Question about Dishwashers
Hotpoint is not taking water inlet
Hi
My dishwasher (Hotpoint) is not taking water inlet. I assume that this is due to air blockage. Any suggestion ho to resolve air blockage
thanks for the help
    President:
  • 1,214 Answers
If your thinking air in the water supply line, air won't be the cause. I would look to make sure there is not mineral buildup inside the valve, and that the valve is good.
Turn the water off, disconnect the line at the water valve, then carefully tirn the water abck on to make sure there is good flow from the water supply line. If there is, then look toward the dishwasher side. If not, look toward the water supply side.
Posted on Jan 24, 2009
Hotpoint Aquarius FDW60 won't take in water. Suspected airlock after house move?!?
Try checking the inlet solinoid , should be 1 for hot & cold, sometimes the solinoid will freeze up due to alkaline buildup .try soaking it in CRL , alkaline deposit desolving liquid .
Mar 13, 2012 | Hotpoint 24 in. FDW60 Free-standing...
Dishwasher is on and connected to water, but no water coming in.
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 27, 2011 | Hotpoint 24 in. FDW60 Free-standing...
The water is not running into my dishwasher, have checked the pipe and there is not blockage
Hi
Daniel
Aug 27, 2011 | Bosch Dishwashers
My dishwasher draining but does not take water in
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back if you need more information.
Daniel
Jun 07, 2011 | Danby DDW1805W Designer Series...
Sn65e000gb dishwasher water not going in
Hi
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Mar 19, 2011 | Siemens Dishwashers
My dishwasher does not fill with water
Hi
Daniel
Feb 21, 2011 | Bosch SHU5315UC Dishwasher
Dishwasher runs but gets no water...
Hi
Daniel
Jan 31, 2011 | Maytag 24 in. MDB5651A Built-in Dishwasher
It is not getting any water
Hi
Daniel
Jan 25, 2011 | Whirlpool DU1030XTXS Dishwasher
Dishwasher is not filling up with water
Hi
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter hen you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Oct 25, 2010 | Hotpoint Dishwashers
Dishwasher will not fill with water
Hi
Daniel
Oct 07, 2010 | Bosch Dishwashers
Dishwashers Logo
82 people viewed this question
Top Dishwashers Experts
