Question about Yamaha RX-V673 7.2 Channel AV Receiver BONUS PAK w/ Two HDMI Cables
Impedance setting on Yamaha AV Receiver
Impedance of my Front & Center speakers are 6 Ohms and my pair of surround speakers have an impedance of 8 Ohms. Can I set the impedance of my AV Receiver at 6 Ohms or just retain the unit's default impedance at 8 Ohms?
    Problem Solver:
  • 17 Answers
Hi. You can always use a Receiver with an output impedance that is lower than the speakers input impedance.Problems arise when you try to use a Receiver with a higher output impedance than the Speakers input impedance.
Receiver 6 ohms speakers 8 ohms......YES..
Receiver 8 ohms Speakers 6 ohms.......YES, WITH CAUTION
Posted on Jan 16, 2013
Testimonial: "Thank you so much for the very enlightening advice on proper matching of Receiver and Speakers impedance."
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: speaker impedance and the Yamaha RXV 463
You risk to crash a set of speakers. In any case this will have a detrimental effect on the sound
Posted on Aug 04, 2008
dunnbiker
  • 8546 Answers
SOURCE: Hi, I am considering to buy a second hand Yamaha
See the answer to your first request:
http://www.fixya.com/PostComment.aspx?thid=4198937&prdid=149612&ctgid=0
Posted on Feb 24, 2010
I have a Yamaha H/T receiver rated @ 95 watts. The front and rear speakers a hms and the center channel is 4 ohms. Is this a dangerous setup for my receiver to function in?
You seem to be confusing the power of the Receiver with the impedance. Watts is how much power or how loud it can go. While ohms is the impedance of the device. The receiver will have an lowest ohms setting for it's speakers. For example if it says 4 ohm you can connect any speaker of 4 ohms and above to it. However if it said 8 ohms then you should not connect any speaker lower than that.
Each channel will have it's own power level measured in Watts. Some units have the same level for all channels, others have different levels for the channels. You can connect any speaker that has a wattage greater than the channel's total max power. If you connect say a 50 watt speaker to a 70 watt amp, it will work, but you must never take the volume to even near the max or it will blow the speaker.
Anything with a mono soundtrack will only decode on the left and right channels. Unless the unit has something like an all channels setting. So the unit seems to be working fine. Mono films have no surround effects applied to them, so the indications are simply showing they are working. They of course feed no surround to other channels, as none are present.
Oct 02, 2017 | Audio Players & Recorders
Speaker impedance and the Yamaha RXV 463
Aug 04, 2008 | Yamaha RX-V659 Receiver
I just purchased a yamaha RX-V767 receiver. I have a polk surround sound speaker system 5.1 that have an impededance of 8 ohms. The receiver has an impedece adjustment knob on it. would it be safe to...
No, you don't want to do that. The Ohm output on the amplifier must match the speakers. Run 8 Ohm speakers on 8 Ohm and run all your speakers on the same impedance (Ohms). Your gonna burn your amplifier up if you run different impedances.
Mar 24, 2011 | Yamaha NS-A60X Main / Stereo Speaker
4 ohm speakers on Yamaha HTR 5540
Model number of the Lux? The only unknown to me regarding the answer is if the Lux speakers are designed for non-Lux attachment. If there are molded connectors on their leads I would be cautious as that is usually the manufacturer's subltlke clue that you really don't want toi mix them with other makers. If they're bare wire I think you're ok.
The impedance selector on the receiver supports minimum 4-ohm front and 6-ohm center and rear, so you'd be marginal on those last two, but barring excessive high volumes I'd think it would work. The powered sub is supported and its impedance spec is irrelevant.
Just curious, is this an upgrade in electronics? From what?
Feb 23, 2010 | Yamaha HTR-5540 Receiver
Can I mix 6 and 8 ohm speakers?
I would not suggest mixing. Use either 6 or 8 only but i highly suggest not mixing unless it gives the option to set a certain input for a certain Ohm. If you mix your either going to mess up a speaker or the receiver itself.
Jun 01, 2009 | Yamaha RX-V463 Receiver
With my RX-V663 can I use presence speakers less than 8 ohms?
Basically you can use any speaker as long as you use the volume button wisely. Damage will only occur if you raise the volume level to the extremes. Bigger speakers should be no problem, if you want bi-amping, your speakers should support that as well.
Apr 10, 2009 | Yamaha RX-V663 Receiver
Denon AVR-2307 Protection Circuit Activated permenantly
The speakers are 4 ohm speakers, a guy on another chat site sent me a link to the impedance curves http://www.audioholics.com/reviews/s...t-v2-fs/page-4
He agreed to that there was a mismatch as the unit has plenty of fresh air around it, plus all the speaker cables have been tested and installed correctly.
So, off to the store where I got it from tomorrow.
Jan 02, 2009 | Denon AVR-2307 Receiver
I have purchased brand new Jamo speakers A 320. Front and surround measure with ohm meter open circuit. Centre speaker Measure impedance 6 ohms. Is this a normal,i have also checked another set of the...
Most better low frequency speakers (woofers) measure about 6 ohms because the addition of crossover will bring the impedance up to 8 ohms. Even without the crossover, 6 ohms will not harm the amp or speakers
Aug 15, 2008 | Audio Players & Recorders
Do all speakers need to have the same impedance? (Protect mode)
Amplifiers sometimes like to have "balanced loads" on them, and this may be the case with your unit, meaning yes, all the impedances should match.
Judging by the impedance numbers you provided, you should be all set. You really want to avoid having something like 2 ohms on the left side and 8 ohms on the right side - grossly imbalanced. I don't see any problems with what you're going to run.
Mar 24, 2008 | Onkyo TX-SR505 Receiver
Yamaha RX-V673 7.2 Channel AV Receiver BONUS PAK w/ Two HDMI Cables Logo
532 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
