Question about Microsoft Windows Xp Home Edition English International for PC
Rename task bar
I want to rename start in taskbar?
  • 217 Answers
Here's a link you can follow to rename start in taskbar:
http://libertyboy.free.fr/computing/tips/w_sm_na.php
Posted on Jan 29, 2009
How do I delete an icon from the task bar when it's full but I want to aDD Another?
Deleting is easy, just right click the mouse and select delete.
To replace, you can do the old switcheroony trick. Right Click Properties, and change the URL web address, Click Apply. Then Right Click again and Rename.
Nov 18, 2015 | ASUS Computers & Internet
Desktop and taskbar are being hidden by white screen
First you have to get administrator privileges (if you already do, Ignore this) but when starting up your computer get into recovery mode (Esc then F11, or whatever you have to do in the startup menu). If you have HP support on your computer, click the center panel and go into command prompt cmd prompt you cd to System32 folder on windows 7 (like C:\Windows\System32). you do that, then follow this order very carefully: copy cmd.exe cmd1.exe then rename sethc.exe sethc1.exe then rename cmd1.exe sethc.exe then get out of recovery mode, but typical people have NORMAL COMPUTERS. when you try to recover, hit cancel when asked about system restore. When the error message pops up, click on the details, open the text doc, and click save as. In that window, you browse to C:\Windows\System32 and basically do what you can do in the cmd prompt. copy cmd.exe, rename sethc.exe, then rename cmd.exe's copy to sethc.exe, then reboot normally. trigger sticky keys (hit shift many times) which brings up the command prompt. You can type explorer.exe into it to bring the taskbar up. click on the show desktop button
Dec 08, 2013 | Microsoft Windows XP Home Edition
Oberon media splash screen will not close
To remove Oberon Media splash screen from Inspector Parker installation, go to the file folder where the game was installed (most likely "C:\Program Files (x86)\shockwave.com\Inspector Parker\product") and rename the file titled "Parker.bmp". It doesn't matter what you rename it to, just rename it. That file is the Oberon Media splash screen pic, so renaming it will cause the splash screen to never appear.
Apr 16, 2013 | Oberon Media Video Game Consoles & Games
Task bar at bottom with font size on it has gone
The task bar is an important part of the Windows experience. Not only does it contain a variety of information including what time it is and how much battery life is left it's the way most Windows users open programs and documents. As such, the task bar disappearing is a stressful thing, but fixing this problem on your own is possible.
Auto-Hide Sometimes you may think your task bar has disappeared, but it's really just been set to "auto-hide." Move your mouse to the bottom of the screen and see if it pops up automatically. Then check all four sides of the screen. If the task bar was simply auto-hiding, disable this feature by right-clicking the task bar, clicking "Properties" and unchecking "Auto-hide the Taskbar." b> Reboot b> If your task bar disappears, and auto-hide isn't the culprit, the first thing you should do is reboot your computer this fixes the problems in most instances. Only one problem: because your task bar disappeared you can't access the "Start" menu in order to shut down the computer. Instead press "Alt," "Ctrl," and "Delete" at the same time and press "Restart" in the window that pops up after doing so. Your computer should restart, and in most cases your task bar should come back when it restarts. b> More Options b> If rebooting doesn't fix cause the task bar to reappear, your computer might have a problem starting explorer.exe, the program that displays the task bar and desktop icons in Windows. Press "Ctrl," "Shift," and "Esc" at the same time to bring up the System Manager. Then click "File," followed by "New Task (Run)" and type "explorer.exe" in the dialogue box that pops up. You now have your task bar and desktop icons back. Reboot to see if they stick around after rebooting. If not, repeat the process in the above paragraph. When you have you task bar back click "Start," then "Programs," then "Accessories," then "System Tools" and then "System Restore." Restore the computer to a time when everything was working fine by clicking that date on the calendar. Reboot to see if this fixes the problem. If none of this brought back your task bar permanently it may be time to run a repair install. Change My Task Bar b> In Windows operating systems, the taskbar shows your currently active windows and programs, shortcuts to your favorite programs, the time, your volume control, active programs and the "Start" button. You may want to change the taskbar so it has a different look or to customize it to suit your needs when using your computer. Windows XP users have fewer options than Windows Vista or Windows 7 users, but all operating system owners can make changes to the taskbar.
