Question about Transmission & Drivetrain for Ford Transit Connect
Transmission was slying now doesnt move for 1998 Ford mustang GT 4.6 Automatic
Have a 1998 Ford mustang GT 4.6 automatic was running good then transmission started slying then didn't move at all now
    New Friend:
  • 60 Answers
Torque convertor or tranny fluid...
Posted on Jan 22, 2013
I have a 91 Mustang GT automatic with AOD. The car shifts great from 1st and 2nd and 2nd to 3rd but 3rd eventually drops out (release gas peddle then depress and no speed just climbing RPMs)
I tried the DIY service and repair manuals from a website and it actually helped
me repair transmission problem in my ford explorer. it wont move forward or reverse, engine is good both solenoids for forward and reverse work.
I don't have much technical knowledge but I just followed it step-wise, and works perfect! got it from www.reliable-store.com
Mar 23, 2018 | Ford Mustang Cars & Trucks
Shift lever blocked in position D ?
Could be the park neutral switch. It senses that foot is on the brake pedal so shifter can be moved.
Jun 19, 2014 | 2003 Ford Mustang
Is there a standard transmission i could put in a 4.6 litre car that now has a automatic transmission in it
The answer is yes, any 5-speed from a 94-04 Mustang (4.6 or 3.8 doesn't matter, it's the same transmission). You'll also need the pedal assembly, shifter assembly, ecu from a 5-speed, 5-speed drive shaft, clutch and clutch cable, and flywheel.
BUT, If u didn't know all that already... let alone the yes or no answer to ur question, I wouldn't advise doing an over
Apr 30, 2014 | 2000 Ford Mustang
I'm using a toyota altezza automatic ,and the odometer stopped working,what should i check
your speed sensor on transmission there is two front and back most commune back sensor
Dec 04, 2013 | 1998 Ford Mustang
How to check transmission fluid on 88 mustang 5.0
from:milton wright.your 1988 5.0 mustang with automatic trans.the dip stick should be under the hood,on the passenger side next to the fire wall.look down! check with the engine running,transmission in park!
Jul 16, 2012 | 1988 Ford Mustang
1998 mustang automatic transmission stuck in park
probably the brake pedal switch (mounted on the brake pedal lever) starting to fail. it releases the shift lever and controls the brake lights coming on. you will need to replace this.
for now, turn the key in the ignition to the lock position (counter clockwise,) then to the off position (clock wise). In this position the brake shift interlock is disabled and you can move the shifter to neutral. these instructions are also in the owners manual in the driving section.
Dec 01, 2010 | 1998 Ford Mustang
Problems removing 98 ford mustang transaxle
If you are talking about the axle hub nuts,then you may have to use an air impact socket driver and impact sockets.These nuts can be torqued to over 140 FT LBS. Let me know if you need more help.MOE
Jun 22, 2010 | 1995 Ford Mustang
What automatic transmission is a code p in a 1996 mustang gt. I think iy is a tremec t56.
your car has a ford AOD-E if it's an automatic, if it were a 5 speed manual it would be a T-45, the T-56 is a 6 speed manual transmission that was found in the 2003 and 2004 cobra models.
Nov 16, 2008 | 2002 Ford Mustang
Transmission not going in gear
did u turn the torc converter all the way in that is your problem 100% sure
Nov 15, 2008 | 2005 Chevrolet Aveo
Transmission & Drivetrain for Ford Transit Connect Logo
122 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
