Question about MSI 661FM3-V Motherboard
Bios update 686 AMI BIOS 1999 cF71 - MSI 661FM3-V Motherboard
  • 21 Answers
SOURCE: Issues in Upgrading BIOS
Actually, your motherboard is a GA-7ZMMH, which we were lucky enough to see in the BIOS ID string. You can find the latest BIOS's from Gigabyte's website at: http://www.giga-byte.com/Support/Motherboard/BIOS_Model.aspx?ProductID=1315 It looks like you're on the F5 rev. I would suggest the F10 rev, and only go to the F11b rev if you need the support for the Athlon XP 2600+. If you are not upgrading your BIOS for CPU support, or you do not need to support a CPU faster than the Athlon XP 2200+, then go with the F10 rev.
Posted on Oct 02, 2007
MysteryFCM
  • 187 Answers
SOURCE: motherboard doesn't accept WD 40 gig on.
When you say "the system didn't work with that", do you mean it didn't identify the drive? When you go into the BIOS setup, are the drives displayed, or are they shown as "Auto"? Did you correctly change the WD drives jumper to Master, and the old drive, to Slave?
Posted on May 25, 2008
  • 94 Answers
SOURCE: KT4V MS-6712 VER:1.0 AMI BIOS beeps (2 very short,
CHECK MEMORY CARD ( RAM), MAYBE ITS GONE..., TRY TO REPLACE WITH ANOTHER MEMORY CARD
Posted on Jun 28, 2009
jim4984
  • 797 Answers
SOURCE: Bad bios flash, backup gives bad checksum error.
Is the mother board working? If so, why are you flashing the bios? If the bios is bad and can not be flashed, you may be able to buy a pre-flashed chip if it uses a removable flash chip. Try this site but you can find others on the Internet.
Posted on Mar 24, 2010
  • 119 Answers
SOURCE: BIOS update on MSI KT6 Delta (MS-6590 v2 5.0)
You should be able to get it from here.
http://www.motherboard.cz/driver/msi.htm
Posted on Apr 26, 2010
Soyo Tech aid response 2A: "different BUSes" on 1999 AMI Bios on ECS P4800 Pro-M VI.0A pc motherboard.Won't boot but stops. How to fix?
Visit http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=574&LanID=9
and compare that is your BIOS updated ? If not, I suggest first update your BIOS to the latest version and see if error is removed ? Try Load Optimal Settings of BIOS. If fail, then try resetting the BIOS. If you have install anything new, try to boot by removing the new device. I suggest from the above URL, you can download the manual of the mother board. I hope trying these steps will remove your problem.
Feb 11, 2016 | Intel PENTIUM-4 FSB800 Mother Board with...
Ami bios 686
YOU HAVE TO WRITE WHAT KIND OF ERROR.
Feb 02, 2014 | Computers & Internet
Just got a brand new gigabyte motherboard,when i shutdown the pc it wont reboot. when the power switch is pressed nothing happens no fans,led, nothing. the board is a ga-990fxa-ud3,cpu- amd phenomII...
Hi Orville,
Your problem is all about your motherboard you need to updated to BIOS firmware to solve your problem.
Go to the gigabyte website then go to your motherboard page and download and updated to the latest firmware for your bios.
Steps in flashing BIOS
How to Reflash Motherboard BIOS About updating BIOS... The whole BIOS updating procedure should be treated with extreme caution. If you do not encounter any system instability or bugs with the current BIOS version, we suggest that you keep it. If you determine to flash BIOS, you are taking a personal risk of BIOS flash failure. Please contact your supplier or our distributors/resellers for further remedy in case system crashes unfortunately because of BIOS flash failure. Before you begin... 1. Please make sure the BIOS version you want to flash matches your motherboard model. 2. If your BIOS is flash protected, please do not enable BIOS Flash Protection under Advanced CMOS Setup (AMI BIOS) or Advanced BIOS Features (AWARD BIOS) in BIOS menu. 3. Never interrupt when you BIOS is being updated. 4. Because BIOS flashing is potentially risky, if you do not encounter problems using the current version of BIOS, it is recommended that you not flash the BIOS. To flash the BIOS, do it with caution. Inadequate BIOS flashing may result in system malfunction. Three BIOS Flash Utilities... We provide three BIOS flash utilities at our website. Below are the overviews. 1 : flashbios_qflash.gif A BIOS flash utility embedded in Flash ROM. Not all motherboards have the Q-Flash, please use @BIOS or DOS flash utility to update BIOS if your motherboard does not have Q-Flash. Features-- With this utility, you only have to stay in the BIOS menu when you want to update BIOS. No need to enter DOS or O.S. mode. Caution-- Make sure you have a functional floppy disk with the correct BIOS version for your motherboard. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 2 : flashbios_atbios.gif A Windows-based BIOS live update utility. Features-- @BIOS helps you search for, download, and then update the latest BIOS in Windows operating system. Caution-- Make sure your O.S. environment is stable. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 3 : DOS Flash utility Features-- The flash utility is a combination of AMI and AWARD BIOS flash utility. You can use it with both AMI and AWARD BIOS. Caution-- Make sure you have a functional DOS boot disk with the correct BIOS version for your motherboard.
I hope my solution may help you.
Thanks for using Fixya...;-)
Sep 18, 2013 | Gigabyte Computers & Internet
BIOS UPDATE
HAVE YOU PROBLEM WITH BIOS ?.
YOU SHOULD NEVER UPDATE IF ALL WORKS.
Jul 11, 2013 | Samsung Computers & Internet
I want upgrade bios ga 8simlh rev 1.0,but can not
Jul 16, 2012 | Gigabyte GA-8SIMLH Motherboard
Vga 686 AMI bios
Hello here is the homepage:
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?DetailID=248&CategoryID=1&DetailName=Feature&MenuID=49&LanID=0
Don`t upgrade the bios, unless you are 100% sure, it`s the right mainboard.
Any drivers missing ??
Good luck
May 16, 2011 | PC Chips (M791G) Motherboard
Bios damaged
You are fortunate that your BIOS has a built-in recovery procedure. However, you will need a working floppy drive to recover the damaged BIOS.
Do you know what BIOS microcode you're using? Specifically, do you have an Award, AMI, or Phoenix BIOS? (Or some other one?)
Award, AMI, and Phoenix all have different procedures for recovering the BIOS. Once you know which one you have, search Google for "XXXX BIOS recovery" (Where XXXX is Award, AMI, or Phoenix).
Typically, the procedure includes placing a BIOS file onto a floppy, renaming it to a specific name (like AMIBOOT.ROM) and inserting that floppy into the drive.
Jul 19, 2009 | Computers & Internet
Bios update
go online and type in
bois download drivers
enter
manifacture name bois model # [date if u have one] download drivers
rod
Dec 16, 2008 | ASUS P4S800-MX Motherboard
The simplest way to update any BIOS is to log on to the Net with that same computer. Do a google search for your BIOS and you have all that info thats it.
Sep 03, 2007 | AMD Athlon 64 X2 3800+ Dual Core Processor...
MSI 661FM3-V Motherboard Logo
744 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
