Question about Dishwashers
Monarch midi meter water softener salt tank is filling up
Have had softener 9 years the salt tank fills to top but has not overflowed yet also the round small water pot on top never empty,s
  • 641 Answers
SOURCE: LG LD-2160 dishwasher
Get an aqua vac and suck out the water (with the dissolved detergent)from the salt container. Refill it with water and repeat the process couple of times. Fill the container with water and salt and it should be fine. Good luck !!
Posted on Jun 28, 2006
jaylex
  • 417 Answers
SOURCE: dishwasher and salt
run a few times with nothing in the machine on full washes it may be that the salt you are using is not suitable for that machine also check that you have the machine plumbed into the hot water outlet.
Thanks J
Posted on Feb 16, 2008
  • 1314 Answers
SOURCE: Neff dishwasher water filling
there is a safety float in there to shut the water off most look like domes under the float is a safety switch take off the bottom kick and see if the float is on the switch if it is check to make sure the switch is good
Posted on Feb 18, 2008
  • 58 Answers
SOURCE: DD603 2 Drawer Flashing Fill Warning
poss water valve b4 i would consider a control
Posted on Mar 12, 2008
SOURCE: hotpoint fdw85 dishwasher error code al10
Hi we've got the fdw80 and AL10 is the heating element. Ours goes wrong every couple of months luckyly we've got extended warranty till 2011. They wont replace machine as fixable so they will be coinng out every 2 months for the next 3 years.
Hope this helps
Posted on May 12, 2008
Water Softener is 1 month old. Salt water up to the 4 mark after recharge cycle. How much brine (volume, please) is supposed to be drawn out of the salt tank upon recharging?
it depends on the concentration you have set in the controls if you set it to a high percentage ( hard water) it will draw out about 40 lirs of salt water
That is to say , if you have the reservoir filled to the overflow hole before , then it will empty the reservoir and may require you to fill it so that it keeps sucking until it finishes the setting time
there will be volumes setting in the user hand book that you adjust to for the hardness of the water
Feb 01, 2016 | Kenmore Ultra High-Efficiency Water...
Why doesn't my water softener have water in it.
The tank is not *filled* with water - it is filled with salt. There is some water in the tank - as long as you are using salt, the brine tank is working. Have a look at this video below:
Jun 10, 2015 | Washing Machines
How do I reset salt level
On the left hand side should be button marked salt level, after adding product,on side of brine tank are numbers in yellow telling you the level,push salt level button to the number shown on side of brine tank. Note: do not fill over brine tank, I suggest to fill to level 6 or 7..
Oct 31, 2014 | Kenmore Ultra High-Efficiency Water...
Culligan water softener manual
You are likely using a rock salt and what you are seeing is a build up of dirt and fine sand because rock salt isn't clean... it's got rocks in it. Clean your tank out and rinse it thoroughly with a hose. Be sure to clean out your 3" tube (brine well) and under the salt platform if you have one. Start with a clean salt like System Saver II or Crystal Plus. Never fill your salt tank over half full. Always let your salt be used down to the water level. IF the salt at the water level is soft and pasty don't add more; tip the salt tank until the salt is raised along one side or corner to above the water level when you stand the tank up carefully. This will allow all the water in the tank to become brine (saturated solution).
IF you are using potassium instead of salt, the brown is a natural component. Don't worry about it although it never hurts to clean your brine tank yearly.
Aug 04, 2014 | Water Dispensing & Filtration
Waterboss 93000 water softener
It most likely is due to a plugged eductor/injector assembly which pulls the salt brine out of the tank to regenerate softener. If it is plugged no brine will be pulled from salt tank during regen but it will keep filling the salt tank and eventually overflow with each cycle. Or there could be a leak in the valve causing the tank to overflow.
