Question about Fellowes DS-1 Shredder
I have a Fellowes DS-1 cross cut shredder and I would like to know how to take it apart so that I can attemp to repair it but I can't figure out how you get in to it and i'm supposed to be an engineer!. Can anybody help me please? Thank you
fellowesrep
  • 102 Answers
SOURCE: Fellowes Shredder keeps running
You should be able to flip up the cd cover and visibly see the sensors in the center of the paper entry(look like little LED lightbulbs) Clean with a Q-tip dipped in rubbing alchohol. This should solve your problem. If it doesn't you probally have a burned out sensor. call 1-800-945-4545 to check with customer service.
Posted on Feb 22, 2008
fellowesrep
  • 102 Answers
SOURCE: Fellowes 220c-2 repair manual
call Fellowes Customer Service 1-800-945-4545
SOURCE: Questions on Fellowes Shredder Spare Parts
these guys might be able to help http://wheelermachines.com/fellowes_parts.htm
Posted on Aug 07, 2008
t_vinson57
  • 58 Answers
SOURCE: T7CM Fellowes shredder -- internal parts
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
SOURCE: How to disassemble Fellowes P70CM Shredder
Agreed, there is a seventh screw under the label, as wstrooper suggests. Press along the label and you'll find the tell-tale indentation!
Having taken it apart (a further 4 screws to remove the nylon housing from the base, and another seven to remove the nylon covering for the gears), it has revealas a stripped gear (the one nearest the motor), caused by too many sheets of paper being fed in.
This problem seems to repeat amongst several P70CM owners. Shame the motor doesn't have a cut-out if it hits too great a resistance, rather than strip the gear of its teeth.
Posted on Apr 02, 2009
Yellow light comes on
Look at the manual in the link below. If you do not find the answer, call Fellowes.
Fellowes Shredder Manuals
Sep 18, 2014 | Fellowes FEL-3011001 DS-1 Light-Duty...
What kind of oil should I use on my fellowes dm8c cross cut shredder
Staples Shredder Oil or GBC Shredder Oil usually about $12.00
Jan 15, 2013 | Fellowes DM8C Cross-Cut Shredder
Need the sb-95c plastic spur gear for the Fellowes Powershred. Where Can I get one?
Go to support on the Fellowes website. Enter your model number and you should be able to locate a parts finder. The shredders are rather inexpensive and the repair parts may not be available.
murf427
Aug 03, 2012 | Fellowes SB95C Cross-Cut Shredder
Shredder does not pull paper in anymore, it makes noise, does not shred
Add some paper shredder oil. A shredder needs oil to function properly, oil should be applied every month or more depending on how often you shred. Learn more here: http://hubpages.com/hub/Paper-Shredder-Oil
Jun 13, 2010 | Fellowes DM8C Cross-Cut Shredder
Where can I get new blades?
usually these plastic pieces break from the machine jamming you really should call Fellowes customer service at 1-800-945-4545 and speak with them. They may be able to resolve your problem with a little more information on your unit.
Mar 12, 2008 | Fellowes DM8C Cross-Cut Shredder
Fellowes DM8C Shredder
For user susan10 if you have a Fellowes machine I suggest you call customer service at 1-800-945-4545
For user stevehello check under stickers or any plugs for any hidden screws some shredders are also put together with tabs that need to be pried apart but check for hidden screws first.
Aug 16, 2007 | Winsource Tech Solutions TS-4500 Cross-Cut...
Fellowes DS-1 Shredder Logo
74 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