Right-click in your taskbar. Left-click on "Lock the taskbar" if it is currently checked. Otherwise, click back onto the taskbar. Click on any empty area of the taskbar. Drag the taskbar to the position (bottom, top, left or right side of the screen) you desire, and release it. Re the taskbar by moving your cursor to where the taskbar ends. Your cursor will change to a two-way arrow. Left-click and drag the taskbar until it reaches the you want. Move your cursor over the series of separator bumps between the Start button and the Quick Launch menu, and the Quick Launch menu and the active programs section of the taskbar, to alter the of the Quick Launch menu and the active programs area. Right-click the taskbar, and left-click on "Lock the taskbar" once you've completed the changes you wish to make. b> Change Taskbar Options b> Right-click on the taskbar, and left-click on "Properties." Modify the taskbar settings so that it appears the way you like. You can decide whether to show the Quick Launch menu (a series of icons for your most commonly used programs), to show thumbnails for your active programs in Windows 7 and Windows Vista and to group similar active programs, and to automatically hide the taskbar or to always have it on top of other windows. Click on the "Notification" tab in Windows 7 or Vista to modify the way the notification area to the far right appears. Stay on the taskbar tab in Windows XP. Hide inactive icons, and decide which information to show, including the clock or the volume, power and network icons in Windows 7 and Vista. Click on the "Customize" button to specify which programs or notifications should always show, never show or grow inactive with disuse. Click on the "Toolbars" tab in Windows 7 or Vista to specify which toolbars you wish to see in the taskbar. Your options will vary according to the programs you have installed on your computer but may include the Quick Launch, address bar and links toolbars. Click the "Apply" button, then "OK" once you have made the changes you desire. Hope this helps.
Jan 16, 2013 | Computers & Internet
THE TASK BAR APPEARS AT THE TOP OF THE WINDOW
First, make sure the taskbar is not locked. Right click the taskbar and make sure the is no check mark beside 'Lock the taskbar".
Now, point your cursor just beside the START button (outside the START orb and on the task bar), click and hold and now you can move it to the bottom of the window.
Jul 13, 2010 | Dell Computers & Internet
Fingerprint reader activated and has me locked out after reboot
hi
here are some steps to disable finger print reader..
The easiest way to disable the Microsoft Fingerprint Reader’s default operation is to rename the highest level program file.
To do this, the DPAgnt.exe program must first be terminated.
Step 1: Press Control-Alt-Delete, so the Windows Task Manager comes up.
Step 2: From the Windows Task Manager, click on the “Processes” tab.
Step 3: Find and highlight DPAgnt.exe by clicking on it.
Step 4: Right click on DPAgnt.exe, and click on the “End Process” menu, as seen below.
Next, you have to rename the DPAgnt.exe program so it won’t be loaded at boot up time. The Microsoft Fingerprint Reader’s program and driver files are located in the “C:\Program Files\DigitalPersona\Bin” folder on a Windows XP Home or Pro hard disk.
Step 5: Click on the “My Computer” icon on your desktop.
Step 6: Type into the “Address” bar input area, and enter “c:\Program Files\DigitalPersona\Bin”
and hit return.
Step 7: Single click on DPAgnt.exe
Step 8: Right click on DPAgnt.exe. Then click “Rename” from the popup menu.
Step 9: Change the filename from DPAgnt.exe to DPAgnt-BAK.exe.
i hope you do it....
please rate me
thank you.
Sep 19, 2009 | Sony VAIO VGN-N250E/B Notebook
Task bar is missing on bottom of screen after pc wakes up.
mine does this with windows 7, right click on desktop and open 'personalize' then open 'taskbar and start menu'
From here choose to move your taskbar location to the side of the screen and click apply. it should return, then just tell it to go back to the bottom.
Sep 18, 2009 | Dell Studio XPS 435 PC Desktop
Taskbar
This could be due to a trojan attack and you could overcome this problem by renaming the explorer.exe and the steps are here..
http://www.ehow.com/how_4592369_problem-windows-xp-taskbar-disappears.html
Jul 07, 2009 | Microsoft Windows XP Home Edition
I LOST THE GOOGLE EARTH ICON FROM THE DESKTOP. HOW DO I RESTORE IT??
Hi-
You can click on start and then go to programs, look for google earth icon right click on it and create a shortcut and drag the shortcut from menu bar to desktop, if you want you can rename it when you right click on icon and choose rename.
Thanks for using fixya!
Aug 02, 2008 | Computers & Internet
Microsoft Windows Xp Home Edition English International for PC Logo
52 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
