Question about Dremel Variable - Speed Multipro Rotary Tool 395
Why does my dremel overheat & smell - Dremel Variable - Speed Multipro Rotary Tool 395
  • sage63
    sage63 Jan 17, 2013
    Brushes seem to be o.k.
Dremel troubleshooting
If you've allowed it to overheat, you'll have to wait before you can turn it on.
Aug 05, 2014 | Dremel 300228 300 Series Variable Speed...
Why has my dremel 6000 just stopped working could it be the brushes
Although Supergrit Abrasives in Gettysburg, PA sells the sleeves and the Hook & Loop diamonds for use with the Dremel 6000, we do not repair tools. The 6000 is discontinued, but you can probably buy a used one that works on Ebay.
Jun 14, 2014 | Dremel 6000 Contour Sander
Engine smells hot
What is the question?
Have you considered a repair shop?
It either overheats or it doesn't
It smells or it doesn't
Don't know what to tell you
without seeing the truck & you explaining
the issue
Jan 30, 2013 | 1997 Nissan Pathfinder
My heater wont work, my car smells like fish & chips, overheats
If your inside fogs up your windshield , i would say its a heater core leak. Check your coolant level it could be very low due to the leak.
Feb 22, 2010 | 1996 Toyota Camry
Do Dremel 4000 tools overheat and stop running? Is there a reset switch?
On a 4000 there is a thermal fuse at the base of the motor from the brush housing. They are cheap to replace. these are replacing fuses on alot of electronic devices. the fuse is a microtemp g7f01 110c.
Feb 20, 2010 | Dremel Multi Max Kit
Motor works but no drive to shaft.
My 15 year old Dremel 395 had the same problem so I took it apart. There is a plastic spline between the motor and the output shaft to the chuck . My plastic spline was split and had many of its teeth sheared off. The shaft lock acts on the output shaft side of this spline, so it was ok. Otherwise everything looked great; bearings ran free & had little play free, brushes ok. To be fair, my Dremel had seen hard use & doesn't owe me anything. No luck so far finding replacement spline parts, which if available should be easy to install. To take apart your tool, just google "Dremel Disassembly". GOOD LUCK!
Nov 28, 2009 | Dremel Variable - Speed Multipro Rotary...
220 volt was applied to motor due to faulty 220/110 V adapter. How can I troubleshoot motor
The first thing to do is smell it. If it smells burned, it is probably fried. If it isn't working after being plugged into 220, there won't be a fix. Armatures & field coils aren't available for these.
Nov 07, 2009 | Dremel 300-N/55 300 Series Tool Kit
Dremel 400 xpr stopped while in use and started to smell like it was burning. It would not start back up again
its a comon thing with a dremel to just burn out in use iv got through 3 of them all died the same way
Oct 25, 2009 | Dremel 400 Xpr Rotary Tool
Is there a reset button for a Dremel Multi Pro?
When the brushes go on my Dremel, it just stops, sometimes erratically - no smell or burning.
May 04, 2008 | Dremel Variable - Speed Multipro Rotary...
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
