Question about Blanco Plumbing
Leaking Blanco Eye tap. Not dripping, but leaking from pivotal point.
I have a Blanco Eye tap which is leaking from the pivotal point. I phoned Blanco who told me I needed new O rings. When these arrived, I removed the spout, finding the existing O rings in good condition, but changed them anyway. It's still leaking, and Blanco say they don't know why. The tap is two years old. Any suggestions please?
sledge1863
  • 149 Answers
SOURCE: leak at spout pivot point on Kohler K-378 traditional kitchen fau
Not going to stop the leak by tightening. Go to local plumbing or home store and they make a repair kit that has the pieces to fix your problem. Also has a diagram on the back of the kit to guide you, its really an easy fix, shut off water under the sink, both hot and cold,and just remove the handle and unscrewing the top of the valve assembly. Good luck dont forget to rate.
Posted on Mar 30, 2009
Dplumber
  • 119 Answers
SOURCE: I have a Blanco BM5300 "Eye" tap and need to
There are several other methods.
Pop out a screw-cover cap on the end of the top of the handle.
Unscrew the base of the handle.
Unscrew the lever off the handle.
Pop out a small setscrew cover plug on the side of the handle under the lever. Hope this helps.
Posted on Sep 11, 2010
  • 1015 Answers
SOURCE: I have an older American Standard kitchen faucet
If you have a payless cashways in your area they carry americanstd. faucets and plumbing fixtures.I think that some K-Mart and sears stores do also. Hope this helps you. Thanks
Posted on Dec 22, 2010
  • 7 Answers
SOURCE: leaking at base of spout...how do i remove hi arc
there is a tiny grub screw at the back of the spout at low level.
Posted on Mar 01, 2011
  • 10865 Answers
SOURCE: Blanco Eye Kitchen tap cold water is leaking from
Hello doy.. get a can of WD-40 penetrating lubricant and spray it on the seam connecting the lever and the body. It will penetrate within an hour or so. Repeat if necessary.
Also use a plastic head or a rubber head hammer to tap it up.
Joe
Thanks for choosing Fixya!
Posted on Mar 12, 2011
Masport 635 -petrol dripping from tap/valve unit
they mostly screw into the tank so it may be just loose
there is a fiber washer ( carby fiber washer) as a seal normally used
if the tank is plastic check for a crack or rub point where the fuel is leaking from and running to the low point of the tap
Sep 02, 2015 | Garden
Leaking blanco single handle faucet with sprayer
minarl deposit bildup in the handol best to just replace the sprayer any hardwer store hose is still good only sprayer head needs replaced comen threds
Mar 11, 2012 | Blanco Plumbing
Blanco Eye Kitchen tap cold water is leaking from tap[ WHEN TURNED OFF. I have remove the allen screw that secures the the cold lever but I cannot remove the leaver
Joe
Mar 12, 2011 | Blanco Plumbing
My Blanco Torino faucet is leaking under the button when you press the button on top to use the spray.
Check the hose connections at the spray head nozzle it sounds like it is leaking there and running down the hose and ending up under the sink.
Feb 08, 2011 | Blanco Classic Single Handle Faucet with...
Our Blanco Cleo 6100 Cruciform Monobloc tap is dripping & I think it has a ceramic disc valve as opposed to the more common tap washer. Is it possible to replace the ceramic valve & if so...
The tap is a Blanco Cleo BM/6100 tap.
The cost for a pair of valves is £41.51 including postage and VAT, the cost for one is £25.97.
Scott Lindley
Blanco Customer Service Manager
Top Brassware Ltd
T- 01709 819077
F- 01709 798888
E- scott@topbrassware.com
Top Brassware Ltd
Unit 3E Aven Industrial Park
Tickhill Road
Maltby
Rotherham
S66 7QR
Jan 07, 2011 | Microwave Ovens
Oil leak onto garage floor either coming from oil pan gasket or oil filter not sure wich one
Clean the filter and pan with a spray cleaner, run engine for a few miutes.
recheck oil leak.
Probably is rear main seal leaking, very common trouble.
If not leaking much, keep drip pan under car to keep floor clean and drive on.
Most cars do leak after they age a little. The black line in the middle of the road is oil leaking from cars. Very common.
Sep 28, 2010 | Honda Passport Cars & Trucks
I have a Blanco BM5300 "Eye" tap and need to change the cold ceramic washer. I have got a replacement washer but can't see how to remove the tap handle from the old washer which presumably fits over the...
Sep 11, 2010 | Blanco Plumbing
The tap is leaking it appears at the bottom of the tap where it meet the sink it is a hansa single handle with vegatable sprayer with a ceramic cartridge
Hi, there are flexible water pipes that scew into the bottom of the tap, one of these could of come loose; try tightening, or the washer may need replacing.
Hope this helps
Jul 21, 2010 | Blanco Classic Single Handle Faucet with...
Leak from blanco aderlphi tap above sink line may be a washer required
this could be a leaking cartridge or more likely a likely a leaking o-ring that sits around the base and seals the joint between the spout and the base
Jul 01, 2010 | Blanco Plumbing
Water leaking (dripping) into the drum when machine is off. Drip is coming from where water dispenses into the machine to fill the drum.
Hi just read your posting.The fault with your machine is a faulty water valve.1st turn off the cold tap to the machine and leave for a couple of hrs.If the dripping stops you have a faulty cold valve.If the dripping does not stop then turn off the hot tap and that should stop the leak.Either way to fix this fault a water valve must be replaced.Or you can stop the drip by just turning the taps off after the washing has finished.Hope this helps and please reply for further help if needed.
Jun 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Plumbing Logo
164 people viewed this question
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
