Question about Roofing
Is it necessary to put flashing around the chimney?
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 108 Answers
You must put flashing around the chimney ,make sure it's done properly.
Posted on Sep 26, 2014
    New Friend:
  • 152 Answers
Absolutely, if you don't do it you will have to tear up the shingles later and put it in when the roof starts leaking around the chimney
Posted on Jan 15, 2013
How to put the mantel and flue parts back on in the fireplace
Fireplace and Chimney Parts: Diagram and Anatomy
https://www.highschimney.com/.../parts-chimney-anatomy-fireplace-chi...
Nov 30, 2011 - A chimney is made up of up to 22 parts. ... Mantle - Also known asmantel piece or mantel shelf, this piece of hardware is more than a .... I have an old Blaze King Fireplace Insert that was purchased back in the mid 1980's.
How to install a wood burning fireplace insert - Hearth.com
www.hearth.com/econtent/index.php/articles/install_insert
A Heatform is a metal firebox which is built into a full masonry chimney. ... The distance to the adjacent wood trim and the mantle. ... All the way back in the fireplace, or out on the hearth? ... Rockford Chimney Supply - We are the best source forChimney liners and Stainless steel chimney liner kits to install your insert or ...
Dec 20, 2015 | Heating & Cooling
Need class a chimney flashing for penetration through standing seam metal (steel) roof. What flashing is best to avoid corrosion problems due to disimiar metals in contact? Also, how is the flashing...
Hello Stephen.
I do understand what you are talking about with your flashing. Your supplier of the standing seam metal should have similar metal flashing to use on any of your roof flashing points. There is a process to install flashing on a chimney or any other protrusions, If you are still interested post some pictures of what you have and I will explain the best I can. It takes years of experience to do some flashings especially on standing seam metal.
Sep 06, 2013 | Roofing
How much does a Chimney Sweep cost?
Man or woman, the women are much more expensive.
Oct 16, 2012 | WatchBuddy Santa Claus in Chimney Watch
How do I get wood stov in the Chimney?
With a wood stove or vent type chimney it is easy, just take a section of chimney out and insert the heater. With a brick chimney you may have room to put the heater in from inside the house. If not, lower the heater down the chimney.
ChimneyHeaters.com Chimney Heat Exchanger
Hi. I also have the toyo stove and that combined with one of these Heat exchangers will heat a 2000 sq/ft House to the point that you have to open the windows in winter.
I got mine at Chimneyheaters.com but I am sure there are of lots of places that have them.
Jun 02, 2012 | Heating & Cooling
When it rains hard and there is a lot of wind the rain gets into the chimney and drips through a ceiling light. Is there a chimney cap that I can buy that will eliminate the problem?
Hello,Yes there is a cap for every size chimney BUT that (while always being a great idea) will only prevent a WASHDOWN & keep pests and leaves out.The celing light conserns me that the roof flashing is leaking near the chimney during wind driven rain.Try a cap it can't hurt & I hope it works.
Sep 30, 2010 | Heating & Cooling
Screen over chimney?
Screen is not the correct product to use to bird or squirrel proof the chimney. Your local hardware will have what is known as hardware cloth. It's actually a heavy wire mesh with 1/4" or 1/2" square pattern. you should be able to purchase it, by the foot, off a roll.
Jan 06, 2010 | Bosch 36 Inch Pyramid Chimney Hood - Black
How does a draft inducer blower work
A draft inducer blower is used to create a proper draft in a chimney or exaust pipe from your water heater or furnace. In a high efficiency furnace or water heater, there is not enough heat expelled from the unit to the chimney to create a proper draft. The toxic carbon monoxide gas which is expelled through the chimney from your appliance is normally carried upward due to the rising hot air in the chimney. When appliances got more efficient (putting more heat into the water tank and less going out the chimney), manufacturers had to add this blower to help get the gases out the chimney since there wasn't enough hot air to create a draft.
Hope this helps.
Dec 10, 2009 | Fasco GSW Hot Water Heater Exhaust Draft...
What is the height of britannia omaggio 90 cooker hood?
Here are the dimensions that relate to your cooker hood. The measurements are in mm.
Width 980 front 578 rear
Depth 480
Minimum height 1015
Maximum height 1170
Main canopy height 750
(excl chimney)
Chimney section width 436 main body/340 sliding section
Chimney section depth 170
Mounting height 650 - 750
Regards
Alan Hood
ami-man
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Jun 16, 2009 | Kitchen Ranges
Smelling co2 around tank, replaced ventilation but still smell co2? need to see if there is a special way to install ventilation (model # whirlpool fg1f4040s3nov) gas water heater
You may be smelling other products of combustion but CO2 is a color-less/smell-less gas. A water heater should be vented thru 4" vent pipe to either a chimney or a wye which joins it with another appliance and a larger(size must be calculated) connector which connects to the chimney. There can be no reductions in size as you travel toward the chimney, and all pipe must slope at least 1/4"/foot up toward the chimney. Single wall vent pipe can be used unless it is less than 6" from anything flammable in which case type "B" vent may be used with a clearance of down to 1". If all this is correct your chimney may be over-sized or obstructed. Proper venting can be very complicated and technical and takes up most of most installation manuals for any fossil fuel appliance.
Pleas rate my answer!
Mar 25, 2009 | Whirlpool Water Heaters
CDA CPX9 COOKER HOOD - how to remove chimney/disconnect power
remove filters, inside there will be mounting screws, support the unit prior to removing screws. there might be ducting inside clamped on, and a power plug(hopefully) to disconnect.
Jan 26, 2009 | CDA Kitchen Ranges
Roofing Logo
1,197 people viewed this question
Top Roofing Experts
Colin Stickland
Colin Stickland
Mike
Are you a Roofing Expert? Answer questions, earn points and help others
