not getting charged more than 3% is theres any setting to stop battery charging even it is fixed in laptop how can i servive battery is not crashed brecause laoptop is working for some time even i pul power cord its only not getting charged please help me regads yogesh sharma
  • 2 more comments
  • yogesh  sharma
    yogesh sharma Jul 11, 2007
    thanks but i got solution of this problem actually that was because of power adapter problem laptop need 15 v power adapter's seting was on 12 v
  • Anonymous Feb 11, 2008
    My laptop is "lenovo 3000 N100 series" . The battery of my laptop is not charging at all. When I checked it, it showed 0% charged. My laptop is working fine with direct supply but as soon as I switch off the supply it switches off. This problem was sudden. There was no problem before two days. I tried to remove the battery and then replace it but it didn't help.
  • Anonymous Mar 28, 2009
    hi...
    My laptop is "toshiba satellite M300".The battery of my laptop is not getting charged when the computer is working.The battery of my laptop is getting charged only when computer shutdown.therefore my laptop is working only with the battery.my laptop is not working with direct supply.
    please anyone help me to solve my problem.thanks
  • emte Mar 28, 2009
    hi...
    My laptop is "toshiba satellite M300".The battery of my laptop is not getting charged when the computer is working.The battery of my laptop is getting charged only when computer shutdown.therefore my laptop is working only with the battery.my laptop is not working with direct supply. Please anyone help me to solve my problem.thanks
    Producer:
    Uploaded 30 video answers.
    Filmmaker:
    Uploaded 5 video answers.
  • 72 Answers
Have you checked the power pin (where the AC cord connects to the computer)?
A poorly designed connector on many laptops is the cause of much grief.
Posted on Apr 01, 2008
  • 57 Answers
Try taking the battery out for 30 secs or so and then replacing it. You'll find a couple of locks on the bottom of the laptop that will release it.
Posted on Jul 10, 2007
SOURCE:
My toshiba Satelite A200 is hang when AC adaptor is insert
Inserting AC adaptor while computer is working on battery power, may indicate that an arcing occurred and cpu got wrong data to stop sequential operation. You may have to turn on AC adaptor, after it has been inserted into your laptop while using battery power.
Feb 08, 2012 | Computers & Internet
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
My laptop won't charge
What do u mean by "adjust the cord" ? If u have to adjust by twisting the jack in the power input port then it is neither the fault of the cord nor the of the battery but may be the fault of the power input port.
Go to Toshiba service center and they will solv the prob.
May 23, 2010 | Toshiba Satellite Pro M300-S1002X Notebook
The laptop is dead.
It does sound like your cmos battery. It is located on your system board. If your confident you can take the laptop apart and get the details from the battery and then goto a pc shop and buy a new one if not take the laptop to the shop and they can replace it for you.
Feb 22, 2010 | Toshiba Satellite M45-S165 Notebook
Toshiba satelite a215-s4747 battery will not charge /replaced battery and still will not charge/ updated bios and still will not charge ?
check the pin on the power cord . try with a different ac adapter . if it is still not chargin maybe the internal pin may be damaged.
Oct 20, 2009 | Computers & Internet
Toshiba satelite black screen
try removing the battery& remove the ac power
Then press and hold the power button in the on position for 10 -15 seconds.
reconnect the ac power only and press the on button ... this should get it to work.
once on again ... reconnect the battery pack
many laptops have a safety device protecting the MB from the capacitors overcharging and this process discharges the capacitors and it should resume as normal
Mar 22, 2009 | Compaq Presario Notebook
Toshiba satelite pro
could be a number of things. a bad solder point for the dc jack on your main board, a fried power supply. or even blown capacitors on the main board. UI would suggest replaceing the ac adapter first. if that doesnt work. you will need to open up the machine and do some testing. I have seen the same problem as a result of a faulty solder point on a dc jack of a toshiba satellite l35a. they use the same jack so could be the same problem. if you want it looked at let me know.
T0X1K66O
Owner,Founder,Head technician
Leading Edge Computers LLC
[email protected]
Apr 29, 2008 | Computers & Internet
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
131 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
