Question about HP Officejet Pro K5400 All-In-One InkJet Printer
Printer is not copying unless i reset cartridage door ,then black cartridge blinks
Love this printer , it will be immortalized in an art installation one day. It got me through two masters , is easy to repair and a workhorse. I take care of it. It will print one copy at a time then the black cartridge flashes . I can fool the printer if I take off the cartridge door and reset. If I reset the door all lights are normal . It started after three copies, then two , then one weird . Need this workhorse.
  • Kathleen Lefkowitz Jan 17, 2013
    a printer driver is probably a solution as per replies , but which one do I use . I see I am not alone in caring for a printer .
  • 1003 Answers
SOURCE: HP c3180 inkjet printer problem
apply two or three drops of 3 in 1 oil to top of the big silver rod (inside printer cover)on which the ink cartridges ride.
UNPLUG RESTART AND Print
Posted on Jan 21, 2008
hashchathy
  • 246 Answers
SOURCE: hp psc 1350 -check cartridge
Power off switch for a 5 minute .
It doesn't work try to reinstall the printer driver
Or check whether the printer cartridge is fit well in the printer
Posted on Jul 29, 2008
  • 45 Answers
SOURCE: HP F4180, lights blinking - on/off, color, black, resume
Hi Guys,
Please check the following link and its the same for Deskjet F4180
HP Deskjet F4210 and F4213 All-in-One Printers - Blinking Lights- c01632938
HP Deskjet F4200 All-in-One Series - Blinking Lights - c01365789
Thank You
Posted on Jan 20, 2009
efs_perpends
  • 1996 Answers
SOURCE: orange light blinking on check your cartridge keeps coming on
Please go to this link at HP online support and follow the instructions to reseat, and possibly clean your cartridge contacts. Try reseating again if it doesn't work the first time. If you're not successful, you can try to reset the printer by turning it off, uplugging the power cable from the back of the printer, wait a few moments, then reconnect and turn on. Sometimes this will clear the error light.
Don't use the cleaning and alignment tools unnecessarily, as this can compound the buildup of ink around the print head.
If all this fails, you may need to replace the cartridge to get the printer to work...the fault is not always a lack of ink.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 19, 2009
  • 52 Answers
SOURCE: check print cartridge flashing
cartridge circuitry damaged, replace with new one
Posted on May 26, 2009
I replaced the cartridage to my lexmark and does not working to make a copy
It could be the cartridge in the carrier. Open the printer cover. Remove both cartridges from the printer. Close the cover. Wipe the cartridge nozzles using a slightly moistened soft cloth to clean it from possible dirts and clogs.
Unplug and re-plug the printer into the power source to reset it. When the printer turns on, re-insert your cartridges. Also, make sure you are using the correct version of cartridges for your model. Close the cover. Try to print again.
Jun 26, 2011 | Lexmark X2600 InkJet Printer
Blinking/flashing lights(orange & green) & won;t pring. Have rebooted computer and unpluged printer. still won't print.
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head install both cartridges on ur printer n check ur blinking light on ur printer that will work only if u r too lucky other wise u have to purchase a one cartridge.
May 29, 2011 | HP DeskJet 5550 InkJet Printer
`HP Deskjet F380 All-in-One Printer-Scanner-Copier E light is on seeming to refer to an ink cartridge issue. I installed new black and color ink cartridges. Light is still on and printer won't make...
Issue: Print Cartridge light is blinking
NOTE: In addition to the blinking light, an "E" might appear in the Copies area.
Solution
Close the print cartridge door.
Cause
The print cartridge door is open.
Oct 28, 2010 | HP DeskJet F380 All-In-One Printer
I have a kodak 5500 aio printer. I replaced the
Try the following:
1. Open the printer access door.
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
Sep 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Power Light Continues to blink.
if you are having issues after installing the new cartridges , then perform the following steps.
unplug the power adapter and remove both the cartridges and then power on the printer , look for the power light. if it does not blink then .
install the black cartridge first and then try to print , if it prints fine its ok. then remove the black cartridge and then put the color one in and then try printing or copying .
if it doesnot print with any either black/ color then you have to replace that particular caratridge..
lemme know once u r done....
May 02, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1270
It sounds like you don't have enough memory. You can assign hard drive space as virtual memory. (right click on "My computer" open properties, then advanced.)
as a last result, add more memory. Memory has gotten cheaper lately.
Jan 26, 2008 | Lexmark X1270 All-In-One InkJet Printer
Can this machine COPY from the Black Cartridge only.
Click Start - All programs - HP - HP Director/Solution center.
In HP Director/Solution center. Click Settings - print settings - printer settings . Click on the Colors tab. Enable the option Print in grayscale and Black print cartridge only.
This is the only way to print with single black cartridge.
Thanks
Dec 21, 2007 | HP OfficeJet 7410 All-In-One InkJet...
Hp 1350 all-in-one
When power is applied to the all-in-one for the first time, the power light is solid and the check paper, check print cartridge, black copy, and color copy lights flash, the display will be blank, and the all-in-one will not respond. One or more of the following symptoms will also be observed: The all-in-one keeps turning off Cannot print, scan, or copy The print carriage will not move Windows plug and play (device detection) does not occur The all-in-one does not respond when buttons are pressed, including the power button. SOLUTION: This problem occurs for two reasons: the front panel cover was not installed or the ink cartridge access door was not closed before plugging in the all-in-one. The front panel overlay must be correctly installed before the power cord is plugged in. Follow the steps below to correct the problem: Disconnect the power cord. Lift the scanner lid and carefully line up and install the front panel overlay. Plug the power cord in. The print cartridge access door must be closed before the all-in-one is plugged in for the first time. The all-in-one cannot complete its first initialization until the door is closed. Follow the steps below to correct the problem: Disconnect the power cord. Locate and close the print cartridge access door. CAUSE: The all-in-one initializes when it is plugged in for the first time. While initializing, the all-in-one scans a bar code on the under side of the front panel cover requiring that the front panel cover be in place and that the scanner be operable. The scanner cannot operate when the cartridge access door is open On light (green) - On Check Paper light (amber) - Blink Simultaneously Check Print Cartridge light (amber) - Blink Simultaneously Black copy area backlight (green)- Blink Simultaneously Color copy area backlight (green) - Blink Simultaneously Issue Front panel overlay is not attached at all or not attached properly Solution Turn Off the all-in-one. Attach front panel overlay as instructed on Setup Poster. Turn On the all-in-one.
Sep 06, 2007 | HP PSC 1350 All-In-One Thermal Printer
HP Officejet Pro K5400 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
