I have a sony kp fr43m91 tv and i noticed dat when i put it on the sound comes up but there is no picture. then suddenly it goes off and the red light starts blinking continuosly. i don't know what to do.
  • 119 Answers
SOURCE: Sony KP-51HW40 No Picture, only sound
how many thimes does the light blink, it's an indication as to where you should start looking for the cause of the problem
Posted on Dec 21, 2006
welcomejee
  • 10594 Answers
SOURCE: sony projecting tv kp-57wv700
Based on service manual info, it cant blinks 7 times as per symptoms, please count again blinks. It can be 5 times.
If its 7 times blink, Horizontal Deflection stopped in this case. If you want to repair it at your own, please let me know to guide you further but it is necessary you should have knowledge of electronics.
Posted on Aug 18, 2008
shbuckler
  • 126 Answers
SOURCE: sony wega kp51 turns on for 3 secs than off w/ blinking red light
The flashes are fault codes. It means your system is faulty. If it is intermittent then it is more than likely a dust issue. Buy an air duster, spray out the back and restart. Should be fine
If it continues to play up then it will be a repair job
Posted on Dec 24, 2008
SOURCE: sony kp-53HS10 blinks 5 times then picture goes off, sound ok.
I had the same problem. My TV had been fading for months. When I first turned it on, it would be fuzzy and out of focus, plus the colours would be off, but after it warmed up it looked fine.
Then the other day it started turning off after a few minutes and the standby light would blink 5 times over and over.
I tried following the instruction given in the previous answer, with the following differences;
The front speaker cover did not have any screws at the bottom corners, instead it just popped out.
I just pulled at the sides gently untill it came away.
Next, I had to remove the 4 screw holding the control panel in the center, then pull the control panel out as far as it would come.
Next remove the 4 screws from the 1' x 2' wood cover that was behind the control panel.
This will expose the insides and you can see the 3 tubes and the panel on the right that contains the 6 adjustment pots. The pots were not labled, but I took a guess and got it right.
The ones to adjust are the top 3 (the bottom 3 must be focus)
It took me a while to get it right. be careful not to turn them too far clockwise as when I did it started crackling and I though I had fried something, but I guess I was ok.
I was having trouble getting the right balance, so I turned them all anticlockwise first, then turned each one clockwise till I saw color and then backed them off untill I got a black screen and could see the channel display.
When I finish adjusting them all, I turned the TV off for a few minutes, then back on and left it on for 15 minutes. the blinking did not come back.
I then plugged it back into my satalite reciever and got an awesom picture. Much better then before.
Now when I turn on the TV it has a great picture right away. I'm hoping it will stay this way.
My wife was dissapointed, she was hoping it was toast so we could get a plasma :)
I guess you can't please everyone.
thanks for the help and good luck if you are trying this.
WARNING, there are very high voltages inside the TV, be very carefull not to touch anything.
I used a long insultated screwdriver to adjust the pots.
Posted on Apr 30, 2009
Wise Frog
  • 13 Answers
SOURCE: Sony wide screen projection tv model kp-57wv600.
I found this solution from SONY's website.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
I hope this helps.
Posted on Aug 05, 2009
Sony kp-fr43m91 red light blinking 10 times
Below is detail of error and which component are faulty.
ax87hipnucw3aaaaaelftksuqmcc
Chassis location of Transistor and Resistor are given in table.
regards.
Nov 23, 2010 | Sony Televison & Video
TV works fine for about 3 minutes then the picture goes black and the red light on the front of the TV starts blinking. The sound works the entire time. If I shutdown the TV and wait a few minutes and...
The light is blinking a code. The code will be a series of blinks, a pause and the blinks again. Phone Sony service and give them this code. They will be able to advise you as to the problem.
Apr 03, 2010 | Sony KP-53HS30 53" Rear Projection...
On our Sony KP-51WS510 projector television (with HD cable box) when we turn it on the screen goes green and the turns the cable box off and goes blank. Also I noticed the light on the front of the...
when it goes green, your green picture tube is shorting out, replaceing the green tube costs alot of money. these sony's had alot of bad tubes, the red and blue are probably going out too, it will cost alot to fix this, at least $500 even if you find good used picture tubes to put in it.
Sep 19, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony kp-61hs10 tv, has sound but picture goes black after 3 min.
I just had the same problem. If your lucky it might be a free 5 minute fix. The five light flashes mean impropper current. I took the front grill off, then behind that is another black cover, I took that off and noticed the circuit boards COVERED in dust. I then took an air can duster and blew off all the dust... works like new. No more flashes and in an out picture. The collection of dust was interfereing with the electrical current.
Ben
Apr 15, 2009 | Sony KP-61HS10 61" Rear Projection...
Sony KP 57WV600
how many times does it blink?
Mar 26, 2008 | Sony KP-57WV600 57" Rear Projection...
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-53HS10
I've had my T.V for about 5 years, and the other day the screen just died and I have no audio, but the when I plug it in the red light in the front flashes, have any idea on what to do.
Nov 21, 2007 | Sony KP-53HS10 TV
SONY KP-57HW40
you are experiencing one or more of three things
1.the crt itself is damaged
2. the vertical ic on blue crt board is bad
3. the focus block is bad
if you hire a sony authorized technician they should be well aware of this problem.
Oct 22, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-51HW40
I had the same problem with mine 2 years ago (TV was 1.5 years old at that time) I had extended warranty on TV and it was fixed by Sony at no cost to me. Now yesterday I have another problem with it. All of a sudden screen went BLUE. No Sound either. It could be the CRT (That's what I read here) Out of luck this time. Will call local Repair shop (70 miles away) and see how much it will cost to fix it. Good luck.
May 31, 2007 | Sony KP-51HW40 51" Rear Projection...
to thus problem its very simple .! try to resolder at the back of the picture tube board.
Nov 26, 2006 | Sony KP-53V75 53" Rear Projection...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
