Question about Work Safety
Where can i buy special work safety boots? - Work Safety
2006 Chevy Silverado ac
okay compressor will always work... there is a clutch behind pulley wheel if no or low Freon in system clutch will keep trying to engage but wont... so in your case 1 system needs to be recharged... on clutch needs replacing.. or there is 2 safety switches one on the low side and 1 on the high side... anyway unless you are an mechanic then you can't fix it need special tool and will cost more to buy tools
you can't release the used Freon into the air it against the law... if its the its easier to replace whole compressor with clutch already installed no special tools needed but system need to be discharged which you cant do.. also special tool needed to look for and find leaks...
May 13, 2017 | Heating & Cooling
Iron won't heat
Element or thermostat or safety overtemp device has failed. Unless its a special and expensive iron, it may be cheaper to buy a new one. If its a cheaper Iron, you probably cannot buy any parts for it anyway.
Nov 19, 2016 | Irons
Can anyone recommend a brand of work boots for women?
Most brands that make work boots don't make work boots for women unfortunately, but there are a few that do. Try Ariat, Rocky, or Timberland.
Jul 29, 2013 | Work Safety
Where can safety boots be used? Are they good for factories?
Safety boots and footwear is suitable for many environments such as factories, industrial settings, warehouses etc and can really protect you from work accidents that can endanger your health.
Jan 15, 2013 | Work Safety
I have a pair of Georgia Boots 11" Giant Safety
Do you have a a pair of shoes that you bought not too long ago and the sole is coming apart? If you rather not risk buying another pair of the same shoes only to have them come apart, then this is the article for you.
Difficulty: Easy
Instructions Things You'll Need:
  • superglue
  • shoes to fix
1. 1
Get a tube of super glue--any brand name should do. Just the regular type should do, no need for any extra strength formulas or special types. Make sure the tube has been properly opened at this time--the seal on the tube has had a hole punched in it, in other words.
2.
Get the shoe(s) that need its/their sole(s) fixed. Where the sole is coming apart on the shoe, squirt in a good amount of super glue, but not too much that it will gush out. (If it does, try to wipe off the excess).
3.
Hold the sole and shoe together for the recommended drying time or until they seal. Try not to get any glue on your fingers at this time, as it can stick flesh to other objects.
4.
The sole should be fixed at this time. Sometimes it has to be done over if the drying time hasn't been followed or the glue might have some problem with it. Repeat this procedure for other shoes to be fixed
apply the same proedure for your broken part insted of repacing it
Dec 28, 2010 | Georgia Boot 11" Giant Safety Toe...
I want to raise the handle bars on my Mongoose XR75 mountain bike, any ideas
Be careful, the stem must be inserted at least 3" or to the safety line, or it will snap off. You have to have a metric allen wrench. Like I say, and I cannot stress it more, do not raise beyond the safety line on stem, buy a longer stem, if you want it higher than that. If, the bike is too small, buy a bike that fits you from a shop who specializes in sizing.
Sep 16, 2010 | Cycling
Whirlpool dryer had been working just fine then suddenly it is not heating at all
** UNPLUG a dryer before attempting ANY repairs. Lethal!
A dryer heater is controlled by the timer, a thermostat and a high-heat safety switch. The thermostat and safety switch are mounted on the housing around the heater.
Most likely - If the heater is blown, a visual inspection inside the heater housing will see a loose heater wire.
Next likely - Thermostat problems occur. I replace the thermostat and high-heat safety if either are suspect. Cheap, easy fix.
Least likely - Controller failure. This can be expensive ($80 - $400) so consider if you want to spend the money. A controller is actually fairly easy to change. Buy a new knob as you are likely to break it without experience and special tools.
Mar 22, 2010 | Whirlpool LER4634J Electric Dryer
Special GE wrench to remove front panel
You need a safety screwdriver or a safety wrench, you can find the tool at Stanley's, call them and tell them your appliance model number if you are not sure what tool to buy.
Feb 07, 2009 | GE Ovens
Galanz microwave oven does not heat anything put into it.
Beware first on your own safety before starting repairs if there is no repair experience, microwaves can damage health special by older equipment in most modern tools there are special tools neccesary, but some older machines can have no protected screws , just be warned , better buy new then a repaired choice well-meant by not experienced people. unless it is something insignificant. like a bad soldering or simple component.
Feb 24, 2018 | Microwave Ovens
1997 eclipse netural safety switch
push down then back to reverse. should do the trick. or sometimes its on the shift boot itself that needs to be pushed down. retarted, i know. but there awesome cars!!!! i like the 3rd gen tho. good luck!
Jul 11, 2008 | 1997 Mitsubishi Eclipse
Work Safety Logo
413 people viewed this question
Top Work Safety Experts
Bobby Lewis
Bobby Lewis
Johan Erasmus
Johan Erasmus
Are you a Work Safety Expert? Answer questions, earn points and help others
