Replacement Power Chord and Black Grill top/back Teac A-3440
I need a replacement power chord and replacement original top and back quater pannel/black ventilated grill for my Teac A-3440 as well as support of how to replace power chord.
    Genius:
  • 1,175 Answers
Service info here:
http://www.hifiengine.com/manuals/TEAC/A-3440.shtml
Join the reeltoreel group on Yahoo groups . There's abunch of guys that might be able to help you find parts.
Please rate my help if you could.
Thanks
Posted on Feb 09, 2009
Black ink does not print with a new printhead
clean the printhead with a lint free cloth as well as the black ink cartridge... make sure you clean the copper contacts properly..
then put it back in...
unplug the power chord from the back of the printer without turning the product off and then press and hold the power chord for 30 sec...
then re plug in the power chord...
then check if that works...
connect the printer directly to the walloulet....
try changing the black ink cartridge...
hope this works...
Oct 17, 2013 | HP OfficeJet Pro K8600 Printer
The print cartridge can not move
turn on the printer then try to move it manually..
if it does not work turn it off and try to move the carrriage manually.
still does not work then do following steps...
1) connect printer directly to wall
2) remove the power chord from back of the printer and then press and hold down power button for 30 sec. release the button and plug in the power chord..
3) if still it does not work out then unplug the power chord from the back of the printer.. press and hold the pound(#) and number 6 key together. then without releasing the button plug in the power chord.. once the power chord is plugged in release the buttons.. the printer would align .. if still it does not work then replace the product as it is an issue with the carriage
Mar 26, 2011 | HP Officejet 5610 All-In-One InkJet...
Hp c5280 wont switch on, its been working well when last used this morning.
Disconnect the power chord from the back of the printer. Wait for 40 seconds and connect it back and check if it is warming up or not. If not the press power key for few seconds and see if it turns on or not.
If not then check if the adapter is getting warm or not after it is connected to wall outlet.
If adapter is warming up then try another power chord and check..
If both power supply are getting warmer then problem is with printer hardware and if printer works with another power chord then replace the damaged power chord
Feb 25, 2011 | HP Photosmart C5180 All-In-One InkJet...
C309a ink level shows low after replacing cartridge with cosco refilled original HP cartridges???
1) remove all the orange tape from the cartridge properly...
2) plug in the power chord directly to the walloutlet
3) unplug the power chord from the back of the printer.. then press and hold down the power button for 30 sec... then release the button.. the plug in the power chord and turn on the printer..
check the ink level...
4) if it does not work press the setup button on the printer >>> press the right arrow and go to Tools >>> clean printhead...
5) after it is done again press setup >>> Tools >>> Align Printer.
after that is done check the ink level again...
if it still does not work follow the next step..
6) unplug the power chord from the back of the printer.. then press and hold the pound(#) and 6 key together.. then withough releasing the button plug in the power chord... after you plug in the power chord release both the buttons... alignment will continue... do not stop the alignment...
after it is done again check the ink level...
7) you can also check the ink level by pressing the setup button >>> Tools >> Display Estimated Ink Levels...
Hope this works for you...
Jan 25, 2011 | HP Photosmart Premium C309A All-In-One...
I have lost the power cord and would like to know the replacement price
you dot necesarily need to buy a replacement, these power cords are universal and you should be able to use any other power chord from even a completely different device. PLEASE NOTE THAT THE VOLTAGE OF THE POWER CHORD MUST MATCH THE VOLTAGE OF THE SPEAKERS
Oct 08, 2009 | Kinyo SW-7352 Computer Speakers
Brand new Black Max 5 gallon wont run
Unplug the compressor power chord. If you can turn the flywheel, then nothing is stuck. Plug in the power chord and try the compressor again. If it does not work, return the compressor for a replacement.
If you can't turn the flywheel, then something is stuck, return the compressor for a replacement.
If you can't return the compressor for a replacement, then try to take it apart to locate the problem and fix it.
Jun 10, 2009 | Air Tools & Compressors
Power cord came out the back of the tv
1. Replace the power chord.
WARNING HIGH VOLTAGE: Do not attempt to work on your set without another person present who is trained in CPR
If the power chord is a plug in type , plug it back in.
if the power chord was ripped out , you need to repair it.
if the power chord was broken before you discovered it, you will also need to repair it.
I do mean a proper repair not just an electrical tape job.
Thank you for selecting FixYa!
azkeyz@fixya.com
Wizard Division.
Sep 24, 2008 | Televison & Video
Hoover Fusion Cyclonic
Ok, lfitz, I fixed my problem. First I called the Sears Service Center. They told me that I would have to drop it off there, and they would send it to Orlando to get looked at. The whole process would take about 2 weeks and who knows how much money. So I decided to become my own Hoover technician. It turns out that my original diagnosis was right about the chord that electrically connects the power on/off switch at the top of the handle to the rest of the vacuum. This was extremely easy to fix so please don't be scared away, although it does require a little philips-head screwdriver action. As always, make sure the vacuum is unplugged before you start. On the back of the vacuum, there is the hook that you wrap the electrical chord around for storage (the top one). On either side of that hook are two screws. Unscrew those. Now, the small piece of plastic that has the hook on it can be carefully pulled back, or removed if you need to. Inside, I found the detached end of a coiled black electrical chord that looks kind of like an A/C adapter. This chord should be plugged into the bottom of the metal shaft that slides in and out to allow you to adjust the height of the handle. Now, adjust the metal shaft so that you can plug the black chord back into the base. Push the chord in until you hear it click. Now, put the plastic piece back in place and put the screws back in and you're done. Plug it in and give it a try. I hope this helps.
Dec 16, 2007 | Hoover Fusion Plus Cyclonic Upright Vacuum...
121 people viewed this question
 Grubhead
Grubhead
