Question about AEG Lavamat 72640 Front Load Washer
How do i clean the lint filter on my AEG washing machine? As the clothes are covered in lint after wash
  • AEG Master
  • 17,130 Answers
Please check this link for tips to do the job;
click on : cleaning lint filter.
Posted on Jan 15, 2013
SOURCE: aeg 76669 oko lavamat machine not
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Posted on Jun 24, 2008
SOURCE: my aeg washer dryer comes up with e20 flashing
I had the same problem (E20) for a long time and tried everything in the manual before I called AEG to have someone stop by and fix it.
He took the whole top off as well as the back and pulled out all this fuzz that was stopped somewhere. He said it normally comes from using too much detergant and also from not letting the machine run empty every now and then....but it doesn't say to do this in the manual. And anyway, I can't imagine that using too much wash powder made 1/2 kg of fluff.
I still have a guarantee on the machine, but they say that because it is my fault that I got E20 I have to pay for the repairment myself.
I actually think that they build the machine purposly in this way to keep up the money flow. I have an attorney on the case now.
Posted on Jan 14, 2009
  • 3230 Answers
SOURCE: aeg washing machine fault code
This error code means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Posted on May 06, 2009
  • 3230 Answers
SOURCE: AEG Lavamat 86720 washing machine
This means your water sensor has detected a leak. it will stop when the sensor is dry.
post further comment for more help......
SOURCE: AEG LAVAMAT 12700 VI turbo washing machine doesn't drain
Hi, You have taken out the strainer of the washer front and cleaned it regularly haven't you?? If that's clear, it's probably just the waste line blocked. Try removing the waste pipe where it joins under the sink, put it in a bucket and see if the washer drains. It's probably full of sh"te. If that doesn't work, then I'm probably full of sh"te and you might need a new pump.
Posted on Jun 15, 2009
I am getting a lot of lint on clothing is there a cleaning process with my smart drive pride 5.5 fisher & paykel washing machine
clean the lint filter in the machine
put any clothes that are likely to shed lint or are susceptible to collecting lint in a wash bag before putting in the machine
Oct 17, 2017 | Fisher Washing Machines
Is there a filter to catch fluff during wash?
How to Reduce Lint in Laundry - Home Ec 101
www.home-ec101.com/how-to-reduce-lint/
Sep 23, 2010 - I clean out the dryer lint trap every time and that doesn't seem to matter. ... If your washing machine is older, there is a chance that it has a built-in lint trap. If this is the case and ... Follow the directions for cleaning the lint filter.
Washing Machine Pump Filter - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 8, 2013 - Common problems and faults with a washing machine pump filter. ... a pump filter to protect the pump from a build up of lint, and obstructions such as coins. ... towel to catch water and don't take it out at all if the washing machine still ... If you can't see any blockage, or there is just the odd button in there that ...
Is there a filter to catch fluff during wash? - Fixya
www.fixya.com/support/t26006809-filter_catch_fluff_during_wash
3 hours ago - Locating fluff filter on aeg washer/dryer . After using the dryer facility the following wash resulted in garment containing patched of fluff ...
How To Clean Your Washing Machine Filter - YouTube
Dec 13, 2015 | Washing Machines
Where is the lint filter on Speed Queen...
You didn't say if it was top or front loading and did not include a model number. The model number is usually on a tag that is covered by the lid or door.
As far as I know most washers do not filter out lint during the wash but rely on the lint being suspended in the wash water and expelled with the dirty and rinse waters. Many do have filters in the drain that do need to be cleaned at times but the symptom is usuall a slow drain or not draining.
How to Avoid Lint on Clothes from Your Washing Machine Top Load Washer...
This is an active lint filter machine.
Filter Flo Lint Capture
At this link you can download Speed Queen Product Manuals.
Maintenance Tips
Front Load Washer Troubleshooting Lint
Oct 16, 2014 | Dryers
Lint on clothes after washing
its a possibility that one of the main drum bearings is leaking grease through the bearing seals so you will need an engineer to give you a quote for the repairs, it might be cheaper to purchase a new guaranteed machine eric
Jan 06, 2018 | Whirlpool Washing Machines
Clothes are dump after over an hour of drying
maybe too many cloths at one time or maybe the vent is clogged that lets the air outside or you need to clean the lint trap.
Sep 07, 2012 | AEG Lavamat 12710 Front Load Washer /...
Hi I have a Maytag Atlantis MAV975OA top loader. I cannot find a lint filter anywhere and my washing is coming out covered in lint. Can you tell me where the lint filter is so I can clean it? Thankyou
Hi gmallard, it doesn't have a lint collector. This machine is a piece of junk. We're going out today to buy a new one after years of brushing down our clothes with lint brushes. I'll put the Maytag in the shed to wash my dogs pillows etc. (about all it's good for)
Jan 03, 2011 | Maytag Atlantis MAV9750A Top Load Washer
Prblems with Kemore washer
Clean your washing machine before your next wash load to be sure there is no lint trapped anywhere in the machine. Fill the tub about half full of water then add a couple of cups of white vinegar to the wash water. Allow it to agitate and then sit there and soak for at least an hour before you empty the machine.
Lint is small fibers from clothing that have come loose from natural wear or laundering. They can build up in washers and wreak havoc on your clothing. The dryer will remove the lint. But with clothing, like dress shirts that are air-dried, this can be a real problem; often requiring multiple washings to remove the lint. Older washers came standard with removable lint traps that could be cleaned. Some would filter the water as it recycled through the washer, while others would require the removal of the center tub support for cleaning.
Newer washers have a self cleaning system that uses a filter to trap the lint and the spin cycle to flush it away. It saves the inconvenience of having to manually clean the filter.
If you have a lint problem, here are a few tips to try:
1) Low water pressure can impede the flushing action of the washer during the spin cycle. Look for pressure variations during filling of both hot and cold water. A kinked or blocked hose can cause this. Check for sediment in the hose as well.
2) Verify that the all of the water is being pumped out of tub and that no restriction in the drain hose exists.
3) Don't wash high lint producing items like socks and towels with your dress shirts.
4) Use a name brand detergent. They have higher quality cleaners and soften the water better, which helps release the bond between lint and clothing, allowing it be flushed away.
5) Don't overload the washer. Your washer needs water and room to remove the lint.
6) Run a wash cycle with a cup of regular white vinegar added. This will help rid your washer of any accumulated lint.
A washer doesn't produce enough lint to have any effect on a septic system, so a separate washer filter is not necessary.
Add a cup of either white or cider vinegar to your washing machine along with the detergent before loading in your clothes to keep lint off.
Sort out all towels and washcloths since they create lint. Put them through a separate wash cycle to keep them from transferring lint to your clothes.
Check the labels on all your clothing to be sure you sort them correctly. Cotton clothing produces lint in the washing machine while polyester clothing picks it up. Wash them at different times to keep the lint off those that are likely to pick it up.
Turn your clothes inside out before putting them into the washing machine to keep them from collecting lint as they go through the wash cycle
Jun 18, 2010 | Kenmore 24032\24036 Top Load Washer
The washing machine does not filter out lint. It
I have the same problem. There's a plastic piece top back of tub that says "Clean lint filter after each load", but where is it ?
Mar 14, 2010 | Frigidaire FEX831CS Top Load Stacked...
AEG Lavamat 72640 Front Load Washer Logo
317 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
