Question about Indesit Washing Machines
Machine dosen't stope. Always run
Model no: IWC7125
  • Indesit Master
  • 17,130 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Posted on Jan 15, 2013
In my kia engen fan run always even when i just start viacle and dosen t have power
one fan should run only when its hot or the AC is on.
sometimes, the fan will run a little after you shut off the engine to cool the system off.
Dec 11, 2012 | 2001 Kia Sportage
Air conditioning won't blow air
sounds like your feeling air flow from motion your blower dosen't sound like its coming on try when you are sitting still with car running turnibg on the blower if it dosen't come on it could be anything from a bad fuse to a bad blower motor
Jul 07, 2012 | 2003 Buick Rendezvous
Ice maker water dosen't work
HI CHECK WATER SUPPLY FIRST.WELL ICE MACHINE FIRST.ITS ON RIGHT?LEAVER DOWN?IF ALL GOOD CHECK VALVE.GOOD LUCK.ALI
Jun 25, 2012 | kenmore.com
My Tv screen dosen't fill the whole srceen
Just on a movie or even watching tv???? If you have the original remote, usually there is a ratio button on it you can push......If theres not, go into the menu and go under video and look for the different ratio (size) of the picture and try one of them......If you still can't figure it out and dont have your manual, you can always "google" your tv and model number and download or at least look at the manual online.....good luck....
Apr 13, 2012 | Televison & Video
My mastermind 708 dosen't spin after wash cycle.It spins fine in the wash cycle but dosen't drain water or spin in the spin cycle.Pease help
Your empty pump filter is blocked with debris. If it can't evacuate all the water then it wont allow the spin cycle to start. Locate the filter (probably behind a little door at the botton of the front of the machine). Remove, clean and remove the debris, re-fit and all will be well
Jul 01, 2011 | Westinghouse Washing Machines
Chevy 2004 blazer ac stoped working abruptly and stops the engine if you turn on the ac could you just replace the clutch if that is what is defective? instead of the whole compressor and all the other...
I mworking on my blazer AC unit now . You have a problem with the compressor clutch or the compresser Its likely the clutch its supposed to cycle about 8 times per minute . So it goes on then off 8 times per munite this is normal . However if the clutch dosen't spin then the belt will drag on the clutch pulley this will stall the engine until the belt wares out but this will damage every part that the belt rides on . The water pump the alternator powersteering pump and belt tenisinor not to mention the belt .It sounds like your clutch is seized try not to run it until you can figure out why the clutch isn't spining
Jun 12, 2011 | 2004 Chevrolet Blazer
My Hoover washing machine 2305l sometimes dosen't
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 10, 2011 | Hoover HTC243 Top Load Washer
Washing Machines Logo
16 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
