Question about Umi CHUWI V7 Speed 7inch 4:3 IPS Screen Android 4.0 Tablet PC 1GB/16GB HDMI
English manual for Chuwi V17 Micro table PC series manual
English manual please
What is the procedure for installing a new battery in this tablet?
most tablets now don't have the option for consumer to carry out battery change take it to a repair outlet
Sep 03, 2015 | CHUWI V88 Mini 7.9" IPS Screen Android 4.1...
It for my android tablet
You should look up in manual, take note that NOT all tablets have slots for microSD, starting by iPAD
If you don't have a manual, provide your tablet's brand and model and maybe can help you to localise a manual
O do a google search yourself.
May 23, 2015 | Tablets & eReaders
How to transfer pictures from tablet to pc?
use either the micro usb cable you use to charge it as a data cable (so basically your pc will think the tablet is an external hard drive or camera) or save your photo's onto a micro SD hard inside the tablet, then take it out and put it in a card reader attached/connected to the pc....or send all your photos (while online) to a 'cloud' or 'drop box' type account and then download from that account to your PC
Jul 16, 2014 | Hannspree T7 Series 13.3" Wi-Fi Black...
CHUWI V80 Dual Core 8 Inch IPS Screen Android 4.0 Tablet PC 1GB/16GB HDMI
You'll need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
Oct 27, 2013 | Umi CHUWI V80 Dual Core 8 Inch IPS Screen...
English manual for a AMPE A78 tablet
Please send for me user manual ampe a78 in English. frahaas@gmail.com
Apr 10, 2013 | Tablets & eReaders
Do you have a instructions manual for a next7p12
Next book has the manuals available at their page located at nextbookusa.com from there, go to the menu for downloads and select Premium7se or even go with Next6. This selection will list all available downloads for those models.
Nov 26, 2012 | Nextbook Premium Series Next7P12
No carga la bateria
It could be possible that you battery is gone, its not working so you can change it and have a check if its working or not This Table is still in warranty period so you can visit to the show room or that shop from where you brought it. They will help help you out for sure.
If the information helped you out plz give me your marking. Thanks
May 17, 2012 | ZEEPAD Brand 7inch 4gb Android 2.3 Tablet...
I was using my cruz when the screen went black! it was a full battery too but now it wont turn on at all....... need help to fix it b/c i love my reader. is there a place or some trick to get it to turn...
This is a "solution" that has worked for a number of similar problems. Try it at your own risk; if at all possible, contact Velocity for warranty support.
1. Place a towel on a table and put the Micro Cruz face down on the towel. 2. Slide a tiny flat head screwdriver around the edge of the back to remove the paneling. 3. Unplug the battery for 5 seconds, then plug it back in. 4. Boot up your Micro Cruz
This is a common solution to the symptoms you described, but you may find you have a more serious issue due to the fact you were using it and it unexpectedly shut off.
Sep 12, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
I just purchased an cruz reader.. I cannot get the wifi to set up.. neither on our open network at work nor at my mac address secured network at home..... I tried to obtain the mac adddress of the tablet...
The computer has a builtin user guide on situations that encountre as usaeg is in prorgess. Also perform a device compartibility observation, usually notebook computers least displa an foreign meidia.
Feb 10, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
Umi CHUWI V7 Speed 7inch 4:3 IPS Screen Android 4.0 Tablet PC 1GB/16GB HDMI Logo
224 people viewed this question
Top Umi Tablets & eReaders Experts
Are you an Umi Tablet and eReader Expert? Answer questions, earn points and help others
