Error code C-0413 konica minlta 6500
When i started the machine after warm up view munite i get the error code C-0413 i off the machine and on it the code is gone ,when i print some time it takes about longer then it give the same code,when i look at the code it show that (fan heater up / HTR3 , or lower /Tems3 . please help thank you
dbarchitect
  • 150 Answers
SOURCE: konica 7020
Did you blow it up, probably not.
Click this link for the everything.
http://www.kmbs.konicaminolta.us/content/support/supporthome.html
  1. Choose the Category "Office Systems"
  2. Choose the model "7020"
  3. Click the error next to the Model dropdown box.
  4. Choose the 1876KB user manual called "User Manual for 7020, 7025, 7030 and 7035"
Or click on this link for the specific manual.
The error codes you seek are not in the manual, you'll have to call Konica to tell you what they are ... call Konica at (860) 683-2222.
Hope this helps. Rate a fixya!
Posted on Dec 11, 2007
sir fixalot
  • 146 Answers
SOURCE: konica 7020
F26-1 at power up. [Description] F26-1 at power up.
[Solution]
PROBABLE CAUSES:
1. The TDS (Toner Density Sensor), in the developing unit, has detected a depletion of toner.
Note: This may have been caused by the customer making an excessive amount of copies while the machine was out of toner. It may also be caused by a bound toner addition system.
Clean all toner from the toner recycle and toner supply assemblies. Confirm that the gear mesh between the toner supply auger drive gear and toner supply motor (M4) is flush. If toner supply conveyance is normal and the toner cavity is empty, install a new toner cartridge (Item #950236) and then perform the following diagnostic mode to replenish the developing unit with toner:
a. Access the 47 mode (power the copier ON while pressing the 4 and 7 keys).
b. Enter output code 54.
c. Press the START button.
Note: Toner will now be added to the developing unit and stop automatically when target level is reached, although it will not run any longer than 3 minutes.
d. Power copier OFF/ON to return to normal copy mode.
Note: Perform the following 25 mode software switch settings to minimize the amount of copies that can be made, prior to copy inhibit, when the ADD TONER message is displayed:
- Access the 25 mode (hold down the 2 and 5 keys at power ON).
- Select [1] (SOFTWARE SW).
- Using the up and down arrows, scroll to the following software switches and set them as follows:
a. 4-0 set to 0
b. 4-1 set to 0
c. 4-2 set to 0
d. 4-3 set to 0
- Power OFF/ON to return to normal copy mode.
Notes:
A. These setting will allow the ADD TONER message to be displayed immediately and only allow 100 copies to be thereafter.
B. Copier inhibit will automatically be released when a new toner cartridge is installed.
2. The toner conveyance gear is worn. The toner conveyance gear is driven by the toner supply motor located on the toner supply unit.
Replace the toner conveyance gear (p/n 26NA32680).
I may be able to get the manuals for a nominal charge. bkbell@brianbell.net
Posted on Jan 03, 2008
  • 86 Answers
SOURCE: Problem on GP405 coppier
E220
The lamp intensity does not
exceed a specific value
within a specific time after
scanning operation starts
(following lamp activation).
• The lamp remains off for 10
sec when it should remain on.
E301 is
The output of the intensity
sensor drops below a specific
value while the lamp is on.
E100 is
The BD signal is not
generated during image
formation (2nd sheet pickup
and later).
• The BD signal cycle has
deviated.
• The BD signal is not
generated within 2 sec after
the laser has turned on (at
time of 1st sheet pick-up).
To have all three come up at differant times and intermittantly
I suspect the front door interlock switch is not being made properly or needs replacing
If you require more help please contact me by reposting
Thank You
Posted on Mar 11, 2008
SOURCE: error code f35-3 on konica minolta 7145 copier
How to reset failure codes (F34, F35, F36). To reset failure codes, perform the following: 1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys). 2. Select [1. software SW settings]. 3. Using the arrows on the left of the touchscreen scroll to DIP SW 3. 4. Using the middle arrows scroll to BIT 1. 5. On the touchscreen select OFF (0). 6. Power the copier OFF/ON.
Posted on Sep 22, 2008
fer_nan_14
  • 76 Answers
SOURCE: Error code 03130031-2F13
03130031-2F13 A/D Converter external trigger output stopped
and the problem is main controler
Posted on Dec 08, 2008
HOW TO SOLVE ERROR CODE C0500 FOR KONICA MINOLTA 211
Error code C0500 and C0501 means Fixing unit's temperature abnormality.
How to reset these codes?
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
http://servicekonicaminolta.blogspot.com/2012/03/error-code-c0500-and-c0501.html
Jun 14, 2017 | Konica Minolta Office Equipment & Supplies
How can I reset eror code CO 500 on konica minolta copier DI 2510
Aug 08, 2016 | Konica Minolta Di2510 Di251 Di250 Di2010...
Hi device does not copy C450 Konica K- error gives FB52
Error concerning Data transmission Bus or hardware (IR
Input system) Check connections between the MFP Control Board (PWBMFPC) Copier Board (PWB-CF) Some serious money so check all connectors, remove them one by one and check each one for bent pin(s) ensure reseated properly, could also have bad firmware, requires tech, because firmware is on secure web site at Konica Minolta.
Aug 21, 2015 | Genuine Konica Minolta Konica Minlta...
Hey I have konica minolta magicolour 2400w printer. When i turn it on, it start warming up but after 3 seconds it turns on the ERROR light & the printer doesn't work. Every time i turn it on same issue...
Hi
Usually these machines give you an error code on the control screen. You do not mention one but the webpage here:
Error Codes Konica Minolta Magicolor 2400W
gives most of the error codes for your model.
and also by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 31, 2014 | Office Equipment & Supplies
What does error code c3102 0n a konica minolta bizhub 6500 mean
problem with Fusing release home sensor and or fuser motor. Fuser is the Hot Part of the machine
Jun 16, 2014 | Konica Minolta Office Equipment & Supplies
Error code 3904
replace the fusing unit and have a tech look at it
Jan 02, 2014 | Konica Minolta Bizhub C 6500 Copier
Error code 3501
HI
I HAVE KONICA C6500
ERROR CODE 3501 and 3802 but know the error 3501
I know it rech high temperature I change the sensor 1 UP fuser roller
and I reset the error, the machine start and stop again with error 3501
Oct 01, 2013 | Konica Minolta Bizhub C 6500 Copier
I turned on my machine and an error message that read CAUTION MACHINE TROUBLE SERVICE CALL (0500). Just purchased konica minlta magicolor 1680 mf a week ago.
With it still under warranty, I would hesitate in any fixes that may negate said warranty. Here is the information to get a hold of Konica: call 1-800-208-1203, select option 4 and have your serial number available.
You might also call the place you purchased it from, being only a week old, it should not be having any issues.
I hope this helps
Jul 22, 2011 | Office Equipment & Supplies
I have problem witm color copier konica minlta 8050 with error sc28-02
Check the yellow drum charge corona to get that open the front of the machine unscrew the front section then pull out he charge corona for yellow do not have open the unit to expose belt and drum. ensure they all are seated properly
Feb 02, 2011 | Konica Office Equipment & Supplies
E000602-0413 error msg
A E000602-0413 code means that the hard drive has crashed or it is failing. You will need to have the hard drive replaced or have it reflashed, but the flashing will only be a band aid. Good Luck
Aug 20, 2010 | Canon imageRUNNER 5570 Copier
43 people viewed this question
jasbo
jasbo
