Question about Water Heaters
Water pressure in PVW50
I have a 9 year old Rheem PVW50. Last year I replaced the drain valve, T&P valve and the anode rod. The old anode rod was worn out. A couple of months ago I noticed the T&P valve was leaking every once in a while. Then it started every day. I read an article that said if the T&P is leaking to open the cold water faucet, if the T&P stops dripping it is not the water heater. But to check it out get a watts gauge with high pressure marker. So I purchased one and found out the cold water was going up to 110 psi and hot water heater up to 150 psi. Found out I need to replace the Watts Pressure Reducting Valve AU25B. After replacing valve cold side is now 50 to 60 psi. However, the hot water heater registers 50 to 60 and when the water is being heated may go up to 100 psi. No water is leaking out of the T&P valve or anywhere else. Putting my ear to the heater I can hear a little grumbling out of the tank but not overly so. So my question is 2 fold. First, is the water pressure of 50 to 100 in the tank ok? Secondly, when is the best time to replace the tank but still get maximum usage out of the water heater? Thanks for your help.
3 Suggested Answers
motor1258
  • 6674 Answers
SOURCE: spent $100 replacing valve on
I'm assuming your talking the pressure relief valve is what's leaking. If plumber says water heater is o.k., then we'll go with that but need to find reason for excess pressure. 2 reasons usually causing that 1) water temperature is getting too hot, or 2) incoming water pressure to tank, is too high.
Have you noticed any difference in those 2 areas such as: water flow at all taps seems to be stronger, even cold taps? Have you payed close attention to hot water temperature, does it seem hotter than usual? If it does, or did seem hotter, have you tried adjusting thermostat on tank down a few degrees to see if that stops the tripping of the pressure relief valve?
Posted on Feb 21, 2011
mc1bean
  • 3053 Answers
SOURCE: I replaced a 15 year old Rheem 40 gallon electric
These are interior metals, similar like rock used in a sauna, to help keep water hot longer. Here is somethings to check out.
Hello, dave
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about hot waterheaters and possibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/water-heater.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 29, 2011
I am looking for a magnesium anode for a Rheem natural gaz water heater PV75
There are two types magnesium anode.
1) Hex-head that screws into separate port on top of tank, and comes either 44" long or 12" sausage links.
2) Combo-anode that connects to Hot water nipple, and comes in solid or combo.
Contact guys at following link to purchase anodes
http://www.waterheaterrescue.com/pages/WHRpages/English/OrderPages/XCart/sales-through-XCart.html
General instructions and types of anodes
http://waterheatertimer.org/Replace-anode-rod.html
Rheem 'preferred parts'
http://waterheatertimer.org/pdf/2011_Rheem-anode-rods.pdf
Purpose of resistorized anode is supposedly so magnesium performs as well as aluminum.
Rheem however had 'resistorized elements' years ago, and that turned out to be promotional gimmick so people would buy rheem-brand products.
Nov 02, 2012 | Protech Rheem/Ruud SP13901B - Anode...
How to how to install the anode rod - for extended warranty - in a new Rheem waterheater?
You are installing a combo anode rod that replaces hot water outlet nipple. This means you will have 2 anode rods, which doubles the anode capacity of tank, which can cause extended life of water heater, assuming that both anodes are inspected each 2-5 years.
Sounds like a heat trap insert is in the way.
Look at parts sheet that comes with product manual.
Pull insert out since it will cause clogs.
Same insert is on cold side nipple.
I want you to contact the Tank forum since they are anode experts:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Tank will recommend magnesium anode and not aluminum.
My understanding is that Rheem water heaters are made so only Rheem brand anodes fit their tanks. While other companies use generic anodes that are sold at any plumbing supply, and also sold at Tank website.
You can configure pipes to make heat traps that save save $2-4 per year on gas water heater operation.
http://waterheatertimer.org/images/Heat-trap-install-900.jpg
http://waterheatertimer.org/How-to-maintain-water-heater.html
Sep 08, 2012 | Water Heaters
I own a house with an electric GE hot water heater. 8ESOT12AA01 Serial # 090122 5750 I do not know how old the hot water heater is and advice about when it should be replaced. No leaks to date but I...
GE is made by Rheem, but the market is always changing. Rheem-based serial number shows tank was made in 1990.
Tank will last as long as anode rod(s) protects steel tank from rusting.
If your tank has two anode rods, then tanks lasts longer.
That's how companies determine if water heater is '6-year' or '12-year.'
I don't have manual for your product to say if you have 12 year tank. Side of tank might have information blurb besides mandatory label that shows serial number.
You can update your water heater by replacing anode rod(s) assuming they can be loosened and removed after this number of years, which is a big IF with old heaters. Your plumber might have impact wrench he uses to see if anode can come out.
http://waterheatertimer.org/Leaking-water-heater.html
If the water heater is making gurgling rumbling and/or crackling sounds then tank has sediment build-up.
