Question about General Electric GE ELECTRICAL TQD22200X2 "Q LINE" MAIN CIRCUIT BREAKERS 240V
200 amp square d wiring diagram with pictures
I order a new fuel pump on web it came with rectangle plug but my came with square one. I installed it the pump works good but the gauge doesn't. Wires are wrong.
All I can say--- is why would you install a pump
with the wrong wire connector & how,cut the
wires & soldering
Except for the wire colors
You can't use that one & expect to have
the factory designed results
IF-- you get wiring diagrams & remove the new
pump, you may find you still can use it
I do not work on any vehicle without first
having wiring diagrams,even if not needed
Aug 12, 2014 | Cars & Trucks
Do i need a main breaker for a 200 amp panal?
This looks like an indoor panel. If you have an outdoor panel next to (or below) the power companies meter, It should have the breaker to feed such a panel. Thus, this indoor panel should only be required to have "main lugs" to receive wire from outside breaker. NEVER size breaker outside bigger than the equipment rating of inside devices. If from the power companies meter you intend to feed this panel, YES it is required to have a Main Breaker.
Apr 02, 2012 | Square D Qo 200 Amp 40 Circuit Indoor...
Wiring diagram for three phase power with two 200 amp service boxes inside building
This work requires a license (or qualified person) everywhere that the National Electrical Code is enforced.
If you're asking how to wire a single phase 200 amp panel from a larger, 3 phase panel of the same voltage - ONE way is to install a 2 pole - 200 amp breaker into the 3 phase panel. Provide 4 correctly sized conductors with the correct insulation in a cable or conduit between the 3 phase panel and the 200 amp single phase panel. Two of these conductors should be black and red (for 120/208 volt system) and connect to the 2 pole - 200 amp circuit breaker terminals, the third should be white and connected to the neutral bus bar. The forth should be green and is connected to the neutral bus bar as well but *only if* it is "service equipment" If it is a "main or sub panel", the green wire should be connected to the ground bus bar. The other end of the conductors should be terminated in a "main lug only" 200 amp panel. The back and red connect to "line 1" and "line 2" bus lugs, the white to the neutral bus bar that is NOT electrically connected to the panel enclosure (do not install the screw or strap between the bar and enclosure). The green must be connected by installing a separate bar that is securely fastened both mechanically and electrically to the enclosure for ground connections.
There is a great deal going on here - and plenty of variables that can change how to do this work, safely and correctly. This is an example of just ONE of many different ways to do the work for a particular installation. There is no one way that works for all situations. If your situation does not support this method - you will have an unsafe installation and subject the building and people in it to a dangerous fire / safety hazard.
Please, consult a licensed electrician before attempting this work.
Nov 17, 2011 | Square D Qo 200 Amp 40 Circuit Indoor...
Can i feed a 100amp box from a 200amp box and feed from main leads ?
As long as you have the capacity to run 100 amps from your 200 amp box and your wire size is adequate then yes.
Nov 13, 2011 | Square Electrical Supplies
What is the second smaller lug for on the service lugs next to the nuetral in a 200 amp square d homeliness panel
This is a sub-feed lug, should you ever decide to add a sub-panel in your house. So when landing your feed wires to this panel, use the larger lug. Good Luck, and feel free to ask me anymore question's that you may. - Jim
Apr 02, 2010 | Square D Qo 200 Amp 42 Circuit Indoor...
I am looking for wiring diagram for honda PICTURE
I have a wiring diagram from the Haynes manual for the CB200.  Can send you by email. kieraan at g mail.
Feb 21, 2009 | 1974 Honda CB 200
Bought wrong panel
no, not to code plus the expense would not justify , you can purchase the 200 amp panel with the main already installed cheaper than purchasing the 200 amp breaker in most cases and still meet the code check on a panel package called a home owners kit ge makes one square d , makes one either good quality , you get the 200 amp panel, several breakers such as 20 amp 50 amp 30 amp by far the best route for you
Dec 05, 2008 | Electrical Supplies
General Electric GE ELECTRICAL TQD22200X2 "Q LINE" MAIN CIRCUIT BREAKERS 240V Logo
Top General Electric Electrical Supplies Experts
hpgwva
Rob Bridges
Level 1 Expert
ken skalski
Are you a General Electric Electrical Supply Expert? Answer questions, earn points and help others
