Question about Cell Phones
IPhone can't charge and can't be detected by PC
    Problem Solver:
  • 5 Answers
Be sure that your Windows PC meets the minimum system requirements to use iTunes and iPhone. This is particularly important if you are connecting iPhone to your computer for the first time. iPhone requires a specific minimum version of iTunes.
Ensure the computer's drivers are up to date
iPhone requires USB 2.0 to function properly. Refer to the documentation for your computer to verify that the USB ports are high-power USB 2.0 ports. Try connecting iPhone to a different USB port, preferably a port that is built-in to the computer instead of an external USB hub. Connecting iPhone to your keyboard's USB ports is not recommended.
In some cases, your computer's USB ports may become temporarily disabled or you may experience other software related issues. Restarting your PC is an easy troubleshooting step that may resolve this issue.
iPhone requires two important pieces of software to operate properly on Windows. First, the driver must be installed; for iPhone the driver is USBAAPL.SYS. Second, Apple Mobile Device Support must be installed as a Windows Service. If these are not installed, see the Reinstall iTunes section below.
Verify that the driver is installed by connecting iPhone to the computer and following these steps:
  1. On the Start menu, click Run.
  2. In the Open field, type devmgmt.msc and click OK. A list of devices will be displayed.
  3. Scroll down to Universal Serial Bus controllers and click the small plus sign to expand this group. iPhone will be listed as either Apple iPhone or Apple Mobile Device depending on the version of the driver installed.
  4. Right-click Apple iPhone (or Apple Mobile Device) and choose Properties from the shortcut menu.
  5. When the Properties window opens, select the Driver tab.
  6. Click Driver Details to view more information.
Verify that the Apple Mobile Device Service is installed and running using the Services MMC snap-in using these steps:
  2. In the Open field, type services.msc and click OK. A list of devices will be displayed.
  3. View the list In alphabetical order and verify that the "Apple Mobile Device Service" status is "Started."
    1. If the status does not indicate the service is started, right-click Apple Mobile Device Service and choose Startfrom the shortcut menu.
    2. If the service is installed and started, right-click the service and choose Restart from the shortcut menu.
    3. If the driver is installed and the service is installed and started, check the Event Viewer for error messages.
      2. In the Open field, type eventvwr.msc and click OK.
Posted on May 24, 2009
How do I upgrade iOS 7.0
Connect to wifi/internet then settings>general>software update follow prompts. Should be charged at same time
Mar 07, 2015 | Apple In Box Iphone 4 Black 32gb 4g At&t -...
Bought my iphone 5 and am unable to charge using both the plug and computer. however am able to charge using the iphone 4 plug. please help!
Before you can charge your iPhone on the computer, your computer needs to install the drivers for it. You might have to reinstall the drivers for it. A good way to check if the drivers are incorrectly installed is to see if iTunes detects it. Try updating your iTunes since the old version of iTunes won't work with ios6 and all iPhone 5 are shipped with ios6
Oct 10, 2012 | Apple iPhone Smartphone
My iphone 3g will not turn on, will not be detected by the computer, and i cannot tell if its even charging
Try holding both buttons, the round one in front of the screen (home button) and the one on top (lock button). Hold both buttons pressed for 10 seconds, the screen will flash and your iPhone will reboot. Connect it to the charging cable and wait for a couple of minutes so the iPhone has enough charge to turn on again.
May 01, 2011 | Apple iPhone 3G
My iphone is not detected in my laptop i use windows i am able to charge it through the AC adapted but iphone is not detected in my laptop please help
I am not sure that what cause that problem, but we could check where problem comes and fix it. Please ensure that you are using the correct USB cable to connect to laptop. There is an USB cable just use for charging, don't use that cable to connect to laptop.
Also if you use correct USB cable, could you change to another USB port, to check your USB port on laptop.
Do you have Itunes on your laptops? Iphone works with Itunes.
Hope this will help.
Feb 07, 2011 | Apple iPhone Smartphone
The ipod is not detected in my pc but it is charging.what is the problem give me reply as early as possible
Unplug your USB cable from the hub, and plug it directly into the computer itself. That is #1 problem, ipods and iPhones don't like to work through USB hubs.
Alternatively, make sure that your charging cable is also a data cable. Some aftermarket cables for iPod and iPhone, especially those packaged with cig. lighter chargers, are charge only, and won't pass data.
If the same cable work on another computer, then you need to take a look at the USB functionality on the computer that is having issues.
That fast enough?
Aug 31, 2010 | Computers & Internet
I can't get my iPhone 3G to detect other bluetooth devices. Some devices detect it, but are unable to pair with the Iphone 3G. This iPhone 3G bluetooth problem is another one in a chain of iPhone 3G...
The iPhone unfortunately does not pair with just any device, it would be best to check compatibility before purchasing a new peripheral for your iPhone.
Dec 27, 2009 | Apple iPhone 3G
I have an iphone 2g, and it takes forever to turn on, up to hours and the screen just apears with the apple and the loading sign, and it keeps turning off and on. and when it finally turns on and then...
Restoring your iPhone should help regain full functionality but please beaware this will completely wipe your iPhone memory so be sure to do a full sync and backup before you do anything.
  1. With your iPhone on connect it to your P.C/Mac using the USB cable
  2. Turn your iPhone off
  3. Press and hold the home button while turning your iPhone on
  4. Your PC/Mac should then detect your iPhone in "DFU mode".
  5. iTunes will also detect your iPhone in "DFU mode" and allow you to select restore.
This can take up to 2 hours so be patient.
Dec 01, 2009 | Apple iPhone 3G
Iphone not detected by computer
i have same prob but my phone is in recovery mode
Jul 27, 2008 | Apple iPhone Smartphone
Iphone not detected with pc or itunes
try changing port and the pc.
if still not working then try changing the cable.
chao.
Jul 19, 2008 | Apple iPhone Smartphone
Cell Phones Logo
924 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
