Problem restarting Desktop computer
When I boot my computer the nothing comes up on the screen. After several attempts to restart the PC with the restart button, the following messegae comes up: "The last attempt to restart the sysytem from its previous location failed. Attempt to restart again?" At this time the system is frozen
    Problem Solver:
  • 11 Answers
The computer battery needs to be replaced. The computer is missing its BIOS settings, which are stored on the computer battery on the motherboard. It's about the size of a nickel, and pops out easily. Take it to your favorite computer store and get a new one - about $8.
Posted on Feb 01, 2009
Stuck in log in screen
The most likely cause is you've recently installed some hardware or software, and upon restarting, the computer didn't know how to handle it. Not to worry, there are several options that often solve this type of problem. Disconnect any hardware you recently installed, such as a sound card. It could be causing the issue. The hardware may be defective or your computer may not have the capability to use it. Start the computer and wait for the Desktop to show up. If the Desktop appears to be just seconds away from showing up but never does, hold down the Ctrl-Alt-Del key combination. In the menu that pops up, choose "Start Task Manager." Select any task you see in the "Application" tab and choose "End task." This may allow the computer to finish loading. Restart the computer if the problem persists. When starting, hold down the F8 key to get a list of startup options. Select the option for "Last Known Good Configuration." Let Windows boot up. If this doesn't work, restart and choose "Advanced Boot Menu" and then "Safe Mode." Let Windows load. If either solution works, go to the Control Panel and choose "Uninstall a program." Select the last thing you installed and choose "Uninstall." Attempt to repair Windows. This may be your last option if nothing else works. Insert the Windows DVD and restart the computer. When the computer restarts, press any key to boot from the DVD. At the first menu choose your language and country and click "Next." Choose the "Repair your computer" option. Use the recovery tools option and then "Startup Repair." If this doesn't work, repeat these steps and choose "System Restore" instead of "Startup Repair" and choose a date before you began experiencing the problem. Hope this helps
b>
Dec 27, 2012 | Samsung NC10-14GW Notebook
After automatic updates and a restart, diagonstic lights A & C were yellow and D & B green, nothing comes up on screen, this happen before after an update but i got it to start after several a
If all diagnostic lights are on, then that means that it has something with the software of your computer. The update has affected some of the programs inside your computer thus it's booting up fine.
I suggest that you access safe mode and do a system restore from there. If you don't know how to access safe mode, then follow these:
1. Turn off your computer.
2. turn it on and keep tapping F8 until you see the options. You should see safe mode.
3. Use the arrow keys to select safe mode, then press enter.
4. Your computer should boot up to safe mode.
5. Access the system restore. You can find it in accessories, system tools, system restore. or you can search.
6. restore your computer to the known good date where your computer was still working fine.
7. After completing the on screen procedures, let your computer restart by itself (it may take minutes or more). It will restart and it should boot to the normal windows.
Good Luck!
I hope this helps.
Carlo
Nov 16, 2012 | Dell Dimension 2400 PC Desktop
I have restored my computer to the factory settings. It went through all the steps to restore my computer. Once it shut it self down from rebooting the Windows XP screen comes up saying please wait.... ...
disconnect all the external devices, try to boot the computer in safe mode by pressing F8, if it doesn't boot in safe mode then you may need to reinstall windows on your computer.
Dec 24, 2010 | E-Machines T6520 PC Desktop
I turn on my computer and i get a box that sais adjust screen and gives a resolution and then goes black, nothing else happens no beeps no booting noise. F10 pops up another screen for 2 seconds then goes...
try to boot in safe mode.To do that.
restart your computer continues press F8 key it will show the option select safe mode
and you can work with that and change the reasoluition and restart the computer work with normal mode..
Nov 13, 2010 | HP Pavilion A610n (PC106A#ABA) PC Desktop
I have a HP Pavilion dv6700 lapt op and recently I installed a new game on it. When I exited the game to install updates onto my pC and restart, the color resolution was extremely distorted and all of my...
restart your computer, hold down f8 untill you see the windows trouble screen, on that screen choose: safe mode then when windows loads repair your resolution and, remove the game from your computer then restart the computer again
May 18, 2010 | HP Pavilion dv6000z Notebook
My PC won't start? every time i start it the fan just spins fast and loud and nothing happens, the screen doesn't show. this happened when i took the PC apart. it a Compaq presario sr1610nx
Initially test the monitor in another pc, if display available use the monitor in Compaq presario sr1610nx. Load to BIOS by restarting and tapping F1, if the display available, the computer is ok. restart and tap F8, if the advanced boot option screen comes up, the software is ok.
Restart the computer and tap F10 and proceed with a destructive recovery to reload the operating system on the computer
May 07, 2010 | Compaq Presario 5000 PC Desktop
Computer will not re-boot
your hard drive has been corrupted due to improper shutdown
Oct 07, 2009 | Dell Dimension 3100 PC Desktop
Computer comes on, shows a blue screen, and restarts on it's own.
Try to boot into Safe Mode.
If you're able to, let me know and we'll go from there.
Jun 17, 2009 | HP Compaq Presario 2223US Notebook
Computers & Internet Logo
161 people viewed this question
David Payne
David Payne
