Kipor sinemaster KGE 2000 Ti Service manual
No spark
The generator shuts off after 30 minutes with an oil level alert but oil level if full
Your oil level sensor is bad. It needs to be replaced. If you unplug the wire leads to the sensor you may get the generator to run, but you'll have no low oil level/pressure protection. The oil level sensor is on the engine crankcase usually near the oil level dipstick. You'll likely see a small sensor with a couple of wires attached to it. To replace it, you'll need to drain your engine crankcase before removing the sensor.
Apr 06, 2014 | Kipor RV Generator Sinemaster IG3000
Kipor ig2000 sinemaster generator runs good no ac power.
You have a faulty inverter board from what it seems. I'd warranty the generator as soon as possible. Without proper electrical experience, I do not recommend you attempt to replace it yourself as you could cause a fire or injury.
Aug 09, 2013 | Electrical Supplies
My kipor KGE 6000 Ti generator overload light is on, and there is no current output
Speak to us and we can help you diagnose this error.
www.generatorguru.com
Dec 25, 2012 | Electrical Supplies
Kipor generator starts ok but will not provide electricity to apppliances
first check the circuit breakers if there ok the problem is inside like over heated parts
Sep 05, 2012 | Kipor RV Generator Sinemaster IG3000
My kipor KGE 1000Ti starts fine but after several minutes stops generating and the red overload light comes on, with the demand for power left connected and the generator still running electrical...
You may be UNDERLOADING the generator and it may be unstable with such a light load... see if it might behave running a heavier load... put a 100 watt light on it as a test,
Jul 25, 2010 | Electrical Supplies
How can you check ignition module[KI-DHQ-30]ON KIPOR SINEMASTER IG3000
If you pull over the engine and make note of the lights we can help you diagnose the problem (ie. inverter, module, oil sensor etc.) Then drop us call and we will run you through it. Generator Guru
Jun 09, 2010 | Electrical Supplies
368 people viewed this question
jasbo
jasbo
