Question about Acer Aspire 6920-6621 Notebook
How to replace cmos battery on acer aspire 6920 laptop
Can battery be replaced or dose the board have to be changed
  • 13433 Answers
SOURCE: where is the CMOS battery located on Acer Aspire
Bottom of the laptop, the big cover that comes off. Below the wlan card
Posted on Feb 18, 2009
  • 52 Answers
SOURCE: acer aspire 6920 back to factory settings
Acer sent me these instructions.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Posted on Jul 12, 2009
SOURCE: where is the cmos battery for an acer aspire 1690 laptop
Hi I have found you a service manual that should tell ya all. http://rapidshare.com/files/48828906/S.G_AS3010_5010.zip The BIOS in most lappy's are usually soldered I expect this to B the same. (I DL the manual to test link ..)
Posted on Aug 21, 2007
  • 338 Answers
SOURCE: I can't find the cmos battery in my Acer TravelMate 512DX
you have got an older model, try this:
follow the instructions:
you will need:
a slim x-screw-driver
a sharp knife with a slim blade and
a cup or else for the screws, don't loose them!
a new c-mos bios battery model: CR-1220 (exchange it while your in there!)
you find c-mos battery and hdd under the keyboard!
- turn off the power, remove accu and charger cable, for static electricity is friendly fire
to your laptop now !
- open your screen to max. fold (angle of 180 degrees)
- look for removable plastic part near to left holder of screen
- carefully remove it
- also remove plastic panel right to it in the section between display holders
metal should be visible now
- carefully! remove keyboard, starting at the left side, continuing topside
as you won't be able to fully remove it, simply turn it over
- unscrew any screws holding the metal plate, remove it
- now you see: left the CPU plus cooler, top right middle the hdd still in an adapter attached
to the mainboard, at it's lower right the C-MOS battery (g
- turn loos these screws
- carefully remove the frame/adaptor holding the hdd
- unscrew again the adaptor
- seperate hd fram adaptor
... and gotcha!
be careful to get a proper notebook hd (samsung or such)
exchange CMOS-battery by chance
reattach new hd to frame, again carefully!
to reassamble: rewind the procedures
put everything back in place
replug, pray and turn on the lappie.
wish you luck.....
Posted on Jun 13, 2009
Testimonial: "Thanks for all of the information. The keyboard was destroyd during the removal process so we bought a new one instead."
SOURCE: Got new battery for acer aspire 6920. not charging
You ordered the wrong battery, theres two types, your original would have been 11.1v if you check the new one it will be 14.8v. They are not compatable.
Posted on Nov 23, 2009
Does this P.C have an internal battery, and if so can it be changed
If you mean a BIOS or Backup cell, yes, akk OC's have. We cannot comment on how to do it as you don't reveal the make and model.
Aug 06, 2015 | Computers & Internet
How do you replace the cmos battery in an acer aspire #7110-2069?
you will have to open your laptop up todo this,then you will see your cmos battery on the board.
May 31, 2014 | Acer Aspire 7110-2069 Notebook
Replace cmos battery
you will need to open your laptop up todo this.
Apr 21, 2014 | Acer Aspire 6920-6621 Notebook
Where is the battery on the mother board on a acer aspire 6920
LOL, it's there Louis, you just have to take the laptop apart to get to it in most cases. I assume you are talking about the CMOS Battery.
Apr 09, 2012 | Acer Aspire 6920 Notebook PC
I have an acer aspire 6920 which cae with a 11.1v
yes you can. but before watch your lartop mannual. if done thumbs me.
Jan 12, 2010 | Acer Aspire 6920 Notebook PC
I have an acer aspire 6920 the one with nvidia geforce and bluray, lost the battery for it and dont know which replacement to buy the 11.1v or 14.8v??? please help!!!
is there no other information on the laptop that tells you or you can give?
try phoning acer 0906 706 8000 (in the uk) look on their website for technical support outside the uk
Jan 10, 2010 | Acer Aspire 6920 Notebook PC
Acer Aspire 6920 will not turn on. With or with out hard drive inplace. Pushing power button makes the keyboard lights come on but not the computer screen or hard drive. Pulled hard drive and connected to...
I had same problem with my aspire 6920.Tried power reset didn't work. Tried replacing memory chips,No go . Pulled rest of my hair out,still nothing . Then I checked memory chips again and noticed that the inner chip was not seating correctly due to a design flaw in the retainers. Gave both retainers a gental tweak,reset chips. And most importantly Disconnected CMOS Battery and held power button in for 1 min. Plugged everything back in and Bingo... Fired right up >>>And to the comment about plugging in the HD ....Mine fired up with out it ..
Jun 18, 2009 | Acer Aspire 6920 Notebook PC
Aspire 6920 built in crystal clear laptop will not work on msn
remove the driver and reinstal again if is WINDOWS vista.
Jan 14, 2009 | Acer Aspire 6920 Notebook PC
Need master password
Reset passwords by removing the small cmos battery on the motherboard for about 5 seconds, replace & reboot. Hope this helps.
Dec 25, 2008 | Acer Aspire 6920 Notebook PC
Acer Aspire 6920-6621 Notebook Logo
2,505 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
