Question about Kenwood Chef A901 901p 907 Quality Motor Repair Kit, With Free Brushes & Guide
To change bruses in a kenwood chef a901 - Kenwood Chef A901 901p 907 Quality Motor Repair Kit, With Free Brushes & Guide
  • mudiford
    mudiford Jan 17, 2013
    great thanks ,so helpful
Kenwood chef A901 thermal switch
eBay has lots. Take the details off the old one.
http://www.ebay.com/bhp/thermal-switch
Or here
http://www.allelectronics.com/make-a-store/category/765/thermal-fuses-breakers-switches/1.html
Apr 22, 2016 | Kenwood Chef A901 901p 907 Quality Motor...
Replaced Capacitor and resistors motor running fine but cant keep the belt on keeps running off should rotation be clock or anti clock
Generally speaking, belt tracking issues are usually due to one or more of the shafts that support the pulleys not being perpendicular to each other - this applies to everything from treadmills to fan belts. Check and correct if possible: that the motor is securely mounted in the housing and that it is not installed crooked; and that the shafts aren't loose or have sloppy side to side movement. Belts should be tight - but not overly so.
Jul 22, 2015 | Kenwood Chef A901 901p 907 Quality Motor...
Want a seal for kenwood blender model bl300
That kenwood is a UK model so if your in the US it's tough to source. The ring you need should have an outside diameter of 76 mm and an inside diamete of 56 mm.
This is a uk ebay link with the exact part.
1 Kenwood BL300 Blender Liquidiser Rubber Seal Gasket
This is a us amazon link with something that might work but not exact. There is a uk amazon equivalent if that works better for you.
Amazon com kenwood blender seal
Feb 18, 2015 | Kenwood Blenders
Where can I find a manual for the A901 food mixer
Check with eBay, or Amazon, or try looking it up on the internet, and purchase one from Kenwood merchandise sales. Your box should have the information to request a manual, or a phone number to call to get one shipped.
Jul 26, 2014 | Kenwood Chef A901 901p 907 Quality Motor...
I have kenwood multi pro500watt i lost manual book how get i one
You should be able to get one from Kenwood at http://www.kenwoodworld.com/en-za/customer-support - you will need the model number. Or go to http://www.manualslib.com/brand/kenwood/ where they seem to have them for KMC500 models (scroll down to food processors). Good luck!
Jul 06, 2014 | Kenwood Fp580 Compact Multi-pro 500w Food...
How do you put water in the magic chef model number mcim22sv portable icemaker?
Remove ice bucket and add water to fill line at the back of the water tank
Jan 17, 2013 | Magic Chef Portable Ice Maker
Kenwood Chef A901 901p 907 Quality Motor Repair Kit, With Free Brushes & Guide Logo
128 people viewed this question
Top Kenwood Blenders Experts
Ross Keen
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve
Are you a Kenwood Blender Expert? Answer questions, earn points and help others
