Question about Tools & Hardware - Others
What is the official name for the pointy end of the anvil?
    New Friend:
  • 152 Answers
The pointy end is called the horn
Posted on Jan 15, 2013
    New Friend:
Bick
Posted on Feb 23, 2013
What is wrong when it pushes the staples into the papers but the staple remains straight through the paper, no folding over to hold
in the foot of the stapler there is an anvil that can to rotated to either turn the ends inwards or outwards
if the small anvil is missing that will be your problem
Feb 25, 2016 | Swingline 39002 Heavy-Duty Stapler
Does the pit go pointy end up or down in water
What kind of oit are you referring to, and for what reason!
If you are looking to root one in water pit tooth picks lightly into it to barely submerge its round/wider end... Pointy end in the air (re: avacado).
Feb 15, 2015 | Cooking
I'm in the market for an anvil and have read about cast iron ones from China. I am tempted to buy once because of the great price. Would you recommend them?
I wouldn't buy a cast iron anvil personally. They tend to be junk. They are brittle and chip very easily and definitely aren't suitable for normal use.
Sep 10, 2013 | Tools & Hardware - Others
What is a jeweler's anvil?
It is a miniature version of a full-size anvil
Fuse replacement
No tools necessary. It's inside the pointy end of this inverter. Turn that metal sprocket right at the pointy end counter-clockwise until it releases. The nib/sprocket releases and the fuse slides out with them.
Aug 20, 2012 | Schumacher XI14 DC to AC Power Inverter
Just change the battery on my Nike Anvil WC0020 watch and the alarm won't sound for the timer as well as the two alarm settings.
If you changed battery yourself, you've lost the tiny spring without noticing it. Carefully check around the place where you changed the battery. The spring itself is very, very tiny, so, be as concentrated as much as you can. That spring (coilspring named by watchmakers) transmits the signal from watch movement to the watch back cover where the sound membrane is located. In case if you find it, open the watch and insert that spring with the bent out end first in to the desired hole in watch movement (should be named COIL SPRING). After that re-assemble watch and the sound should work.
Jun 02, 2011 | Nike Mettle Anvil Super Watch Obsidian...
I had to sell my first copy of Elder Scrolls IV Game of the Year Edition. Now I recently repurchased it but now I can't play the Shvering Isles or the Knights of the Nine Quest Lines. I have already...
Have you loaded Shivering Isles to the hard drive? The Knights of the Nine quest requires you to stay out of Anvil for a few moments. If your game save is in Anvil, leave the town, fast travel to a new town, and talk to any NPC, Attack in Anvil should be a conversation option. Select this and follow to end. Return to Anvil and head for the Chapel, you should hear some guy ranting about the Chapel being attacked and so forth. Talk to him and quest will be started. Shivering Isles pops up the second your game loads as a mysterious door has opened in Niben Bay. Swim to the island and enter the portal.
Oct 19, 2010 | Bethesda Softworks The Elder Scrolls IV:...
My CP 734 has no power under load. Is there a rebuild kit to fix this problem and where can I get it? If a kit is available, is that a difficult rebuild? Tim
I used to repair these impacts for a living. Simplest first thing to do is back off the three 1/8" set screws in the back a couple turns. Pour a little varsol into the air inlet and plug it in. run the gun until your hand is black, (wear a glove). Once the varsol stops disconnect the air, add a few drops of air tool oil and tighten the screws slowly and evenly. You will hear the impact rpm increase. If your gun doesn't speed up to it's original scream you will have to remove the four 5/32" set screws and see what's worn. To open it hold the impact by the nose 3" off the table and position a center punch in the hole of the anvil shank with the same hand and hit it with a hammer hard enough to overtake the spring. The guts should drop on to the table in tact. The guts are in twp parts, the hammering mechanism, and the air motor. The three 1/8" screws hold the motor together. You will soon see the problem. Take the back off the air motor and it will show your if the veins are worn. Cjeck the end plates for wear. You can turn the end plates down on a lathe if available. As a rule of thumb, if the anvil shank is dry buy a repair kit, if it's wet, buy a tune-up kit. If the ring on the anvil shank doesn't turn, buy a repair kit and change your sockets. When rebuilding these front seal often leaks. These impacts are supposed to use 30 weight oil, but a mix of Ingersol Rand grease and 30 weight oil, ( just till it's slightly runny) will stay much longer. Assembling the anvil assembly can be tricky until you figure out how to hold the shank and two pins with the same hand. Good luck.
Dec 04, 2009 | Chicago Pneumatic 1/2" Air Impact Wrench
Install back seat
Someone else had this problem and posted the solution online. I found it while planning to reupholster the drivers seat on my Olds Alero. Hope this helps, i've cut and pasted from wikianswers.... I had the same problem, hence my stumbling across this question this afternoon. i just spent a very frustrating hour working it out! first, to get an idea of how the black clips sit, place them in the rectangular gaps on either side at the front of the seat. the plastic clips sit in the rectangular hole, with the pointy ends facing up. the short one at the front. the short pointy end clips around the front edge of the rectangular hole. the longer pointy end that is now towards the rear of the car is meant to clip onto the wire that sticks out at the front of the seat. there is one on either side of the seat so it is easy to see them line up roughly. the pointy end doesnt clip around the u shaped bit that sticks out, but the striaght bit just behind that. now, if you can understand what i meant. it is time to install. take the plastic clip out of the rectangular hole. clip the long pointy end around the wire on the seat. lower it carefully into place. this is what i found the tricky bit. you can't see, so i lined it up by feel, and lowered it very carefully. then....... after trying many times to put in in place, a finally forced it in with brute stregnth and determination. you have to force it down towards the back of the car to make the clip latch into the rectangular hole. it took me ages to work out the frist one, then the second side only took a minute as i knew what to do. hope this was understandable and will help.
Mar 07, 2009 | 1999 Oldsmobile Alero
Tools & Hardware - Others Logo
100 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
