Maxor FWRA160NEP001 size - Computers & Internet
I am looking for a charger for a. cce info netbook winbook n22s
Do you have the old charger? if so have a look on the label for the output voltage V and current (A or mA) and wattage W.
It will be something like Output: 19V 3.16A 60W
or --------------------------- output volts:DC 15-24v 0-4.6A 70W Max
or similar
Then you can buy an equivalent one if you can't find the exact one.
You also have to have the correct size plug. But if you have the original you could have the plug fitted to another charger if you know anyone that can solder the wires for you. Just cut the plug off with 5 or 6 inches of lead left on it.
Feb 07, 2012 | Computers & Internet
The Maxor One Touch 4 750 was working fine. I unplugged it to connect to a new computer. Now, I can hear it humming, there is a little click, and then the light will come on and stay on. I plug it into the...
Try unplugging the drive (if it has a power cable then that is all that you need to unplug). Then restart your computer. When your computer begins to start back up, plug the power into the drive again.
If this doesn't work:
  1. Click Start
  2. Right click on my computer
  3. Click properties
  4. Go to Device Manager (depending on version of Windows it will either be on the left or in a tab).
  5. Expand the different sections and look for one with a warning sign (likely yellow). If that seems to be your drive then right click on it and click uninstall.
  6. Then remove the drive completely and restart your computer.
  7. Once your computer has completely turned on and you are looking at your desktop, plug in the drive.
Best Wishes!
Mar 29, 2011 | Maxtor OneTouch 4 Plus 750GB External USB...
Where can convert european shoe sizes to american?
Here you may find a convertion table for shoe sizes.http://www.dancesport.uk.com/shoes/conchart.htm
Oct 27, 2010 | Clothing Accessories
Computer doen't recognize Maxtor n256 have to boot by CD
  1. Log on as administrator or as a member of the Administrators group.
  2. Click Start, click Run, type compmgmt.msc, and then click OK.
  3. In the console tree, click Disk Management. The Disk Management window appears.
  4. you should see the maxor disk (unallowcated)
  5. right click & format it
Apr 04, 2009 | Maxtor Hard Drive
Maxtor 120gig unable to open.
Try inserting your Maxor into the computer and then REBOOTING. Chances are, they will show up after the reboot (assuming the correct drivers are present). Some USB devices are not totally plug and play. I had the same problme at work last year until I figured out this trick.
Nov 22, 2008 | Maxtor OneTouch USB (A01B120) 120 GB Hard...
Driver for MAXTOR External Drive FWRA160NEP001
You should be able to download the drivers from HERE . They only list product names like Maxtor One Touch 4 and such, so I couldn't point you to an exact link.
Hope that fixed ya..
Geno
Apr 02, 2008 | Computers & Internet
Lost wires for Maxtor hard drive
you want usb cable (from drive to system) i will send otherwise post the problem clearly
Mar 24, 2008 | Computers & Internet
Maxtor 3 one touch mini 60GB won't load or Format
Try deleting All Partitions & then Partition whole Drive,using 59.0Gb.This should give approx. 8MB buffer.
Also when formatting,remember to format Ordinary not Quick Format
Jan 21, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
