Question about Roofing
What kind of metal is best for roof flashing?
    New Friend:
  • 4 Answers
Copper is one of the best metal used for roofing. But, there many other metals are also available for roofing. The advanced technique and equipment are used to made all types of metal strong and effective for roofing. You can refer roofing in sheffield for more details.
Posted on Jun 12, 2017
    New Friend:
  • 4 Answers
Copper is the best flashing Metal Roofing Sheets. Flashing forms the intersections and terminations of roofing systems and surfaces. Copper is good as it is easy maintenance and easy to install. It is durable and strong also. Strong air also does not affect the copper and keep it in its place.
Posted on Apr 05, 2017
    New Friend:
Sheet lead is most preferred by roof tilers as it has proven to be long lasting, cost effective and readily available. I am interested to know what sort of roof you are putting down as there are different options for different types of roofs..
I have found that if you aren't sure about something it pays to give a call to one of the companies that manufacture the flashings, they will be able to answer just about any question that you have. Not all roofing suppliers are manufacturers, these guys definetely are and make similar products to the Colorbond, and Lysaght products.
Flashing No1 Roofing Building Supplies
Posted on Mar 16, 2016
Copper is a great metal for roofing and to make gutters with. I have never seen anything so strong and long lasting. The uniquely convenient advantage that copper has is its flexibility. You can bend copper easier than most metals I've seen. Although it can bend, it's still a durable metal that can stand all forms of weather. http://www.kfcroofing.com.au/catalog/index.php?main_page=index&cPath=24
Posted on Dec 04, 2014
Sheet lead is most malleable softer to use &shape with lead beater,copper &aluminium can also be used but more difficult to shape around chimneys ,valleys and gutters etc.
Posted on Feb 15, 2013
    New Friend:
  • 152 Answers
Copper is a good metal for flashing because it is strong, malleable, and durable, but really any flat sheet of metal will do the trick
Posted on Jan 15, 2013
Is metal roofing worth the extra cost?
Definitely yes, metal rooves have dozens of advantages ( like durability, environment friendly, stylish look, reliability, safety, etc. ). Here is the most detailed article about this type of rooves to make final decision METAL ROOF COST . Good luck!
Jul 22, 2015 | Cars & Trucks
Tip
The Best Benefits of Metal Roof Coatings By Conklin
When our white roof coatings are applied to commercial metal roofs you will save money since the frequent local roof repairs will be virtually eliminated. When roof damage occurs from wind and hail storms occur elastomeric white roof coatings are the default choice. In reality Conklin Roofing Systems should be your default choice since they manufacture the best products in the market.
http://roofinghorizon.com/conklin-elastomeric-roof-coatings-austin.html
on May 25, 2015 | Stanley Bostitch Rn461 Gun Coil Roofing...
Flash a metal roof to a wall
if its brick you can cut into it so you can tuck the flashing in and apply sealent and run the flashing on top of metal roofing apply sealent inbetween before screwing down.
Sep 29, 2014 | Roofing
Cleaning roof of oven, does the can the element be removed
Oven roof is made up of metal normally and i think Liquid Roof is best for repairing leaks. You should have a look at it.
Liquid Roof AND RV Roof Coatings
Mar 24, 2014 | Bosch HBN 131560B / 131520 hot-air...
Need class a chimney flashing for penetration through standing seam metal (steel) roof. What flashing is best to avoid corrosion problems due to disimiar metals in contact? Also, how is the flashing...
Hello Stephen.
I do understand what you are talking about with your flashing. Your supplier of the standing seam metal should have similar metal flashing to use on any of your roof flashing points. There is a process to install flashing on a chimney or any other protrusions, If you are still interested post some pictures of what you have and I will explain the best I can. It takes years of experience to do some flashings especially on standing seam metal.
Sep 06, 2013 | Roofing
How to install slate roofing
A slate roofing is actually a nice idea because its make your home quite pretty. To use slate roofing first you need better kins of slates its breakable also but now including roofing you should try another options like metal roofing, rolled roofing , its easy then slate roofing you can also visit http://andersonindustrialroofing.net/replacement/
Jan 12, 2013 | Roofing
What is best Sirius antenna placement on C5 Corvette?
You could actually bury the antenna in the roof header if the roof is all fiberglass, as it won't block the signal as much as a metal roof will. You could leave a piece of sheet metal stuck to the magnet antenna, but I would bury it INSIDE the car with a chunk of metal under it. Should work pretty decet that way, especially if your city has terrestrial repeaters.
Nov 28, 2009 | Sirius Satellite Radio Receiver
Roofing Logo
1,850 people viewed this question
Top Roofing Experts
Colin Stickland
Colin Stickland
Mike
Are you a Roofing Expert? Answer questions, earn points and help others
