Question about Building Materials
What is the correct ratio for mixing concrete?
  • Jake Gibson
    Jake Gibson Jan 27, 2016
    Cynthia, great question regarding the cement mix ration for concrete. It seems like there would be a formula somewhere on the bags. I've also heard you could order precast concrete, especially if you have a large section to form and pour. Good luck with your project, I'd love to see pictures when you're done.
  • Wesley Colberth
    Wesley Colberth Mar 05, 2016
    Hey Cynthia, great question about the correct ration for mixing concrete. I have worked with concrete before so its safe to assume that your having a lot of trouble on your own mixing concrete. I suppose that ready mix concrete can be delivered so that the ratio of the mix is correct. http://jersonsconcrete.com/services/
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 152 Answers
Generally about 2:3 water to cement. it should say on the bag, if it is too watery add more powder, if it is too thick add more water
Posted on Jan 15, 2013
  • bzet1820 Dec 14, 2014
    you are wrong with your answer - you do know that?
  • 700 Answers
For basic mix use (mix by volume):
4 parts sand
1 part aggregate (stones about 1/4" to 3/4")
1 part cement
1.5 part water (adjust accordingly! that amount is average! add 1 part first and then splash during mix till you have consistent doughy structure! if for pouring - add all of that and then up to 1/2 part more)
this mix is good to use as base under the tiles, foundations for mounting paving, stones, benches, first layer of render on the wall, and whatever will be covered with something else.
for working floor use following mix:
3 part sand
1 part aggregate
1.5 part cement
1.25 to 1.5 part water - see remarks above
there is several other proportions and mixes, unfortunately exceeding scope of this short answer
Posted on Dec 14, 2014
Concrete is not just a mixture of cement to water. Concrete is a blend of different mortar and or concrete sands. And an aggregate rock if creating foundation or slab structures. Generally you can buy a concrete blend sand with aggregate, (either gravel or river rock round ,(uptown 2"), at a local landscape supply shop. Or they sell pre mix bags of ready mix that you just add water too. Dependant on the desired slump that works best.
A good do it yourself mix is 3to1 or 4to1. 4 parts concrete sand blend to one part cement. Water depends on slump. Buckets work great for measuring. Use a concrete mixer with aggregate sandcastle mortar mixer without aggregate.
Posted on Jun 29, 2014
Oil petrol mixture for Rockwell 26cc weedeater
Two cycle engines run on a mixture of gasoline and oil. Each engine type is designed to run on a specific gas-to-oil mix ratio.
IMPORTANT: Use only oil that is labeled for use in "Two-cycle" or "Two-stroke" engines. Home Depot and other stores now have "premixed fuel" of gas and 2 cycle oil.
To mix two-cycle fuel, start by putting correct amount of oil in gas can. Then slowly add correct amount of gasoline. Do not try to mix gas and oil directly in gas tank of equipment.
IMPORTANT: Do not use any fuel that is over 30 days old. Do not mix more fuel than you are likely to use in a month. Old fuel can gum carburetors and prevent starting. Always use fresh fuel.
The chart below shows correct amount of oil per gallon that each mixing ratio requires. Expect that yours will be between 32 gas to1 oil and 50 to 1. 32:1 and 50:1 are most popular.
Ratio GAS:OIL UNITED STATES OIL per 1 U.S. GALLON Gasoline
(128 oz.)
*INTERNATIONAL OIL per 1 IMPERIAL GALLON Gasoline
(160 oz.)
*INTERNATIONAL OIL per 1 LITER Gasoline
(metric)
32:1 4 oz. 5 oz. 31.25 mL 40:1 3.2 oz. 4 oz. 25 mL 50:1 2.6 oz. 3.2 oz. 20 mL
Jan 01, 2015 | Weedeater Garden
How do I fix rotted wooden expansion joints in my driveway?
there is a tuberous strip that is used as expansion joints in concrete. To get the correct thickness you may have to use several strips together. they are normally black in colour and you may have to lay in several strips first and then use something like a bolster ( brick cutter) to drive in the last strip. Talk with your concrete supply shop for advice and products ( shop that sells concreting tools and products.)
grout will crack out at that thickness. Because you have such a wide gap (2'' or 4''). I would make up a good concrete mix using bondcrete ( brand name for concrete glue) in the mix and use that with a strip of black jointer either side
Seeing how the timber lasted 40 years if you used treated timber this time it will last another 40 years -probably longer.
Dec 05, 2014 | Cars & Trucks
Can I buy concrete mix online?
Sure, you can buy concerete mix online. Try Home Depot: http://www.homedepot.com/webapp/catalog/servlet/Search?storeId=10051&langId=-1&catalogId=10053&keyword=concrete+mix&Ns=None&Ntpr=1&Ntpc=1&selectedCatgry=Search+All
Jul 22, 2013 | Building Materials
What is the sand and cement mix ratio for a patio
Hello. The typical volume-ratio for a self-mix concrete in this application would be one part Portland cement to three parts sand. For a stronger pad (capable of higher stress loads) it would be as low as two parts sand, but this is not necessary for a standard patio pour. The gravel should be three parts, more will make it tougher to achieve a smooth finish. Re-cap: Portland cement - 1 part, sand - 2 or 3 parts, gravel - 3 parts. Hope this helped.
Apr 12, 2011 | Garden
Echo chainsaw 16in. model 280 E(P) or 290 EVL(P) \r\nLooking for the correct oil and gas mixture ?
The mixture for most echo products is 50:1 ratio. You can use the Stihl fuel mix in this unit .. The Stihl fuel mix is also a 50:1 ratio.
Mar 29, 2011 | Echo Garden
What is the fuel mix ratio for Partner Active 111 concrete saw
50-1 withe Husqvarna two stroke oil, 25-1 with any other two stroke oil, alaways try to use Husqvarna two stroke oil.
Mar 05, 2011 | Garden
Mixing formula for concrete garage floor,concrete,gravel and sand
There should be mixing instructions on the bag of concrete, but it is 1 part cement, 2 parts sand and 3 parts gravel.
May 24, 2010 | RTO M-D Building Products Carpentry &...
WHAT IS THE CORRECT FUEL TO 2 STROKE OIL RATIO FOR A 2006 KAWASAKI KX85
It all depends on what type (and brand) of two stroke oil you're using. For example, some non-synthetic two stroke oils are supposed to be mixed at a ratio of 20:1. While most synthetic oils are designed to be mixed anywhere from 36:1 to 100:1. Your best bet is to follow the advice of the folks at your dealer as to the type of oil to use - and then follow the recommended mixing ratio as detailed in the oil manufacturer's instructions.
Nov 07, 2009 | 2006 kawasaki KX 125
Weed eater TE475 - fuel ratio
FUELING ENGINE
WARNING:
Remove fuel cap slowly
when refueling.
HELPFUL TIP
To obtain the correct oilmix
ratio, pour 3.2 ounces of
2--cycle synthetic oil into
one gallon of fresh gas.
This engine is certified to operate on unleaded
gasoline. Before operation, gasoline must be
mixed with a good quality synthetic 2-cycle
air-cooled engine oil designed to be mixed at a
ratio of 40:1. Poulan/Weed Eater brand
synthetic oil is recommended.Mix gasoline and
oil at a ratio of 40:1. A 40:1 ratio is obtained by
mixing 3.2 ounces (95ml) of oil with 1 gallon (4
liters) of unleaded gasoline. DO NOT USE
automotive oil or marine oil.
Jul 05, 2009 | Yard Machines Garden
Building Materials Logo
1,982 people viewed this question
Top Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
