Question about Electronics - Others
Transcend jetflash 210 not working in windows 7
I have recently upgraded to Windows 7 from XP only to find that my Transcend Jetflash 210 2GB no longer works. Any way I can get it working again?
  • Jeroen B Jan 15, 2013
    I tried the registry setting and rebooted but that did not solve it. What is not showing up is the driver that asks for the fingerprint. There was a suggestion to install the driver, I would love to do that but have searched extensively and cannot find it. Does the original poster of that comment have a download link?
  • Brian Sullivan
    Brian Sullivan Jan 15, 2013
    W 7 First, please disconnect all USB devices and then perform the following steps: Click "Start" button, type devmgmt.msc (without quotation marks) in the Search bar and press "Enter". Click Continue if necessary.In Device Manager, double click to expand Universal Serial Bus controllers, right click on the Host Controller, click Uninstall and click OK.Repeat the step 2 to uninstall all items under Universal Serial Bus controllers. Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
  • 27,725 Answers
Click Start, then Run Enter regedt32.exe and navigate to HKEY_LOCAL_Machine\SYSTEM\CurrentControlSet\Services\Usb f a USB key doesn't exist, create one and create a new DWORD value called DisableSelectiveSuspend and make its value 1. Restart the PC. Transcend have a lifetime warranty http://www.download3000.com/download_48621.html
Posted on Jan 15, 2013
4 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: I have a Transcend JetFlash
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive to working order you need to format the flash drive,BUT you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Posted on May 17, 2011
SOURCE: Transcend jetflash 2GB no detecting
ny Transcend jet flash 2GB fingerprint not recognized, any help fpr me pls to format or to find any solution for this problem...
thanx
Basman
Posted on Nov 01, 2008
  • 70 Answers
SOURCE: unknown device
you must install windows driver package to run it
Posted on Apr 15, 2009
Transcend 32gb jf v60 pen drive not working
If now you can see your usb drive there might not be any need to do the following
Click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
then you might have restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
Transcend jetflash recovery
JetFlash Online Recovery is an advanced new software tool specifically developed for Transcend JetFlash USB flash drives.
If your flash drive is not working properly, in most cases it can be repaired instantly by using the recovery tool's simple user-friendly interface.
The JetFlash Online Recovery Tool is conveniently located on the Internet, so no matter where you go, you can service your flash drive 24 hours a day, 7 days a week.
All data on your JetFlash drive will be permanently erased during the repair process.
Please backup the contents of your JetFlash before proceeding.
This software is designed to repair malfunctioning JetFlash USB flash drives.
It will not recover
any data/pictures stored on the device.
Hardware Requirements: USB Port (supports USB2.0), Internet Connection
System Requirements:
Windows XP SP2/ 2000 SP4 or later version(Administrator rights required)
Windows Vista (Administrator rights required, must turn off UAC) To turn off UAC in
Windows Vista, please go to Control Panel > User Account -> Turn User Account Control on or off > and then uncheck ''Use User Account Control to help protect your computer.'' Please remember to restart your PC for the new settings to take effect.
Windows 7 (Administrator rights required, must turn off UAC)
To turn off UAC in Windows 7, please go to
Control Panel -> User Accounts -> Change User Account Control Settings -> change to "Never notify" -> then, Please remember to restart your PC for the new settings to take effect.
Download Links
JetFlash Online Recovery (for Windows 2000 SP4/ XP SP2/ Vista /7)
JetFlash Online Recovery (Only for V15; for Windows 2000 SP4/ XP SP2/ Vista /7)
JetFlash Online Recovery (Only for JF620; for Windows 2000 SP4/ XP SP2/ Vista /7)
User Manuals for JetFlash Online Recovery
Manuals (Traditional Chinese)
Manuals (English)
If you need more help with this post a reply
Hope this helps.
Nov 27, 2012 | Electronics - Others
My 32 gb transcend pendrive not work how to repair what is problem and where in pune
You have to be the computers Administrator to change any values on any hardware on a computer
Click start control panel user accounts on the users tab click the name of the computer Administrator you must have full control.
Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
If you are running a Windows XP OS then you might be able to:
click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
w7
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
for xp or earlier
click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver
restore defaults
In XP
It will not recover
Download Links
Manuals (English)
Hope this helps.
Nov 26, 2012 | Electronics - Others
My computer which runs Windows 7 can not detect my Jetflash 500 16gb flashdrive
It should be able to automatically detect and install it. Try using it on another computer that has either Windows XP, Vista , or Windows 7 on it. If it doesn't automatically detect and install it on that one then the flashdrive is dead.
May 14, 2012 | Transcend TS16GJF500 16GB JetFlash 500 USB...
Usb TRANSCEND JETFLASH " ELITE" NOT WORKING ON WINDOWS 7
what i have found is that you will need to use your jetflash 8 gb with windows 7 only if you keep trying to use it with xp you will get error messages or wanting to scan or format it
click start click to open on my computer you should see your usb drive F: right click select properties there will be an array of options select the sharing tab option then advanced sharing
permissions make sure you have a tick in the share this folder box then click permissions make sure all three boxes are ticked you full control change and read in windows 7
hope this helps you
Jan 18, 2012 | Electronics - Others
Suddenly usb pen drive stopped recognising
Try using 'JetFlash Online Recovery' .
It is advanced new software specifically developed for Transcend's JetFlash USB flash drives. It repairs your flash drives immediately through simple and user friendly interface. With such effective, safe and reliable solution, it can save your precious time and money bringing your product for traditional RMA service. Wherever you travel, Transcend JetFlash Online Recovery services you 24/7 on the internet.
* Hardware Requirements : USB port (supports USB2.0),Internet connection
* System Requirements : Windows® XP SP2/ 2000 SP4 (Administrator rights required).
Step by Step Instructions
1. Please insert your JetFlash into a PC with internet connection.
2. Run OnLineRecovery.exe and press "START."
3. A confirmation message will be displayed. If you are sure you want to format the JetFlash, press "START." If you do not want to format your JetFlash at this time, please press "EXIT" to quit.
4. The process may take several minutes. Please be patient.
5. When the format is complete, please press "Exit," then unplug the JetFlash and plug it back in to your computer.
voila, its done.
Don't forget to say THANKS
Oct 23, 2010 | Transcend Computers & Internet
Unknown device
Apr 10, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Download copy JFSW.exe for JetFlash elite
Driver Installation – Windows® Me, 2000, XP and Vista
No drivers are required. Newer Windows operating systems have built-in drivers that support the JetFlash®. Simply plug your JetFlash® into an available USB port and Windows will automatically install the files needed to use your device. A “Removable Disk” with a newly assigned drive letter will appear in the My Computer window.
JFSW.exe is the older version. You might want to try JetFlash Elite v2.0, a newer more advanced version of JetFlash elite - highly recommended:
http://www.transcendusa.com/Support/DLCenter/Software/Setup_JFSW2.exe
I think you know about this page, but here's a link to save you googling:
/index.asp?axn=SRH2&ModNo=107&ItemID=TS2GJFV30
Hope this helps
Chris (ziraffa)
Jan 11, 2009 | Transcend T.sonic 610 MP3 Player
thanx
Basman
Nov 01, 2008 | Transcend (589307) Media
Electronics - Others Logo
1,307 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
