Question about Adhesives, Coatings & Sealants
Can i use automotive paint sealant in the house?
    Champion:
    New Friend:
  • 217 Answers
Paint sealant is meant to protect your paint job and keep your car shiny, it won't serve this function in the house, unless you want very shiny walls..
Posted on Jan 15, 2013
Someone told me to put ge silicone sealant over freshly cured silicone caulking to give it a smooth look before painting. now i have a real mess. sealant won't cure what do i have to do
Hey Lorrie,
I am sorry someone gave you this info.. You will and probably have to remove ALL/BOTH the caulking and silicon and then redo the caulking all together. You can use your finger to smooth the caulking.. and you can paint over it when its dry,,,
Jun 22, 2017 | GE Home
I used red primer oil based I want to paint metallic burnt orange on my car is it ok and how well will it work
won't work-- two different types of paint on an oily surface
what will happen is when you apply the top coat it will go all wrinkly and peel off
Aug 31, 2016 | Cars & Trucks
How do I get the old glue off paint work where the old badges where without scratching car?
WD40 or Zoff, or Goo Gone or Jigaloo. Spray on, leave 5 minutes, spray again and wipe off.
Apr 09, 2016 | Cars & Trucks
I have painted and the paint will not dry, it feels dry but if i lay anything on it magazines, etc. it sticks.
You have not mentioned what kind of paint you have used, however, here are a few ideas.
We might accidentally hit on the one.
Some paints, such as latex or enamel, can do this if the first coat of paint is not completely "cured" before you add the second coat.
To be completely "cured", paint has to dry and harden for a set amount of time.
You also did not mention your location, but temperature & humidity can affect the drying time as well.
If the weather or the room is cold and/or damp, that can keep the paint from drying.
The colder and the damper, some paint will not "cure" at all!
If you used an automotive paint, properly mixed paint sometimes has "dryers" added to the paint to help it dry, but the same applies about the temperature and the humidity.
Automotive paint that is meant to be sprayed on cannot be brushed on, for the same reasons, it may not dry.
God bless your efforts.
Dec 04, 2015 | Cars & Trucks
I want to strip the concrete floor that I use jasco seal 6 years a go do you have any product I can use .
  • 1 Make sure that the surface of the concrete is cleaned thoroughly. Remove stubborn dirt or stains with a mixture of one part degreasing cleanser and two parts water. Rinse the concrete well and wait 48 hours before continuing.
  • 2 Use a large paintbrush or a long-handled paint roller fitted with a fine-nap roll to coat the entire concrete surface in a thick layer of soy-based or other environmentally-safe chemical stripper. Allow the stripper to eat away at the sealant for 10 minutes, scrape up the peeling sealant with a paint scraper or putty knife. Clean up all of the debris.
  • 3 Rinse concrete to remove all of the stripper. Let the concrete dry 48 hours. Apply the new sealant or the finish of your choice .
  • Oct 21, 2013 | Jasco Wet Look Cure Seal 0613-GL Set of 4
    We bought homestead roof paint identified as terracotta colour. The paint turned out to be a dirty brown. Four coats were required to paint one tile. The paint is so inferior that the rain washes a lot of...
    This is a chat room for automotive questions
    Your in the wrong section & I doubt anyone
    on the internet can help with your dispute with
    a contractor or mechant
    Aug 28, 2013 | Computers & Internet
    Applied paint sealant on my car but the metal is rusting
    Many paint sealants do not protect against salt water erosion. The salt water works to break down the protective layers to corrode the metal underneath.
    Aug 26, 2013 | Adhesives, Coatings & Sealants
    How to waterproof cardboard boxes
    Paint or spray the cardboard with a waterproof coating
    • Spray the cardboard with an automotive primer and then let it dry. You can also use a variety of waterproof varnishes to provide this initial waterproof coating for your cardboard. Since you will be painting the cardboard with another layer of protective covering, make sure the substance you use for this initial layer can be painted over.
      Next, paint the cardboard with an outdoor latex paint similar to what you would use on the outside of your house. Having these two layers of waterproof sealant--a primer and a latex--should keep your cardboard stiff and dry for quite a while.
    Mar 16, 2012 | Cameras
    LG phone paint chipping
    Ok I have seen great results using the paint from Automotive "Touch Up" Spray cans.. OR those "Automotive "Touch Up" sticks.. providing I guess ya can find the right color? Anyway G L.
    Aug 09, 2007 | LG Jabra Winder - Earboom for Most...
    Adhesives, Coatings & Sealants Logo
    452 people viewed this question
    Top Adhesives, Coatings & Sealants Experts
    David Payne
    David Payne
    Richard Piatek
    Richard Piatek
     perry tradesman    ...
    perry tradesman ...
    Level 1 Expert
    Are you an Adhesive, Coating and Sealant Expert? Answer questions, earn points and help others