You can also get a baseline of rust by flushing tank and watching if water is very rusty.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/Water-heater-will-not-drain.html
If you flush tank regularly, and inspect anode every 1-3 years, a tank will last many years longer than manufacturer's label.
http://waterheatertimer.org/Water-heater-manufacturers.html
Apr 20, 2011 | General Electric Water Heaters
Our 40 gal Rheem gas hot water tank is almost 3 years old. We have a well for water supply and a 2 year old Paterson Iron Remover plus newer water softener. Suddenly 3 weeks ago the hot water developed the...
I would have to go along with your brother on this one. The aluminum anode rod is by far the cheapest way to go. Other options include extensive filtration,ozone treatment and acid treatment.
The aluminum anode rod is much cheaper and I would recommend you change it yearly at least. Good luck and thank you.
Feb 22, 2011 | Rheem Water Heater Anode Rod AP12938
I have the Rheem 47 gal Short Electric Water Heater 82sv502 that is roughly 5 years old. I have been getting the infamous sulpher smell, I have drained it once and now am getting the same problem. Is there...
Use 2 pints of hydrogen peroxide instead of bleach.
1) You need to replace anode rod, and 2) flush water heater with hydrogen peroxide:
Following links have information and instructions for anode rod:
http://www.waterheaterrescue.com/pages/WHRpages/English/Longevity/water-heater-anodes.html
http://www.thisoldhouse.com/toh/video/0,,20047047,00.html
To find anode rod, see if manual shows image.
Some rods are hidden under metal cover of tank.
Some have circular plug located on top of tank.
Some heaters have 2 anode rods > this would be on 12-15-lifetime warranty tanks
Some anode rods are connected to hot or cold water nipples.
Post question on professional plumbing forum with brand and model number:
Look at label on side of tank for valuable information needed to post question.
Add a comment for more free assistance.
Also take advantage of fixya phone service.
For a price, fixya expert speaks to you via phone while you solve the problem.
Jan 01, 2011 | Rheem 47 GAL ELEC SHORT Water Heater 6YR...
I have a Servi-star 40 Gal. electric SN# SS 0496B15258, How old is this unit? Thanks, Jim
http://www.buyerschoiceinspections.com/water-heater-ages
There seem to be 2 possible answers: Servi-star vs Servistar
Answer #1: Servi-star by American
1st 2 digits are year, 2nd 2 digits are week
This means water heater was made year 2004, 96th week ....it seems wrong.
Answer #2: Servistar by Craftmaster
1st 2 digits are month, 2nd 2 digits are year
This would mean your water heater was made 4th month of 1996
Which answer is true? 6 years old or 14 years old
If tank had 12 year warranty and came with 2 anode rods, and you have good water, and no stray current on pipes, then tank can last 14 years.
If tank had 6 year warranty and came with one anode rod, and you have hard water and a water softener, and you never changed anode rod or drained tank, then 6 years is a long life for the tank.
Oct 07, 2010 | Rheem Water Heaters
Annual maintenance for Rheem water heaters calls for removing and checking the anode rod. After some searching I found a 6-point 1-1/16 socket, but I can't turn the anode rod. Applying more leverage...
PROBABLY. THE ANODE PROBABLY FUSED ITSELF TO THE TANK VIA ELECTROLYSIS. I WOULDN'T WORRY ABOUT INSPECTING THE ANODE ROD UNLESS U LIVE IN AN AREA OF HARD WATER AND/OR THE UNIT IS OVER 5 YEARS OLD. DRAINING AND FLUSHING THE WATER HEATER TWICE A YEAR WILL HELP KEEP THE UNIT PERFORMING LONGER. ADDING A WATER HEATER BLANKET WILL HELP LOWER UR UTILITY BILL AS WELL.IF U FEEL U MUST HAVE AN ANODE IN UR TANK, ANY RV DEALER HAVE ANODES FOR A SUBURBAN WATER HEATER THAT U CAN ADAPT AND THREAD INTO THE DRAIN PORT OF UR WATER HEATER.
Dec 06, 2009 | Water Heaters
Cant locate anode rod on rheem gaas water heater
It looks like a plug screwed into the top of the water heater (it IS plugging the hole so turn off water and release pressure b4 removing)
Sep 30, 2009 | Water Heaters
Rheem ap12938 anode rod installation
I suggest replacing the whole water heater instead of just the rod. Usually the water is at the end of its useful life it the rod needs replacing. You will probably need to do that soon anyway. However, if you do replace it and have no head room, you will have to totally disconnect the heater, lay it on its side to do the job. (might as well replace the unit if you are doing all that work.)
Sep 17, 2009 | Rheem Water Heater Anode Rod AP12938
Water Heaters Logo
20 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
