Question about Adhesives, Coatings & Sealants
Can i use an adhesive as a sealant? - Adhesives, Coatings & Sealants
    Champion:
    New Friend:
  • 217 Answers
I recommend going to the store and getting a proper sealant. adhesives are generally used just to fill a gap, while sealants are more used for actually fully sealing the gap off
Posted on Jan 15, 2013
Husqvarna LR12 transaxle - isthere a gasket between the case halves /
ring husqvarna spares to see if there is one available
if not most manufacturers just use a quality adhesive sealant like loctite blue or red as the housing faces are machined to close tolerances
might even be a rubber "o" ring in a groove so sealant will not be necessary
Nov 19, 2016 | Husqvarna Garden
I need to glue the sole on the side of my supergas back to the canvas material... which glue should i use?
I have found that silatec construction adhesive /sealant the best to fix soles back on
use clothes pegs to maintain pressure during the dry process time
other than that there is nothing that fixes failing soles
Jun 19, 2016 | Superga Clothing Accessories
What type of glue can I use to glue a poster board to a glass window that will hold up in winter?
The best product that will not harm the poster or window is silicone caulk. There are also some crystal clear adhesives made from silicone now available.
Jul 13, 2015 | Adhesives, Coatings & Sealants
WHAT IS THE SITUATION FOR A LEAK ON OILPAN
new late model vehicles use an adhesive sealant when they fit the pan to the block. Over time this adhesive can break down and leak but this takes years on over 100.000 miles and the replacement is a gasket that you use good quality sealant with..
Dec 10, 2014 | Cars & Trucks
Mobile home roof
If it's a mobile home he probably has it 2-12 pitch roof I would use roll roofing instead of shingles hope this helps
Jul 04, 2013 | Adhesives, Coatings & Sealants
My waterrower has a leaking seam in the plastic tank. I know its not that expensive to get it fixed, but its a big hassle...80 mile round trip in heavy traffic. Is it ok to use plastic sealant like you use...
I sealed my tank seal permanently and also fixed cracks on the bottom with Loctite PL Marine Fast Cure Adhesive Sealant. On the inside when the tank was apart I glued a heavy plastic patch directly over the cracks in the bottom. I made the patch from a flat section of plastic cut from an old refrigerator crisper drawer. After installation with the tank laying flat and level glue the upper side of the tank to the adjacent wood for stability. Wait a few days before filling. Photos are attached. Loctite 10 fl oz PL Marine Fast Cure Adhesive Sealant 2016891 The Home...
Dec 28, 2010 | Water Rower WaterRower A1 Rower
Glass in door is falling in due to sealant breaking up. Where can I get more sealant?
Go to E-bay, and in the search box enter-- High temperature silicone adhesive.
You will find several brands listed for sale, take your pick.
Dec 16, 2010 | Baumatic B187 Stainless Steel Electric...
Why is my lexus ls 400 trunk leaking
ls 400 - trunk leaks water. Fix -- Under the trunk seal at the bottom/rear you'll see that two pieces of metal come together. The adhesive / sealant that is used at the factory seems to leak with age. pull off the seal and use a good adhesive sealer to prevent water from leaking down between the two pieces of metal. Reinstall the trunk seal after it has dried and set properly.
Sep 06, 2010 | 1998 Lexus LS 400
With a cracked tub o a washe tuber, is replacing the tub the only solution, or is there some type of sealant or adhesive that could be used?
You may use a two-part epoxy adhesive/sealant but the cause of the crack must be addressed first. The tub will eventually be damaged completely if there's an issue with the inner basket banging the sides of the the tub. Address any balance issues then take the tub out to apply the sealant properly.
Jul 09, 2010 | Maytag PAV2300 Top Load Washer
Convertible rear window leaks water
Purchase some Permatex clear RTV silicone adhesive sealant from an autoparts store run a bead around the window where you have a leak; smooth the sealant like you would caulk wait 24 hours before use
Jun 03, 2009 | 1996 Ford Mustang
Adhesives, Coatings & Sealants Logo
450 people viewed this question
Top Adhesives, Coatings & Sealants Experts
Richard Piatek
Richard Piatek
David Payne
David Payne
Are you an Adhesive, Coating and Sealant Expert? Answer questions, earn points and help others
