Nwsg09 laser lighting unit motor does not run. Need schematic to fault find
2 Suggested Answers
  • 1602 Answers
SOURCE: LASER UNIT FOR SHARP AL-1010
GO ON LINE SHARP AL-1010 LASER COPIER SCHEMATICS.
OR THE LOCAL LIBRARY TO INDUSTRAIL COMMITION STANDARD COMMITION, THE BRANCH OF THE COVERMENT THAT REGULATES THAT PRODUCT SHOULD HAVE THE SCHEMATICS OF THE COPIER OF A DEALER OF THE EQUIPMENT SHOULD ALSO HAVE THEM ON MICROFISH, OR KNOW WHERE TO LOCATE SUCH THINGS, OLD TYPEWRITER REPAIR SHOPS MAY HAVE IDEAS WHERE TO LOCATE THAT DOCUMENTS AT
ROD
Posted on Feb 09, 2009
Canon 3300 e000110-0000
Laser motor error fault. you need to change laser scanner unit or check the covers over the primary corona are properly placed as they actuate a laser cover.
Jun 20, 2013 | Office Equipment & Supplies
Im getting a error E52
Error E52 is a Laser Motor Unit Fault. You can buy a new laser motor unit or try to fix it yourself.
Step-by-step instruction:
1 - Remove gently the top cover of the printer ( 4 screws - 2 on top/front + 2 in back/side). [Front screws are revealed by pulling open the front cover.]
2 - Be careful with the connectors going to the top LCD panel. You might want to disconnect the shorter one. [Do disconnect the shorter one.]
3 - Remove the laser unit located on top of the printer covered by a steel plate.
To do that:
1 - Unplug (pull) the white flat connector going to the left side of the laser unit.
2 - Unscrew the 3 screws keeping the laser unit in place.
3 - The lower/right screw also maintains in place the second connector going to the unit. Remove it and unplug (pull) the connector.
4 - Squeeze out the laser unit from under the wires (going back and up).
[If there is a wired cable that goes tightly over the unit, unscrew one screw holding the small circuit board in place.]
You now have the laser unit outside of the printer.
1 - Remove the steel plate of the laser unit. There is a plastic shutter that will come loose. Don't loose it and take note of its location in case you need to put it back.
2 - Unscrew the 4 screws maintaining the motor section and remove it. [This is not necessary. Leave the board in place.]
3 - There is a small piece of black plastic that maintains the top part of the motor unit (with the mirrors) on the left side of the board. Twist it and remove it. [Twist it 90 degrees is sufficient; no need to remove it.]
4 - Pull up the mirror part.
5 - Be careful during all that not to touch any of the mirrors or prism or whatever seems to conduct light. If you do, you can always clean with isopropyl alcohol or glasses solution. [Since you have to touch the mirror to lift it, I just cleaned it routinely with an alcohol prep pad after I replaced it.]
6 - Put some sewing machine oil on the shaft.
7 - Put everything back together.
Mar 07, 2011 | Brother HL 7050 Laser Printer
I have a phaser 7700dn and the error code 44 has come up fuser sub lamp failure
THIS IS THE TEXT FROM THE PHASER 7700 SERVICE MANUAL, HOWEVER, SEE MY COMMENTS AT THE END OF THE QUOTE.
11 06-372 ERROR 11 LASER UNIT POLYGON MOTOR FAILURE
Note
If this failure reoccurs three times successively, an Engine NVRAM
value is set preventing further printer use until the Clear Tech Rep
Fault, Clear <09-380 ~ 09-383> is run.
Remove Rear Cover (RRP 1, on page 7-154).
Disconnect P400 (see figure page 2-46) and P401 (see figure page 2-46) on the Engine Control
Board.
Inspect both connectors to determine they are fully engaged as a unit. Re-engage, if necessary.
Note The two connectors can NOT properly seat into their socket(s)
unless they are both engaged as a unit. Ensure there is no
separation.
Carefully reinsert the plugs into their joint socket and FIRMLY seat them.
Replace the Laser Unit (RRP 38, on page 7-200).
Note Whenever the mounting screws for the Laser Unit have been
loosened, it is necessary to recalibrate the unit by performing the
RegiCon Adjustment Procedure beginning on page 4-124.
If the problem persists, replace the Engine Control Board (RRP 42, on page 7-206).
It has been my experience that 90% of the time the scanner motor (polygon motor) has gone bad. I have repaired many 7700 printers with this error by replacing the laser scanner. The part can be purchased at: http://www.lpscomputer.com/p-3060-1-116-1110-00-laser-unit.aspx
Jun 02, 2010 | Xerox Phaser 7700 Laser Printer
ERROR L6
An L6-10 code is a polygon motor failure in the copier's laser unit. It's what flashes the image to the system drum. If it won't clear after shutting down/unplugging the unit for 30+ seconds then the laser unit (the LSU) needs to be replaced. You'll need to contact a trained Sharp service representative to facilitate the repair.
Oct 01, 2009 | Sharp AR-M205 Copier
Schematic missing - need to know which cond unit
Black wire goes to contactor. On your capacitor the brown wire goes on one side the blue and the other wire from your contactor goes on the other sideof the capacitor. Russ
Aug 07, 2009 | Heating & Cooling
ROD
Feb 09, 2009 | Office Equipment & Supplies
AR200 with L6 fault
Your laser unit may be bad. try c interupt 0 interupt,,enter 14 and push start. the machine should reset. If the code returns, you need a laser unit replaced. 200-300 dollar repair.
Feb 04, 2009 | Sharp Office Equipment & Supplies
Asko W640 - sporadically says motor fault and won't run, or, won't stop running, gets stuck on the spin cycle. We've had the motor fault problem before, but this "running on" issue is...
I would say the won't-run problem is separate from the run-on problem. You can live with the run-on problem -- probably a fault in the controller. Unless it's a faulty code, the motor-fault light probably means the motor is overheating. That can be caused by anything that causes it to work hard, such as a stuck pump.
Nov 26, 2008 | Asko Washing Machines
Unsolved fault
check all your paper cassettes and make sure the paper isnt jammed in there or that it is installed properly
Jun 19, 2007 | Toshiba e-Studio 350 Copier
Open Questions:
k24674
