Plesae guide me as to how i can down load apps and game onto A1219 using my laptop having dongle for net
SOURCE: problems transfering apps from iphone to Ipade
You are able to use any appstore app with the iPad. Make sure your iPad is listed as a connected device in the left side bar of iTunes. Check your sync settings to make sure they're set to sync with your iPad and if needed restore your iPad using the restore button and try to sync again.
To make an application fullscreeen tap the small "2x" button in the bottom corner of your iPad. This will upscale the app to fullscreen.
Hope this helps, if you found this helpful please leave some feedback. Thanks.
SOURCE: I had bought an ipad
there were some random wifi issues with ipads early on but the most recent updates through itunes have corrected those. So best thing would be to connect to your computer and make sure its updated. if that doesn't work, may be a range issue, they dont have the longest reception.
SOURCE: Why does my new iPad get so hot when I play games on it?
Hi Jessica,
Much to your chagrin I bet, there's not too many options besides "play it less" if you want to cool your new iPad down. If the heat is an issue for you now it is probably going to continue to be an issue for you later.
Having said that, there are a couple ways I have used that seems to cool down the iPad by a few degrees:
I hope that helps you out!
SOURCE: How do I cool down the iPad 3?
Hi datsyukiandeke,
Here are a few pointers I have for you when gaming on the new iPad:
To disable guided access try the following:
Triple-click the Home button and enter the passcode chosen during setup of Guided Access to unlock the device
You'll now be back to the usual behavior of iOS.
If you'd like to turn off Guided Access completely, just go back to Settings > Accessibility > Guided Access > and flip the setting to OFF. You'll need to enter the passcode again to do so.