Here is the owners manual for your model.
http://www.waterboss.com/media/WB_Softener_V1_Manual.pdf
See page 23
RJ
May 05, 2014 | Water Dispensing & Filtration
Harveys water softener leaking
Actually it is regenerating if it is filling the salt tank with water. It is just not drawing out the water/brine during the brining cycle. Check the eductor assembly it is most likely plugged with iron or debris. Clean thoroughly and manually cycle unit to brine draw. Usually second cycle, until the water level is back to normal then do a manual regeneration from beginning. Then regen 3 consecutive days.
Feb 05, 2014 | Reliance Water Dispensing & Filtration
Water softener fills up with water
If you are referring to the salt tank filling with water, then the problem is the eductor assembly. This is where the brine is drawn from the salt tank. If it is plugged no brine or very little brine will be drawn during regeneration. You will need to clean the eductor assembly and manually regenerate the softener to regain softened water.
What model softener is it? It would help to bail most of the water out of the salt tank. How much depends on the model.
RJH2O
Jan 26, 2013 | Measuring Tools & Sensors
My water softener emptied im not sure how long it was empty for but I dont think it was too long I filled it with salt and now it doesnt work. It still regenerates but im getting hard water still any...
Do you mean the salt tank was empty? If so fill salt tank half way wait about 6 hrs for brine to develop. Manually regenerate softener 2x within 24 hrs. When the salt runs out the resin becomes saturated with hardness minerals. It takes at least 2 regeneration cycles back to back to completely restore soft water. Also the hot water will take some time to get soft. It will help to flush water heater after cold water is consistently soft.
I hope this helps,
h2oservices
Feb 26, 2011 | Culligan Compatible S7011C RS23SED5...
The water softner is now filling up with water also the is water in the the overflow its sits in
The softener is not drawing brine during the regeneration cycle. The eductor assembly may be plugged or you may have a bad seal internally. It will keep filling the salt tank if the float assembly is not working properly also causing the salt tank to overflow.
RJ
Dec 28, 2010 | Culligan Under Sink Water Filter
Salt indicator light comes on?
Check the instructions which are freely available from www.miele.co.uk or the relevant site for your country. Browse to the current models and you should find the PDF for your model. For non-current models, instructions are under the link "Customer Support".
In general, the instructions are as follows:
If the water in your area is very soft and constantly lower than 0.7 mmol/l (4 °d) you do not need to add dishwasher salt. The water softener must, however, still be programmed to correspond to the water hardness level in your area. (The salt indicator light will still come on, but should be ignored).
Important: Before filling the salt reservoir with dishwasher salt for the first time, you must fill it with approx. 2 litres of water to enable the salt to dissolve. Once the dishwasher has been used, there is always sufficient water in the reservoir.
Inadvertently filling the salt reservoir with powder or liquid dishwasher detergent always leads to serious damage to the water softener. Make sure you have picked up the correct packet of dishwasher salt before filling the salt reservoir!
Only use special coarse grained dishwasher salt for reactivation. Do not use other salts such as cooking salt, agricultural grade or gritting salt. These may contain insoluble additives which can impair the functioning of the water softener.
To refill:
* Remove the lower basket and unscrew the salt reservoir cap.
* Fill the reservoir with approx. 2 litres of water (first use).
* Place the funnel provided over the salt reservoir and carefully fill with salt until the reservoir is full. The salt reservoir holds approx. 2 kg of salt depending on the brand used.
As the salt reservoir is filled, displaced water will overflow.
* Clean any excess salt from around the reservoir opening and then screw the cap on again firmly.
* Run the "Pre-wash" programme immediately to remove any traces of salt water from the cabinet.
For the Miele, the salt reservoir is usually under the bottom basket, the cap is usually grey in colour. [Only the latest models have the refill cap in the door itself].
You should be able to find dishwasher salt just about anywhere, I've even found it in Malaysia, sold at good ol' Tesco!! Brands of salt include Calgonit (Finish) & Somat.
Jan 05, 2008 | Miele 24 in. Novotronic G641 Plus Built-In...
Dishwashers Logo
204 people viewed this question
Top Dishwashers Experts
